A Kid's Tundra
Discussion in '1st Gen Builds (2000-2006)' started by 2006 Tundra AC, May 28, 2021.
  1. Feb 14, 2023 at 11:35 AM
    #61
    2mchfun
    As said above, some of us prefer to do things on our terms. That's all. If you prefer to wait until you might already be up to your neck in alligators and then have to fix things on your ride, be my guest.
    Y0TA PR0 and BillyB like this.
  2. Feb 14, 2023 at 1:47 PM
    #62
    bfunke
    bfunke Tundra Curmudgeon
    I get that and replace the water pump with every timing belt change but I don’t normally replace fuel pumps on any schedule. I visually inspect everything like belts, hoses, ball joint and tie rods with fluid changes. After replacing 4 failed coils over the years, I just spent $200 more to do the other 4. Back around 120K miles I got the intermittent click of death so I put new copper contacts in the starter solenoid. My old Tundra has been a super reliable ride and never let me down. I plan to drive it another 250-300k beyond its current 250k. Frankly it’s a better platform for towing my wave runner than the 2.5Gen
    2mchfun and BillyB like this.
  3. Apr 15, 2023 at 7:25 PM
    #63
    2006 Tundra AC
    2006 Tundra AC [OP] Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    Here is the final product of my latest project! I am stoked with how well it came out.
  4. Apr 15, 2023 at 7:27 PM
    #64
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    Replaced sway bar bushings along with Wheelers extended brake lines this weekend as well.
  5. Apr 26, 2023 at 4:50 AM
    #65
    Toyotundra06
    Toyotundra06 New Member
    Donald
    2006 Silver Tundra Access Cab
    Man if I could actually spend the money I'd be bringing everything up to date on mine as well.
    2006 Tundra AC[OP] likes this.
  6. Apr 26, 2023 at 5:22 PM
    #66
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    Bilstein 4600s are a good way to go for an update on a budget. I had 4600s on mine for 150,000 and when I took them I tested them and they were still in great condition. 1stgenoffroad even sells a 4600 level kit. Replacing balljoints are a must if they haven't been done, especially the lowers. The tierods are not as necessary unless they have just gone bad. I liked the steering rack poly bushings and they were only $30. Leaf springs are expensive but ATS springs have good stock or extra load capacity replacement options. If you can afford it, I recommend a refresh on the suspension.
    Toyotundra06[QUOTED] likes this.
  7. Apr 26, 2023 at 7:25 PM
    #67
    AverageJoe
    AverageJoe New Member
    DFW TX
    21 DC SR 4WD
    Nicely done, keep up the good work
    Black@Blue19 likes this.
  8. Apr 27, 2023 at 6:08 AM
    #68
    Toyotundra06
    Donald
    I'll have to look into those the ride has gotten...less than smooth over the last 15,000 miles haha
    I've got the 4.0 as well and the only thing I've replaced is...the Alternator.
    Ball joints are next once we move I think 170,000 miles is enough torture for the stock ball joints.
  9. May 10, 2023 at 5:02 PM
    #69
    VenturingSquirrel
    VenturingSquirrel New Member
    USA
    2003 SR5
    Armor - Addicted Offroad front plate bumper - Addicted Offroad rear bumper - All-Pro Offroad Rock Sliders - Custom Front Skid Plate Suspension - 5" Tuff Country DB lift - Camburg UCAs - King Shocks (front, 6" lift, 650 lbs. springs) - Deaver leaf packs (6" lift) - All-Pro Offroad U-bolt flip w/ Timbren bump stops - Archive Garage shackle flip w/ 6" shackles - Archive Garage Rear Shock Relocation Bracket (To Be Installed) Wheels/Tires - Pro Comp 7069 wheels - BFG KO2 285/75R17 Electrical - National Luna dual battery system - sPOD Other - Monsta Liner (entire body) - ARE CX cap - Topper EZ Lift w/ Weekender package - Smittybuilt X20 winch w/ synthetic line - Uniden bearcat 980 SSB CB Radio - Scangauge 3
    This is one of the cleanest 1st gens I've seen. Great work OP!
  10. May 21, 2023 at 6:25 PM
    #70
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    I finished my Bussmann auxiliary fuse panel this afternoon. Bought a sunglasses holder switch panel from B40Built on Instagram and I highly recommend checking him out.
    I also snagged some 285/70/17 Falken Wildpeaks from a guy at work the other day. I mounted them on Saturday and they look tuff. They also ride and handle well for a big, heavy tire. Mucho better than the pizza cutters from before.
