TRD Pro Wheel Well Camo Trim
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Aug 9, 2022.
  1. Apr 30, 2023 at 11:31 AM
    #451
    Taikowaza
    Taikowaza New Member
    Perfect fit! Great job they look fantastic and cover the tires perfectly. You got them for an amazing price and so much faster than most of us on the thread, nice work!
    Mine are finally arriving tomorrow. Are you going to wire your lights in? That's the big question here! I think I'm going to install mine w/o wiring for now.
  2. Apr 30, 2023 at 11:50 AM
    #452
    Ruger19
    Ruger19 New Member
    2022 Tundra
    Being in central Arizona, I was surprised myself. I waited 6 months before I went shopping. If I hook up the lights, ill source the wire from the trailer plug. For now, they are reflectors.
  3. May 1, 2023 at 6:12 PM
    #453
    Taikowaza
    Most enjoyable install ever. Not wired for the moment, someday! But for now, absolutely in love with these! Looks and quality amazing
  4. May 1, 2023 at 6:22 PM
    #454
    Ruger19
    Ruger19 New Member
    2022 Tundra
    Nice !
  5. May 1, 2023 at 6:59 PM
    #455
    555 TTT
    555 TTT New Member
    Camouflage looks very impressive in sunny weather, but when it's cloudy we will turn on the lights. We look forward to continuing!
    Taikowaza[QUOTED] likes this.
  6. May 1, 2023 at 8:37 PM
    #456
    cruiserhead
    cruiserhead New Member
    Looks good. Stock wheels right? What size tires? Do you have any unpoke (what’s the opposite of poke)?
  7. May 2, 2023 at 2:13 AM
    #457
    Taikowaza
    Stock R20 TRD wheels, TRD 3” lift, BFG KO2 285/65R20.
    The TRD flares feel and look amazing I keep finding myself walking around the truck admiring. I’m sure I could use spacers or install wider tires if I wanted to, but would be worried about rub. Pretty happy with the look r/n.
    If I did want to fill the new space, what spacers would you recommend? Anyone who has done this I’d love pics. Past pics have shown these flares do a great job matching a good poke lol
    For me this setup is great for r20 on the TRD lift b/c of no rub, and better speed and load ratings than flotation. Also listed as the largest for the TRD kit that doesn’t require dealer to make changes I didn’t want. Not sure if spacers would introduce rub w/the TRD lift.
    Either way these parts were worth the long wait, seamless install on the TRD OR limited. Especially cool is how there are pre-drilled slots in our trucks for the flare’s marker light housings in the wheel well! Much beefier than the flimsy (in comparison) stock parts.
    PS I have my black TRD OR flares available
  8. May 2, 2023 at 10:45 AM
    #458
    cruiserhead
    Cool. I also have the TRD lift - with OEM 1794 wheels, but I believe offset is the same (+60). I had bad rubbing on the sway bar with the exact same tires as you so I put spacers on which made the rubbing much better (although still slightly there). My truck is currently at the dealership for an axle issue and they are checking why I rub so bad while it is there. But putting the spacers on is what made me consider the pro flares since my tires are now out a bit. I only did 1" spacers so they are now currently about dead even with the stock flares.
    I used Bora spacers as FYI and they seem very solid, but haven't driven much in them yet and if the dealer can somehow make adjustments so I do not rub without the spacers, I will probably remove them. But this is why I wondered about the wheels looking too far inset with the bigger flares. Seems like it looks good though from your experience.
  9. May 2, 2023 at 12:18 PM
    #459
    Taikowaza
    Thanks cruiserhead! Cool we both have the same tire size and lift! Now you’ve got me curious about spacers! I agree that having that perfect flush fit with the flares would look great, do you have any pics you can post? So you think a 1” spacer would be good, although you mentioned that if you can figure out the rub you might remove then. I’m not familiar with the advantages/disadvantages (if any) to spacers but I will do some reading. Pls LMK what you learn re your sway bar rub and whether the spacers helped! Thanks again!
  10. May 3, 2023 at 7:51 PM
    #460
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Got the flares installed, they look good! Not wired yet, bit will eventually.
    Taikowaza and 555 TTT like this.
  11. May 3, 2023 at 7:53 PM
    #461
    cruiserhead
    here are some pics of mine now with the spacers (stock flares). Hopefully you can get a sense of it.
  12. May 3, 2023 at 8:50 PM
    #462
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    So apart from the added width of these flares, I noticed that the black ones I took off fit inside the crease in the fender so you have an inset crease that follows the line of the flare.
    Then you put the Pro flares on and this crease is now covered and the flare has a rubber gasket that touches the fender and hides the crease. This actually changes the look of the truck sides.
    Some of the blocky appearance that we like about the gen3 Tundras is smoothed out!
    Just thought I would share my observation for those who haven’t installed theirs yet.
    Taikowaza likes this.
