General Supercharger Thread
  1. May 22, 2023 at 11:36 AM
    #8491
    Saltyhero13
    Saltyhero13 Throbbing Member
    Wow. Our guys wasn't even running E85:
    level 1
    Saltyhero13
    · 26 min. ago
    So how does running E85 work? Do you have to swap tunes or is it flex fuel?
    level 2
    pMurawski
    Op · 25 min. ago
    I never ran it on e85, it was tuned on 93 pump gas. It was setup for e85 with the proper injectors and fuel pump, but never switched over.
    level 3
    Saltyhero13
    · 14 min. ago
    Interesting.
    So how did you push such high numbers and not grenade your engine? Your tune must have been on point. Seeing folks break rings lands, crack pistons, and throw rods at much lowers PSI and WHP numbers.
    level 4
    pMurawski
    Op · 6 min. ago
    Tuning was precise with different failsafes in place for AFR readings, etc. Was at around 75% injector rate utility, and the pump had plenty of room to go. If I really wanted to push it could’ve got it to mid 620-630’s on pump, and well over 650 on e85. Didn’t want to push my luck that far though.
  2. May 22, 2023 at 11:58 AM
    #8492
    snivilous
    SW UT
    300k+ Supercharged 2008
    From the little bit I've read, the first real mechanical failure is the rods at like 700whp. Though take that with a grain of salt. Point being if you run plenty of fueling the engine seems to be able to handle quite a bit in stock configuration, which that guy seems to back up.
    Too bad we can't hook up some fail safes since the AFR gauges will output a signal when your boost or AFR is outside of parameters. I guess you could install a big red light on the dash :rofl:
  3. May 22, 2023 at 12:10 PM
    #8493
    Winks4x4Toy
    Winks4x4Toy New Member
    Maryland
    2015 1794 Super White Tundra
    Bak Flip cover, LED interior lights, American Flag tail gate letter inlays, 20in wheels, full audio system, 12in Android center screen.
    This is accurate.
    Silver17[QUOTED] likes this.
  4. May 22, 2023 at 12:16 PM
    #8494
    Saltyhero13
    It makes sense which is why I was wondering about incremental upgrades before going big on a short block.
    snivilous[QUOTED][OP] likes this.
  5. May 22, 2023 at 12:25 PM
    #8495
    Saltyhero13
    The only other folks I've seen offer E85 is National Speed with their " Harrop Stage 4". The price point and build parts list doesn't mention Motec or the GM sensor. Possible it just isn't listed.
  6. May 22, 2023 at 1:34 PM
    #8496
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Soooooooooo.... I went to test my cooling & started bogging, AFR was 20 giving it gas & I was at 20lbs fuel pressure. Tank coming down AGAIN :(
  7. May 22, 2023 at 2:16 PM
    #8497
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    hopefully for the last time! Are you at 3 or 4 drops? Gunning for my record of most drops in the shortest amount of time!
    e30cabrio[QUOTED] likes this.
  8. May 22, 2023 at 2:19 PM
    #8498
    e30cabrio
    This will be 4. It's odd because it goes to 40 for a second on start up & drops to 20, also, it does not go lower when running the adjuster out.
    I swapped in the old FPR hoping that was the issue. Same behavior.
    Of course, it's the hottest it's been (104) I picked it up & will little by little it.
    Can I sell @ 105?
    M3Tundra-JK likes this.
  9. May 22, 2023 at 4:27 PM
    #8499
    e30cabrio
    Fucking feed hose was loose again. I'm seriously not understanding how tight I need to make that hose clamp, both times it was to the point I was worried I was going to break it, so I replaced the "best fuel clamp" with a regular one.
    The one on the left was there, I used the one on the right this time, I forced the hose on the nipple, then pushed the clamp on & tightened it further than I like but I really don't want to do this again. Anything else I should do before buttoning it up (with difficulty, there's 3/4 of a freaking tank)
  10. May 22, 2023 at 5:54 PM
    #8500
    M3Tundra-JK
    Scott
    2005 GX470
    I think I used mostly the clamp on the right, but used one or two of the ones on the left with the Radom Venturi pump
  11. May 22, 2023 at 6:04 PM
    #8501
    snivilous
    SW UT
    When in doubt double hose clamp it is my philosophy.