    Black@Blue19 and sportbike37 like this.
  11. Jul 2, 2023 at 3:25 PM
    #71
    Tundra1986
    Tundra1986 New Member
    2003 Tundra SR5 4x4
    Great post, I have the same truck , same color. Super jealous of your build. Looking forward to future posts.
  12. Aug 9, 2023 at 5:34 AM
    #72
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Nice rig brother.
  13. Oct 8, 2023 at 5:35 PM
    #73
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    A little rig update:
    Wrapped up my bed rack build. I am pretty happy with how it turned out. Learned some things for a v.2.
    i picked up some Toytec Aluma coilovers that had about 2,000 miles on them as an upgrade to the 5100s. I much prefer the ride and handling compared to Bilsteins with the 2884s.
    Grabbed a u-bolt flip with the archive garage bump stops. I really appreciate Eric's customer service. The USPS lost the package and when it finally showed up it looked like it had been dropped from a plane and there was some damages but he shipped out the damaged parts the next day. Solid product and he stands behind his products.
    Finally, just for fun, I wired a voltometer into my cigarette lighter hole. I ran it to one of the switches to the left of the steering wheel so I can turn it on or off.
    More upgrades very soon. Gears should happen before the end of the year and I am shopping for sliders.
  14. Oct 8, 2023 at 5:44 PM
    #74
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Lookin good! :) Keep up the good work, very nice truck.
  15. Oct 12, 2023 at 8:33 AM
    #75
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Great build! So what gear ratio are you planning on? Any lockers or LSD to be installed while you're in there?
  16. Oct 12, 2023 at 10:45 AM
    #76
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Love this thread!! It would be a cool read to begin with, but the fact that you're 16 and doing this on the truck your Grandfather gave you is SOOO very cool! Truck is looking good!
    You strike me as an exceptional young man, and you're definitely doing Grandpa proud. :bananadance:
  17. Oct 12, 2023 at 12:26 PM
    #77
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    Thanks! @whodatschrome I am planning on 4.30 assuming I can find it. Those are hard to come by sometimes but it looks like East coast gears has them in stock right now. I am torn between a locker and a LSD. I like the ARB locker but I like the Detroit TrueTrac also. I am weighing my options right now. You don't have a recommendation do you?
  18. Oct 12, 2023 at 1:55 PM
    #78
    bfunke
    If you drive mostly on the street go with a LSD
  19. Jan 9, 2024 at 5:39 PM
    #79
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    A couple updates on the old truck. First is I rolled over 200k this morning.
    Second is I have put 500 miles on my new gears and I did the break in oil change this afternoon. I finally landed on 4.56 with a Truetrac. I love how it drives. Gained some torques on the low end and the Truetrac is super capable. I went out to a place in Lago Vista to try out the Truetrac and there were a few places I was concerned about but the Detroit just plowed on through.
    Gotta jack up on the axle to get all that old oil out.
    Few tiny metal shavings but nothing to be worrisome about.
    For a life update, I got accepted to a little school in Longview called Letourneau. Looks like I am going to go learn how to be an engineer. That means I need to get a few things squared away on the pickup before I go. Top priority is replacing the radiator. Denso discontinued the radiator for 4.0L :( so I am looking at the Mishimoto plastic tank.
    https://www.mishimoto.com/2000-2006-toyota-tundra-replacement-radiator.html
    I would replace all radiator hoses, water pump and thermostat and all that good stuff at the same time. I was also considering doing the Hayden 679 axillary trans cooler and Derale 13011 thermostat and not connecting the trans to the radiator to eliminate any possibility of pink milkshakes.
    Anyway, y'all stay warm.
  20. Jun 23, 2024 at 7:37 AM
    #80
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    This weekend I did Aisin waterpump, thermostat, and fan clutch. I pressed new bearings into the old idler pulleys for the serp belt and got an HD green belt from Gates. I also did an oil change (6 months and 1800 miles). I had a new Mishimoto radiator and I found out too late that the coolant reservoir nipple had broken off so I am stuck for a few days until I can get a replacement.
  21. Jul 31, 2024 at 7:50 AM
    #81
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    Just read through this whole thing. This is awesome.
    Super clean mods. Good job man. Great truck.
  22. Aug 29, 2024 at 8:47 AM
    #82
    Methodical
    Methodical New Member
    Maryland
    2006 Tundra SR5 DC TRD 4x4
    Nice work. You save yourself tons of money doing it yourself and know it was done right and to your specifications.
    I just bought an '06 Tundra and getting my feet wet on doing a small lift up front. I am waiting on my 5100s.