  13. May 3, 2023 at 9:52 PM
    #463
    Taikowaza
    Thank you CH! I really like the look with the spacers. I think spacers make the overall effect more balanced with the TRD Pro flares. I’ve been looking at the 1” Spidertrax they look great. Some posts say they make the ride more stable with better tracking! Some posters write that spacers make the build weaker and worse for towing. Studying now!! PS this thread is awesome I love my flares
    cruiserhead[QUOTED] likes this.
  14. May 3, 2023 at 10:02 PM
    #464
    cruiserhead
    Personally, I would just prefer not to have the spacers...less things for something to go wrong. I will be doing a bit of towing as well, but for the time being I need to keep the spacers on because of the rubbing.
    I agree on the look and like the slightly wider stance though. I am leaving them on for now, but likely at some point will just get some wheels with a bit more aggressive offset. I have the pro flares on order, so will see how it looks once installed!
  15. May 7, 2023 at 3:05 PM
    #465
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Added PRO flares ( not wired ) and REK GEN mud flaps.
    stock wheels
    285/ 65 / 20 Toyo A/T 3
    1” Borla spacer
    CD00EDC5-F77E-4131-B62C-FA8F89B2967D.jpg 7F861EB8-7360-4080-A6C6-401ED188A97D.jpg 0DD279FA-371A-46A0-8D54-F881CE0AB9B9.jpg
  16. May 7, 2023 at 3:43 PM
    #466
    Tundra17944Ever
    Tundra17944Ever ‘16 Limited to ‘23 1794
    Tom
    GA
    2023 Tundra CrewMax 1794 TRD 4x4
    Fuel Rebel 6 Bronze 20x9 +20 Nitto Recon Grappler LT295/60R20 PRO fender flares color matched and wired Fox suspension from TRD Pro TRD Pro shift knob Grille surround color matched CBI Covert bumper with bull bar Rear bumper arms color matched BakFlip MX4 tonneau cover WeatherTech mats Gloss black window trim TT cat shield Black TRD grille Tufskinz tailgate letters Tufskinz TRD logo and stripes Tufskinz door sill protector Center console safe TWC 5” exhaust tip TWC slip-on exhaust TWC titanium valve stem caps Beat Sonic amp TRD air filters Diode Dynamics amber fog lights Color matched digital camo fog light bezel OEM Dashcam
    @teab Phase 1 complete (see pics)I got a late start so I will have to work on it a little throughout the week. Can’t wait to get it finished. Like you I want to see this through and not have to come back and make it look better later.
    CV60, Black widow TRD, SC4333 and 2 others like this.
  17. May 7, 2023 at 3:46 PM
    #467
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    That is clean. Nice job!
    iiawah808 likes this.
  18. May 10, 2023 at 9:17 PM
    #468
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Looks great! I've been debating on whether or not I should run 1" spacers with my factory off-road wheels..
    This Saturday I'm having a set of 285/65 R20 Mickey AT Baja Boss installed. This past weekend I installed the flairs and wow, the stock tire / wheel combo was not going to cut it IMO. Did you run your wheel and tire combo without the spacers and decide you still needed them, or were you already running the spacers?
  19. May 11, 2023 at 2:29 AM
    #469
    Yota802
    Yota802 New Member
    I had the tires, level, and spacers installed all at the same time.
    ryanwgregg and SC4333 like this.
  20. May 13, 2023 at 1:58 PM
    #470
    Tundra17944Ever
    Tom
    GA
    @teab Mission accomplished!! I finally had some time to run all the wires and make all the connections. I ran one wire from the driver’s side front across the grille and down the passenger side until I reached the 4 way plug. I also ran a wire from the driver side rear across the spare tire support. All lights were t-spliced into the 2-lead long wire. I made one connection to the 4-way plug and tried it out. All lights work perfectly. If anyone is wondering, the positive pin on the lights is the pin closest to the middle of the light.
    To anyone looking to wire your Pro flare lights, all I can say is….
    @teab is a Tundra genius.
  21. May 21, 2023 at 5:19 AM
    #471
    Yota802
    Yota802 New Member
    Very nice DIY wiring jobs above!!
    I see Rave has a wiring set up for the flares lights. Has any tried this route ?
  22. May 21, 2023 at 7:57 AM
    #472
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have the Rave kit but haven't installed it yet. You get a disconnect for each flare if you ever need to take the flare off. The pin end of the wiring connect to the light and then the shrink wrap is applied. I would inject some epoxy or sealant into the end before putting the heat shrink on. The wires are intended to be permanently installed to the light and the connector sits about 10" to 12" away from the light tucked into the fender.
    The other end has a fuse tap or wire tap. It is pretty easy to install these, it just depends on how you want to trigger them, that will be that hardest part of this.
    I went this route because I didn't want to deal with the shaving of connectors.
    When I was about to give up on my order for the flares and go with Sports, I looked at some flush mount LED's and I was going to install them into the sports. To much time thinking about lights! I need another hobby! I do like the TRD units now that I have them.
