OBD Thread: PIDs, Apps, Dashboards
Discussion in 'Performance and Tuning' started by WNY PAT, Jan 18, 2020.
  1. Apr 20, 2023 at 4:32 AM
    #301
    coTony
    Tony
    Montrose, CO
    That is what I have been doing and getting so frustrated. Not understanding how some folks are showing what they have and nothing like that on mine. The only thing that looks like it has anything to do with the transmission are the "Status of the Shift SW Status (N,P Range)/OFF or ON" and "Status of the Shift SW Status (N,P Range) Supported/Supp or Unsupp". All the rest search results for "Status of" are for OBD Requirements, O2S, Misfire, MIL, Heater Monitor, Heated Catalyst, Heated Cat, Glow Indicator, Fuel System, EVAP, EGR/VVT, blah blah
    I used to have a full set of hair on my head... :frusty:
  2. Apr 20, 2023 at 8:24 AM
    #302
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Not saying this is what you are doing but when I was setting mine up part of my problem was I was scrolling too far down into the list and looking through "Status of the Shift...." instead of just "Shift Status" which is further up the list. Like I said, not saying that's what you're doing but that's what I did at first and something worth noting just in case.
    coTony[QUOTED] likes this.
  3. Apr 20, 2023 at 11:20 AM
    #303
    coTony
    Tony
    Montrose, CO
    No, I have literally read every single line till my eye have bled. Then I think man it has to be there, so I scroll again as I scroll up reading every single one. There has to be one key word that I am not putting in to search with so that is when I decided to relax and read them all.
    When I find it most likely it will be from getting it from another 2018 Platinum owner and I will say DAMN!! Read that a million times and had no idea THAT is what I should be looking for. There are a LOT of new ones in there for the '22-'23's but I seriously do not see anything in regards to the transmission in there except "Status of the Shift SW Status (N,P Range)/OFF or ON" and "Status of the Shift SW Status (N,P Range) Supported/Supp or Unsupp" other than that... nada
    BMET and Gaston[QUOTED] like this.
  4. Apr 20, 2023 at 12:10 PM
    #304
    Gaston
    Gaston New Member
    Gary
    SE MI
    Damn, yeah I have no idea what it would be then. Best of luck figuring it out though! If you figure it out before someone posts maybe circle back and update for others later
  5. Apr 20, 2023 at 1:47 PM
    #305
    coTony
    Tony
    Montrose, CO
    Yeah I was hoping for some of the others with a 2018 could chime in if they have the gear and lock up working. I am trying to get ready for a trip and was hoping to have this available but does not look like I can keep spending all that time doing one thing. Grrrr
  6. Apr 25, 2023 at 3:26 PM
    #306
    coTony
    Tony
    Montrose, CO
    I am looking for someone with a 2018 Platinum that has successfully found the PID for the torque converter lockup? I have no clue what to search for and I have read them all (put them all in a spreadsheet)
  7. May 4, 2023 at 5:40 AM
    #307
    Cthulhu
    I upgraded my tablet to a Samsung Galaxy Tab A8, and drilled a hole in the RAM mount to accommodate the camera for a half-ass dash cam. Also, was running Torque Pro, but pulled the $26 trigger and switched to OBD Fusion. So far, liking it better than Torque Pro, especially with the Toyota PID expansion pack. FYI, the folks at OBD Fusion said that they are working on a rollout for Android that will allow dashboard background color to be changed, as well as other new features. Timeframe?...they don't know yet. :(
    50Shades and jtwags like this.
  8. May 16, 2023 at 3:23 PM
    #308
    coTony
    Tony
    Montrose, CO
    Well found out I had a problem with the scanning and had to start from scratch. The good news is I have a gauge setup that I just used for over 3,500 miles of driving and loved being able to monitor things. I then found the reader I have did not understand the newer language so upgraded and now have all supported PIDs I was looking for.
    Thanks for all the help folks
    Galladanb and Gaston like this.
  9. May 17, 2023 at 6:16 AM
    #309
    Gaston
    Gaston New Member
    Gary
    SE MI
    @azTony glad you got it figured out
  10. May 17, 2023 at 6:20 AM
    #310
    coTony
    Tony
    Montrose, CO
    Not as glad as I am for sure. This was low priority to me apparently but dove in before my long trip and got ‘er dun!
  11. May 17, 2023 at 3:44 PM
    #311
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    why do you need all this? just curious
  12. May 17, 2023 at 7:11 PM
    #312
    BMET
    BMET New Member
    2018 Tundra Limited
    What reader are you using? I am struggling with OBD Fusion. I bought it for the transmission temperature, and there's not a PID for it, even though I bought the extra add-on for my 2018 Tundra. Maybe I am missing something. Any tips?
