2005 2WD differential replacement
Discussion in '1st Gen Tundras (2000-2006)' started by Eprn1n2, Mar 8, 2023.
  1. Mar 8, 2023 at 5:06 PM
    Eprn1n2
    Eprn1n2 [OP] New Member
    Hello All. My Tundra finally has a problem I need help with. There is a knocking noise when I accelerate. I finally got under the truck and found the noise to be coming from the rear differential. I'd like to replace it with a used one. How do I find out what ratio it is? Can I replace a 4:30 to 1 with a 3:90 to 1? Any recommended parts places for a used diff?
  2. Mar 8, 2023 at 5:15 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    You can have it rebuilt for around $1200 if you pull it and take it to a shop that is known for diffs. You can put whatever gears you like in there. You can also have one mailed to you from East Coast gear or something. Or find a used one perhaps. If you’re ever gonna put larger tires on there 4.56 for 32-33” 4.88 for 33-34 would be my recommendation.
    Eprn1n2[OP] likes this.
  3. Mar 8, 2023 at 5:19 PM
    Eprn1n2
    Thanks for that. Then you know what you're getting. I'd like to get a little better mileage with a 3:90.
    alb1k likes this.
  4. Mar 8, 2023 at 5:27 PM
    You are aware of the major known issue and TSB with the transmission crossmember coming unbolted on 2WD which has the exact symptoms you describe, right?
    sflips, bfunke and MEWaters like this.
  5. Mar 8, 2023 at 6:05 PM
    I guess I could've linked it.
    Details about what comes loose can be found here, it's the 4 center bolts hidden up/under the middle of the transmission crossmember. See the missing bolt to the left of the white centering nub in this picture - this member was missing 3 of 4 bolts from the factory, and the one remaining bolt was loose so their transmission was just slapping around when they accelerated and hit bumps.
    The TSB itself can be found here with the details you need, but you won't need to replace it necessarily. Tighten the bolts using blue Loctite, replacing any missing.
    I also recommend you read this thread.
    If you don't find any bolts missing, tell us some more details about what you're experiencing. At least you'll get a sanity check about whether it's actually the rear end.
  6. Mar 8, 2023 at 6:27 PM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    Check this, it happened to mine.
  7. Mar 8, 2023 at 7:10 PM
    Eprn1n2
    I’ll have a look. Love these forums. I had the vehicle up on stands and ran the engine until the noise was there. Fairly certain it came from the diff.
  8. Mar 8, 2023 at 7:15 PM
    You could be right, but enough folks on here have gotten bitten in the ass on the crossmember thing ... it's worth checking out.
    I mean, if you're lifted, and you have larger tires, it could be worthwhile doing the upgrade to 4.3 if you can find something that'll work. Or even 4.1, but ... yeah.
  9. Mar 8, 2023 at 7:34 PM
    Eprn1n2
    I’ll definitely have a look. I thought I had it when I replaced the bad center support bearing and the rear u joint.
  10. Mar 8, 2023 at 8:51 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You have factory 4.30? Is that on a v6?
  11. Mar 8, 2023 at 8:57 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Dont expect much extra economy from a gear swap. The truck is still pushing the same amount of wind, and dragging the same weight, and at any given time is going to need the same amount of hp (fuel) regardless at what rpm it does it. The v6 has a higher rpm torque peak, so it'll be a little happier at a little higher rpm anyway. Just stay out of OD under 50.
  12. Mar 9, 2023 at 8:14 AM
    Eprn1n2
    My Tundra is the V8. Not sure what the current ratio is. Just checked all the cross member bolts and they are secure. There are not any metal shavings in the gear fluid I drained out.
  13. Mar 9, 2023 at 9:17 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Eprn1n2[QUOTED][OP] likes this.
  14. Mar 9, 2023 at 10:17 AM
    Hell yeah, my truck has the best turning radius out of all of them.
  15. Mar 9, 2023 at 11:48 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    V8 is probably 3.90
  16. May 22, 2023 at 12:36 PM
    Eprn1n2
    Project is done. I purchased a used diff from eBay. That works fine. While I had it apart I did the wheel bearings and axle seals. Finished it off with the drum brake overhaul. Next is adding transmission fluid.
    bmf4069 and shifty` like this.
  17. May 22, 2023 at 9:32 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Where did you get the drums from?
  18. May 23, 2023 at 6:31 AM
    Eprn1n2
  19. May 23, 2023 at 6:41 AM
    If you notice any weirdness with your braking, note that an exorbitant amount of folks have come here after replacing with store-brand drums, bought either from brick-and-mortar or from scAmazon, and reported vibrations, chunky braking etc. because the drums were out-of-round. Aside from the fact scAmazon is a huge source of very authentic-looking counterfeit parts, so we must assume what you got was actually legit, if you notice weird stuff, pop off a drum and take it to a shop to ensure it's in-round. Else have them turned. You may not notice right away.
    Avoid buying parts on scAmazon, fleaBay, WallyWorld online. Several folks (including me) have received a variety of white-box generic and full-on bogus parts from here. Spark plugs are a huge one. And there is NO protection, it doesn't matter which "Storefront" you buy from, if scAmazon if fulfilling the purchase, the item is typically coming from shared inventory bins at your nearest shipping warehouse, and the inventory hitting those bins isn't adequately scrutinized.
    Used parts on fleaBay is another beast. It's the new stuff you need to worry about. Other vendors like RockAuto and Summit will get you guaranteed authentic parts at competitive or better pricing.
  20. May 23, 2023 at 6:45 AM
    Eprn1n2
    Probably all true. So far so good. I'll keep you updated.
  21. May 23, 2023 at 8:56 AM
    Eprn1n2
    Here is the damage to the old diff. Hate to admit it but I ran the fluid low.
    w666 likes this.