  23. May 22, 2023 at 12:50 PM
    #473
    warfare
    warfare New Member
    2012 Platinum and now 2023 Limited Hybrid TRD OffRoad
  24. May 22, 2023 at 12:52 PM
    #474
    warfare
    warfare New Member
  25. May 22, 2023 at 2:28 PM
    #475
    SC4333
    SC4333 New Member
    Grant
    I ended up using some Delphi female pins 16-20ga that I had left over from another project and made the fender flair light connections with them and 18 gauge wire, which is more than sufficient - see picture of amperage draw from the front two lights at less than 2 tenths of an amp. Very solid and the connections wont be going anywhere anytime soon. I'll throw some pictures and a basic step by steps below for anyone interested. Relatively inexpensive and easy to do if you have some basic DIY skills. A few others have done this too, from what I have read throughout the thread. I wont cover any of the 12 volt supply as I have mine hooked up through my switch-pro, but the rear trailer connection, or trailer lights relay under the hood are both good places to start. The non-premium LED headlights also have a parking light connection that can be tapped and will suffice.
    1) Make up your pig tails and with the bare female connectors on one end and whatever connection you want to make on the other. I would put some heat shrink around each female pin as shown below just to make sure they don't somehow contact each-other prior to your epoxy setting up.
    2) Take the Female connectors and inert them onto the male connection at the light housing.
    3) Place the light housing in a vise with some soft jaws or figure out a way to hold them upright so you can fill them with quick set epoxy, or pot the connections with another suitable alternative.
    4) After fully cured take marine grade heat shrink and cover the connection to prevent any possibly water intrusion and also help to prevent wire strain. (I used a 2 minute clear epoxy suitable for plastics, one hr full cure time)
    I would recommend using a wiring loom(s) to prevent any wire chaffing and keep everything neat. Going to attach some pictures that should help give some clarity. Unfortunately I got carried away and didn't take any photos of the connectors after they had been potted with the epoxy. Pretty simply stuff though, and I'm sure you get the idea. Note at the end of the pigtails I used a different type of connector because it's what I had on hand (Deutsch) but they are rather expensive, as are the crimping tools and probably not ideal for your DIY. The Delphi type weatherproof connectors below are perfectly fine to use.
    Some links to products described although you can typically find this stuff in most large metro areas:
    female pins / water-proof connectors https://www.amazon.com/gp/product/B014IU2EE2?ie=UTF8&th=1
    Crimp tool for connectors https://www.amazon.com/gp/product/B071KFLY43?ie=UTF8&th=1
    Heat shrink tubing w/ adhesive liner https://www.amazon.com/gp/product/B0B3JX1G1W?ie=UTF8
    Wiring loom, 1/8" works well for (2) 18ga wires (you can go with hard plastic as an alternative) https://www.amazon.com/dp/B074GN12PY?ref=ppx_yo2ov_dt_b_product_details&th=1
    I used the 2 minute plastic version of this, but this would probably work just fine as well:
  26. May 23, 2023 at 9:44 AM
    #476
    Taikowaza
    Yaboy and ryanwgregg like this.
  27. May 23, 2023 at 9:47 AM
    #477
    Taikowaza
    Thanks Ryan! Hoping I really like the look and drivability. Also hoping no issues with suspension or towing. Do I need another alignment after installing? Running 285/65R20 BFG KO2
    Black widow TRD likes this.
  28. May 23, 2023 at 5:21 PM
    #478
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Looks like I’m not getting my flares. Ordered May 11th.
    Waited until I got this email with email of original invoice attached as well. $375 additional shipping charge on top of the $99 shipping originally quoted.
    ryanwgregg likes this.
  29. May 23, 2023 at 5:58 PM
    #479
    iiawah808
    Oahu, HI
    $160 each from Servco Toyota who is Hawaii’s only dealer.
    I’ll be in OKC in June so I may order there and bring them back with me via check in baggage.
    SC4333, ryanwgregg and Taikowaza like this.
  30. May 23, 2023 at 5:58 PM
    #480
    Taikowaza
    So sorry to hear this Iiawah808! Hawaii is the most beautiful ever but shipping can be so expensive from the lower 48! Same with Alaska in my experience.
    I agree with Ryan, if you can order through your dealer on-island, hopefully they can include your awesome flares with their main shipments and cover the transport.
    Even though your Sparks order will be cancelled (that shipping cost is insane!!) I have no doubt that you will get your flares from your dealer for a fraction of that cost. I enjoy your posts BTW cheers!
    just saw your post re carry on baggage that is a good idea! FYI the box dimensions are really large, much bigger than the flares themselves. Even though the weight is low, airlines may measure and charge for 4 separate luggage pieces…that can really add up.
    my last idea is negotiating with Sparks. Why TF do they have to use 2nd day air FedEx? Super expensive. Why not ship UPS slow boat. Will cost way less. You could even generate labels for them (find some discounts) and they can print and ship. Big savings
    https://www.ups.com/assets/resources/webcontent/en_US/ak_hi_rates.pdf
    iiawah808[QUOTED] likes this.
