Anyone Know The Factory Alignment Specs for 2005 Access Cab 4x4, V-8?
Discussion in '1st Gen Tundras (2000-2006)' started by WaterOp, May 6, 2023.
  1. May 6, 2023 at 11:50 AM
    WaterOp
    WaterOp [OP] New Member
    So Lake Tahoe, CA
    2005 Tundra Access V-8 Auto 4x4
    Just got new tires put on (Michelin 265/70R16) and had the truck aligned,
    PRE-ALIGNMENT Left Front; Camber 0.2, Caster 2.5, Toe -0.10, Right Front: Camber 0.0, Caster 2.9, Toe 0.02, Total Toe -0.08
    POST-ALIGNMENT: Left Front; Camber 0.8, Caster 2.5, Toe 0.02, Right Front; Camber -0.3, Caster 2.9, Toe 0.02, Total Toe 0.04
    Truck is stock - no lift kit.
    I haven't been able to find the factory alignment specs on-line, so was wondering if this is within specs?
    Also, dealer claimed that they could not adjust Caster due" to excessive rust" you guys in-the-know, what do you think?
  2. May 6, 2023 at 11:57 AM
    shifty` All my rowdy friends have settled down
  3. May 6, 2023 at 1:38 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    455h0le_dachshund and noahrexion like this.
  4. May 6, 2023 at 5:32 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If the cam sleeves rusted to the bushing sleeves inside the control arms, there is nothing that can be done. Not without cutting them out and installing new hardware and bushings (if not, control arms).
    I don't recall the factory specs 100% but iirc is somewhere around:
    0 to -.10 camber (+/- .50)
    2.0 or 2.5 caster (+/- .50)
    .08 total toe (+/- .20)
    @BubbaW listed what specs I recommend for most.
    I'm currently:
    -.50 camber
    2.8 caster
    .15-.20 total toe
    I was getting a touch too much outside edge tire wear at -.3 camber, so gave it more.
  5. May 6, 2023 at 9:21 PM
    WaterOp
    So Lake Tahoe, CA
    Thanks All!
    Hey Assassin, looks like I may need to replace Lower Control Arm bushings, and/or L.C.A.s as well. Sounds like you might have experience with those, any advice?
  6. May 6, 2023 at 10:03 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    If you don't have a large press and the correct size adapters it's best to just get new arms.
  7. May 6, 2023 at 10:12 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Yeah, break out the sawzall. I’ve done 7 or so in my Toyota dealings. They are hardened steel so it takes some work. I’ve found it’s easier to cut off the arms, grind down the nubs, and then pry them out of the frame.
    Alignment wise, I ask for 0* Camber with the maximum amount of Castor on the Pass side, then for them to dial in the Driver side to the same, but to correct for road crown. Toe just to be in spec.
    bmf4069 and noahrexion like this.
  8. May 7, 2023 at 10:19 AM
    WaterOp
    So Lake Tahoe, CA
    Hey Diablo,
    If you've done 7, you certainly have a lot of experience with these!
    Good old YouTube shows folks cutting at the bushings.
    Is there a reason why you're cutting at the arms instead of at the bushings?
  9. May 15, 2023 at 11:10 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Yep, you’ll go though 12 Diablo Blades trying to cut through the hardened pieces, but technically you could press out the bushings and press in some new ones, but each bushing is close to $100, and not worth my time or the expensive sawzall blades.
    It takes less than 1 sawzall blade to cut through both arms, and a quick flat disc to cut down the nubs sticking out. Then you just pry them out.
    YouTube is full of a bunch of people who have only done it once and one way. I have 5 different 1st gens in my driveway and much of the info on YouTube is junk.
    For example, my girlfriends 1st gen sequoia’s back hatch handle broke. YouTube said it’s a nightmare to replace, and to only get a metal one off Amazon for $12 and don’t waste money on a $200 factory handle. And that you’ll break every clip taking the plastic panelings off.
    Turns out the $12 “metal” handle off Amazon is 100% $hit. Like absolute garbage $hit. Then you find out it’s not $200 from Toyota, it’s $94 and they have updated the design and it’s much beefier. And if you’re not a moron, you can remove every panel without breaking a single clip. Then if you have 1/2 a brain, you can replace the latch in less than 23min having never done it before.
    I’ve never been so shocked at how useless YouTube was until researching Sequoia Rear Hatch handle replacement.
    Bad Jackson and shifty` like this.
  10. May 16, 2023 at 3:23 AM
    NetGnome
    NetGnome New Member
    NJ
    Removed lots of rust.
    I have cut through my control arm bushings with two carbide sawzall blades.