  13. May 18, 2023 at 5:48 AM
    #313
    Gaston
    Gaston New Member
    Gary
    SE MI
    I'm using OBDFusion with a Veepeak adapter and I'm able to see the PID for transmission temps
    https://www.amazon.com/Veepeak-OBDC...84414029&sprefix=veapeak,aps,623&sr=8-1-spons
  14. May 18, 2023 at 5:56 AM
    #314
    BMET
    BMET New Member
    2018 Tundra Limited
    Thanks Gaston, appreciate it. I am going to swap out my adapter for the one you mentioned. Thanks again!
  15. May 18, 2023 at 6:03 AM
    #315
    Gaston
    Gaston New Member
    Gary
    SE MI
    Welcome, several people here use the same adapter if I'm not mistaken
  16. May 18, 2023 at 9:09 AM
    #316
    Cthulhu
    • GPS Speed: great for seeing how fast you're ACTUALLY going if running different tire sizes than stock (sometimes I'm a cheapo, so for this I prefer it to buying a speed calibrator:rofl:)
    • Gear position, tranny temps, and torque converter lock indicator: for towing
    • Distance to Empty: even though you can see this on the dash info screen, I use my dash info screen to see tire pressures, and don't want to have to switch back and forth from pressures to DTE
    • Power Steering Pressure: can potentially identify steering pressure / rack issues
    • Coolant Temp: for an accurate reading other than the OEM dash needle
    • Battery Voltage: for an accurate reading other than the OEM dash needle, to possibly identify electrical issues
    • Compass and Intake Air Temp: just me rounding out the screen :thumbsup:
    SRT-1, TTund16 and 50Shades[QUOTED] like this.
  17. May 18, 2023 at 9:11 AM
    #317
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    It's odd my setup must of updated but now I don't see or can't find the Oil Temp. Annoying
  18. May 18, 2023 at 11:17 AM
    #318
    50Shades
    J
    West Coast
    i like it! haha i used to have a diesel and monitored at least 8 PIDS haha
    i may copy your setup there..
    Cthulhu[QUOTED] likes this.
  19. Jun 20, 2023 at 11:14 AM
    #319
    bjohnson425
    bjohnson425 New Member
    Brandon
    I have read every post here and the linked threads and still cant find the answer tho it has been talked about.
    2017 Sequoia, VeePeak module with OBD Fusion... is there a way to get the actual TPMS readouts for each tire ? It has to be somewhere in the computer since it has to know when the pressure drops low enough to trigger the light..
    Galladanb likes this.
  20. Jun 20, 2023 at 11:23 AM
    #320
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I don't believe that year has at the feature. Only light trigger. But I don't know for certain.
    bjohnson425[QUOTED] likes this.
  21. Jun 20, 2023 at 11:29 AM
    #321
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    My point of reference is when someone wanted to add this feature to the dash display to older years. Takes a ton of programming etc
  22. Jun 20, 2023 at 4:12 PM
    #322
    bjohnson425
    Brandon
    Are those of you with the VeePeak leaving it plugged in ? I noticed when the truck is completely off it still has a light on.
  23. Jun 20, 2023 at 4:32 PM
    #323
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep I leave mine in fulltime
    bflooks likes this.
  24. Jun 20, 2023 at 4:49 PM
    #324
    Cthulhu
    Just an FYI Rey and @bjohnson425, my TrueStart battery had some parasitic draw from my Carista OBDII adapter. Started unplugging after shutting down the truck, no more leeching. YMMV with the Veepak.
    bflooks and reywcms[QUOTED] like this.
  25. Jun 20, 2023 at 5:43 PM
    #325
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I leave mine plugged in, but mine does not sit more than a day. If it sat longer without driving I might consider unplugging it.
  26. Jun 21, 2023 at 3:42 AM
    #326
    Gaston
    Gaston New Member
    Gary
    SE MI
    I leave mine plugged in and my truck will sit for 4-5 days sometimes, hasn't been an issue :fingerscrossed:
  27. Jul 17, 2023 at 4:21 PM
    #327
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    In OBD Fusion, what is the torque converter temp listed under? Is it “A/T Oil Temperature 1”?
  28. Jul 18, 2023 at 8:08 AM
    #328
    Gaston
    Gaston New Member
    Gary
    SE MI
    Torque Converter is A/T Oil Temperature 2 and the Pan is A/T Oil Temperature 1
  29. Sep 25, 2023 at 11:17 PM
    #329
    Taikowaza
    Taikowaza New Member
    Hi guys thanks for this amazing thread. I just bought the fusion app for iOS but noticed that there is no Toyota add-on yet for 2022+ Tundras. Has anyone found this or been able to purchase or install? @ToyFan from Banks is trying to find the shiftstatus PID for 3rd gen Tundras. Has anyone found this using OBDII? If so it would be awesome if you could help identify that, many thanks! Personally I’d love to have a gauge displaying the shift status on the dash at all times. Much appreciated
  30. Sep 25, 2023 at 11:22 PM
    #330
    Taikowaza
    @azTony were you able to find the shift status PID for the 2022 Tundra using Fusion with the Veepeak? Really appreciate the research you’ve been doing with OBDII for our trucks!
