Replacing rear leaf springs, what do I need?
Discussion in 'Suspension' started by Nbab23, May 9, 2023.
  1. May 9, 2023 at 7:17 AM
    Nbab23
    Nbab23 [OP] 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Switching to Icon RXT leaf pack. I already have CB 2+ shackles so it'll lift the rear 3 inches to match the front.
    Here is what I have so far: Leafs, OME brake line extension kit, carrier bearing drop kit, new longer u-bolts from toytec, rear shocks that support a 3 inch lift (probably going to go with toytec boss).
    Questions on what else I may need: Different rear bump stops? I don't offroad so not sure if this is needed. Leaf spring shim? I've heard that the factory leafs take into account the 38 gallon fuel tank, so not sure if I'll need a shim on the drivers side. Anything else I may be missing?
    Just want to make sure I can do this once, do it the right way, and be done with it. Thanks all
  2. May 9, 2023 at 6:54 PM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Sierradevil likes this.
  3. May 9, 2023 at 7:17 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Looks good to me. You don’t need bumps stops but you’ll need to drill the factory ones a little to fit the nub in the rxt pack.
    Nbab23[QUOTED][OP] likes this.
  4. May 9, 2023 at 7:35 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Really depends on what you do with your truck…
    silicone paste for lubing bushings.
    Lose the shackles and use the OE shackles. You have the ability to adjust lift heights via add/remove/rearrange the orders of the leafs within the pack. longer shackles negatively impacts both performance and longevity of the pack.
    seriously consider replace shocks with one’s design for the additional droop travel afforded by such a leaf pack. @AccuTune Offroad has a great option https://www.tundras.com/threads/fox-2-5-rear-1-5-3-lift.122878/
    as well as Icon RXT themselves.
    as for bumps… @Durobumps makes an awesome set of f/r bumps for the truck. Or you can go full air bumps (fox,king,SPC,ads,locked).
    Depends on your needs…
  5. May 10, 2023 at 6:31 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Thanks for the additional info. My truck is pretty much a pavement princess with intermittent towing/hauling. I have been going back and forth on switching back to stock shackles and selling the CB shackles. As much as I would love to go fox shocks, I think its overkill for my needs at this time.
  6. May 10, 2023 at 9:06 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    If towing and hauling is gonna be your thing, my recommendation is that you maintain something with an overload spring or add additional weight bearing mitigation components, sump springs, airbags, RaS etc.
    Nbab23[OP] likes this.
  7. May 10, 2023 at 10:05 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Yeah I've been looking into RAS, I also think I am going to go with Dobinsons or OME greaseable shackles since I don't believe I have my OEM ones. They seem to be a little beefier than stock without the added lift.
  8. May 10, 2023 at 5:04 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I can support going the RXTs + an RAS if you're towing. As @BiggHertz I say drop the lift shackles and modify with the leaf springs. That's what I'm going to end up doing with my setup. Of course - I can help you get a hold of all of it :cool:
    Nbab23[QUOTED][OP] and BiggHertz like this.
  9. May 11, 2023 at 6:05 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Awesome, thanks guys
  10. May 11, 2023 at 6:24 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You don't think he'll need taller bumps?
    2mchfun and Nbab23[OP] like this.
  11. May 11, 2023 at 6:25 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Perhaps but not for the wheeling he does not immediate
  12. May 11, 2023 at 6:55 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    10-4
  13. May 12, 2023 at 7:25 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Well I'd say I would not want to go back again and have to undo the U-bolts and add new bump stops so might as well take care of all that while I have it all apart. I have 4 kids, 8 years of age and under so my time is pretty limited. I'll probably just take a day off work to do this. Would you guys recommend the Timbren off road bump stops or what about the Timbren SES system? That seems like it may help with towing and also have a bump stop role as well.
    Decisions, decisions....
    texasrho83 likes this.
  14. May 12, 2023 at 7:53 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    A lot of folks have gone the Sumo Springs route
  15. May 12, 2023 at 7:58 AM
    a_double
    a_double New Member
    Why the pushback on shackles? Is it not good with RXT's? What about with just stock leaf springs and shackles? ...for an unloaded bed mostly.
  16. May 12, 2023 at 8:05 AM
    2mchfun
    If you don't add to the factory bump stop height, then you run the risk of flattened leaf packs when you load up the truck. The whole pkg functions together, if one component isn't right, the whole pkg cannot function properly. Kinda like trying to drive the truck on flat tires. Will it move? Yes! For how long? Bump stops are cheap compared to new springs.
    a_double, Nbab23[OP] and texasrho83 like this.
  17. May 12, 2023 at 8:38 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You can do lifted shackles with replacement springs that have more arch/lift but the bump stops have to be heightened to maintain proper support. If you routinely load down the bed or aggressively wheel to where your wheel gets shoved up into the well, your new springs will lose arch.
  18. May 12, 2023 at 8:41 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    I think the idea is that shackles essentially flatten the leaf springs to provide lift and better travel. So if you are mostly unloaded not a big deal and they can actually improve the ride. But if you are driving loaded, which I am at about 150lbs at a time plus occasional towing then its not ideal as the flatter leaf springs cause greater sag when loaded/towing. In my scenario since I purchased new leafs packs that are adjustable depending upon where you put the extra leaf, it is better for me to ditch the longer shackles and just add the leaf to provide my 3 inches of lift from the springs themselves to keep the natural curve of the spring then add sumo springs or a similar product for extra support.
    a_double[QUOTED] likes this.
  19. May 12, 2023 at 8:43 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    And that's why I want to make sure I get this right. I pieced together things haphazardly early on which probably is what resulted in my factory leafs flattening out so quickly. Time to do it right.
    2mchfun[QUOTED] and a_double like this.
  20. May 12, 2023 at 8:51 AM
    Mine were bad around 13K miles on my 2020. I actually had at leat 1/4 inch gaps between mine.
  21. May 12, 2023 at 8:54 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ouch
  22. May 12, 2023 at 9:01 AM
    Trying to find the pics.
  23. May 12, 2023 at 9:02 AM
    a_double
    a_double New Member
    I was going to simply add shackles to regain rake on a TRD Pro...back to the drawing board and piggy bank. I do plan to load the bed in the winter to help with traction on slick roads. and the occasional recreation load out. Sub'd to this to see how your setup turns out! @Nbab23
  24. May 12, 2023 at 9:04 AM
    The RAS might be good for your sitaution.
  25. May 12, 2023 at 9:08 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You can totally do shackles and/or RAS. Just get better bump stops.
    2mchfun likes this.
  26. May 12, 2023 at 9:17 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Get rid of the stock rubber bushings of the RXT's and replace with coachbuilder/Energy suspension polyurethane kit and apply lots of lube before installing. Quite a welcome addition for not a lot of money and effort.
  27. May 12, 2023 at 9:51 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    I’ll be sure to follow up once I get it all done. It’s definitely adding up fast from a $ standpoint. But once again trying to do it right and do it once so it lasts a nice amount of time.
    2mchfun likes this.
  28. May 12, 2023 at 9:52 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes don't use the bushings that come with the springs. I did and ended up having to buy CB bushings and install afterwards
  29. May 12, 2023 at 10:00 AM
    Nbab23
    Nathan
    PA
    2020 SR5 crewmax
    Are they the same bushings that come with the CB shackle kit? If so I would think I could just re-use them.
  30. May 12, 2023 at 10:04 AM
    2mchfun
    Don't forget to drop your driveshaft carrier bearing a bit with some spacers to keep the u joints happier with the lift. Brake Line ext. Kit as well.
    Trusty Rusty and Nbab23[OP] like this.
