Should I get my alignment redone?
Discussion in 'Suspension' started by Blkdmax, May 8, 2023.
  1. May 8, 2023 at 10:08 PM
    Blkdmax
    Blkdmax [OP] New Member
    Tennessee
    2021 Cement CrewMax 4x4
    I recently installed eibach coilovers with one driver side shim, 295/70/18 on the stock trd wheels, along with toytec shackles set at 1”. Truck leveled out perfectly.
    Had Firestone do the alignment while they mounted my tires and it feels like I’m having to correct my steering constantly, also my steering wheel isn’t straight which drives me nuts. This isn’t my first lifted tundra so I understand the differences after larger tires and suspension upgrades.
  2. May 8, 2023 at 10:23 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Question being... your 'after measurements' show everything in the 'green' (expect right caster, which is only slightly out), but is green indicating OE specs or is green indicating proper alignment specs for your rig after the suspension modifications were done???
    Regarding the non-centered steering wheel... that, in of itself, would be enough to take the truck right back to have it completed properly :thumbsup:
    Blkdmax[QUOTED][OP] likes this.
  3. May 8, 2023 at 10:29 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    You had excessive toe before and they fixed that... supposedly. Looks like they didn't touch your LCA cams, just did the tie rods. Caster is at the bare minimum which might be causing the wander.
    If you can install the front shocks, you should probably just do your own alignments. It isn't that hard.
    Blkdmax[OP] likes this.
  4. May 8, 2023 at 10:31 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You want your total toe around 15, that would be my main concern for tire life. The steering wheel thing gets me too but in and of itself, not a problem if it's slight
  5. May 9, 2023 at 6:03 AM
    Blkdmax
    Tennessee
    I paid for the lifetime alignment with Firestone but I honestly don’t trust them now. I’m getting my oil changed Thursday at the local Toyota dealership, I’ll let them try to get an alignment on it. They’ve done good in the past with alignment’s for me.
  6. May 9, 2023 at 6:06 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You probably need ucas
  7. May 9, 2023 at 6:18 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I wouldn't think you would need UCA's if you only have 2.5 inches of lift in the front, if you went 3 or above with the addition of your shim then you may need a set of UCA's to help dial in the alignment. I personally went 3 inches in the front, never put in UCA's-although they are sitting in the garage waiting to be installed at some point, and have never had the steering wheel issue that you are describing. The steering wheel being not straight means they screwed up and would have nothing to do with your current setup. Agree with taking it somewhere else and seeing if they can correct it.
  8. May 9, 2023 at 6:25 AM
    Blkdmax
    Tennessee
    This is the 3rd tundra I’ve lifted with the same equipment, driver side shim and all. Never need ucas before. I think I just got a half a** alignment
    Nbab23 likes this.
  9. May 9, 2023 at 7:10 AM
    rruff
    rruff New Member
    This is the first time it's been aligned after lifting? I'd use the LCA cams to move the wheels forward and give you more caster. Adjust the front pivot in all the way, then adjust the rear to zero camber. Then adjust the tie rod for toe.
  10. May 9, 2023 at 7:43 AM
    Blkdmax
    Tennessee
    Yeah it is. Good points, makes sense. I don’t think a tech will listen to me if I told them that though.
  11. May 9, 2023 at 8:31 AM
    rruff
    rruff New Member
    They don't want to mess with the LCA cams! And I don't blame them. If it's a high mileage vehicle in the rust belt, those bolts could be rusted solid. Even if not they are like 200ft-lb bolts and any adjustment changes caster and camber simultaneously. But caster isn't so critical... with a lot being best usually, and especially with stock UCAs and a lift, which is why I say pull the front pivot in all the way and just fiddle with the rear ones to tune camber. You might have to make some clearance at the front of your wheelwell, but that's not hard.
    Most of these places will just adjust the tie rods for toe, which is much easier.
  12. May 9, 2023 at 8:51 AM
    Blkdmax
    Tennessee
    It’s a southern garage kept 2021 tundra with 10k miles
  13. May 9, 2023 at 12:31 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    it will drive significantly better with the massive amount of caster uca’s will add.
    I wanted to think firestone didnt mess with your lca bolts, but they something else seems very odd. If you installed a lift, why was your camber perfect in their before measurements?
  14. May 9, 2023 at 4:34 PM
    Blkdmax
    Tennessee
    Thinking they made up the numbers? The definitely finished quickly.
  15. May 11, 2023 at 7:51 AM
    Blkdmax
    Tennessee
    Update:
    Took it to my local dealer who’s always been good. They said the alignment was horrible and they realigned it. Drives so much better now.
    Nbab23 and rruff like this.
  16. May 11, 2023 at 8:02 AM
    rruff
    rruff New Member
    It's interesting how much different the previous guys "after" is vs this "before".
  17. May 11, 2023 at 11:49 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Pretty ridiculous.....glad they were able to take care of it. I'd be getting my money back from that lifetime alignment program. I signed up for a 3 year alignment at NTB and they actually do a decent job of aligning it, but always try to sell me on something else while it's there. I think those programs don't really get any money out of doing the alignments so they don't put too much effort into it if you are not purchasing another service
  18. May 12, 2023 at 3:39 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I go to a local tire shop that does TT, RV, and lifted trucks. They always get my alignments right. Here's today's sheet:
  19. May 12, 2023 at 4:10 PM
    Blkdmax
    Tennessee
    What are your lift specs?
  20. May 12, 2023 at 5:49 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    7.5"