  12. May 22, 2023 at 6:25 PM
    #8502
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I'm a fan of these types, been running them since my old race car.
    e30cabrio and M3Tundra-JK like this.
  13. May 22, 2023 at 7:45 PM
    #8503
    e30cabrio
    In case anyone is wondering, 4 is the number of times I was able to r&r the tank before the strap bolts stripped.
    Waiting for Amazon next day delivery of helicoil knock offs only m10x1.5 ones available for next day. At least they have 4.5 stars
    The tank is perched on 2 jacks, not thrilled I could not finish.
    M3Tundra-JK and HulkSmurf14 like this.
  14. May 22, 2023 at 9:37 PM
    #8504
    M3Tundra-JK
    Scott
    2005 GX470
    Dang...my tank bolts were self tapping bolts. I just went to town on them with the impact gun every time
  15. May 23, 2023 at 1:00 AM
    #8505
    e30cabrio
    So WERE mine, frustrating.
    M3Tundra-JK[QUOTED] likes this.
  16. May 23, 2023 at 6:33 AM
    #8506
    e30cabrio
    I found a slightly bigger bolt that worked on the front strap, the back strap's fully blown out.
    I have never Helicoiled, any tips outside the instructions on YouTube videos?
    Hopefully, the repair & Loctite will do it.
  17. May 23, 2023 at 6:34 AM
    #8507
    M3Tundra-JK
    Scott
    2005 GX470
    only done a few. just make sure it's straight, and don't use power tools
  18. May 23, 2023 at 10:40 AM
    #8508
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Thanks to @AZTundra for the 750s! And the @snivilous stickers since he’s to cool to send me some lol
  19. May 23, 2023 at 10:47 AM
    #8509
    e30cabrio
    Look just like my 5-O 650s lol
    HulkSmurf14, reywcms and AZTundra like this.
  20. May 23, 2023 at 11:10 AM
    #8510
    snivilous
    SW UT
    :rofl: you know I had considered finding the postage stamps the other day, but I was too busy explaining to you how to measure things :D
    ZPhilip, HulkSmurf14, Wynnded and 4 others like this.
  21. May 23, 2023 at 11:12 AM
    #8511
    snivilous
    SW UT
    And wtf @AZTundra, way to not appreciate my stickers :mad:
  22. May 23, 2023 at 11:27 AM
    #8512
    AZTundra
    Paul
    Phoenix, AZ
    Lol, those were duplicates. I had 2 sets from different orders I placed with you. Just figured I'd save you the postage from sending them out.;) If they were my only stickers @reywcms would have been out of luck.
  23. May 23, 2023 at 11:29 AM
    #8513
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL!!
  24. May 23, 2023 at 11:32 AM
    #8514
    Saltyhero13
    So what are thoughts for keeping the engine happy and safe?
    We know higher AFR to cool the rings/cylinder? Alternate solution is gaping rings/gapless rings may recoup some fueling.
    Looking at a bunch broken piston picture, knock and heat seem to be the killer of piston heads. Common trend seems to be cracked lands (addressed above) or a holes punched right through the head (probably a concentration of heat). Not a metallurgist.
    Thoughts?
  25. May 23, 2023 at 12:08 PM
    #8515
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Having a cooler running Harrop helps I would think. Here are some thoughts on helping a boosted 5.7 live from Matt Smith from older posts on FB which I found interesting.
  26. May 23, 2023 at 12:09 PM
    #8516
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Let us know if you mysteriously begin experiencing long crank/starting issues...
    Look just like my 5-O 750s.
  27. May 23, 2023 at 12:26 PM
    #8517
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Will do. Hopefully not lol.
    Wynnded[QUOTED] likes this.
  28. May 23, 2023 at 12:27 PM
    #8518
    e30cabrio
    Radiator has been acting up, got a new OEM Denso.Should I be concerned about this?
    I was able to bend most of the fins back.
    __________________
  29. May 23, 2023 at 12:43 PM
    #8519
    M3Tundra-JK
    Scott
    2005 GX470
    I was not aware that the TRD coolant cap raised the PSI! Interesting
    nags likes this.
  30. May 23, 2023 at 1:09 PM
    #8520
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's what the PSI rating means....:rofl:
    It prevents coolant from expanding into the overflow tank unless the system reaches that pressure.
