OBD scanner recommendations?
Discussion in '1st Gen Tundras (2000-2006)' started by Darezee, Apr 27, 2023.
  1. Apr 27, 2023 at 8:48 AM
    Darezee
    Darezee [OP] New Member
    Moose Jaw
    2005 Tundra
    4x4 DC. 2” levelling kit. Factory rims painted Black Sapphire Metallic base/clear
    FA3737C2-2263-4E82-A767-46AEE99FFF58.jpg I have a 2005 Tundra. Can anybody recommend a good user friendly scanner under $500. my specific issue is ABS problem but I’m interested in a good scanner that covers everything else and possibly cover a BMW too.
  2. Apr 27, 2023 at 9:01 AM
    shifty` All my rowdy friends have settled down
    There's a thread for OBD stuff, maybe it helps:
    https://www.tundras.com/threads/obd-thread-pids-apps-dashboards.60459/
    Meanwhile, you may also want to check out this thread in case you find some shit in it that gives you an 'AHA!' moment:
    https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Oh, and on OBD readers, heed the warning, and this warning is true with everyone you buy on scAmazon these days, especially auto parts, appliance parts, etc.:
    https://www.tundras.com/threads/in-need-of-a-proper-diagnostic-tool.112820/#post-2918397
    If you tell us more about your ABS problem, we may be able to help. There are a couple of conditions that are immediate "AHA!" red flags for some of us.
    BravoDeltaRomeo likes this.
  3. Apr 27, 2023 at 9:28 AM
    Darezee
    Moose Jaw
    2005 Tundra
    Hi. Thanks for the tips and warnings I will check out those links. I used a friend’s scanner and replaced a bad connection with no change. The ABS started working in the middle of a 12 hr drive about a year before scanning but then quit again after the trip. ‍♂️
  4. Apr 27, 2023 at 9:35 AM
    What's the ABS doing, locking up too quickly? Pulsing the brakes when it shouldn't, or not pulsing them when it should? Throwing an ABS warning light?
    Has any brake, bearing, or hub work been done within the last year or two and/or last few thousand miles?
    As stupid as this sounds, the adjustment of the rear brakes is pretty critical to proper brake operation all-around on these trucks, and a properly functioning e-brake is pretty critical to keeping the rears adjusted. So much that there's an entire sticky thread on theory and adjustment tactics. Just pressing and releasing a properly functioning e-brake several times back-to-back will adjust down the drums and has fixed a number of reported problems from users, from vibrations to brake feel.
    I'm a pretty big fan of the OBDLink MX+ I bought and the support has been stupidly good because I paid a little extra for the unlock or whatever. I know it's multi-brand, but not sure if it'll work with your BMW or not. There's also a VM of Toyota's Techstream software out on the internet you can find/DL/use with a specific USB dongle adapter available all over the internet, but that may not be nicely-packaged enough for some, or dealing with virtual machines too technical for others.
  5. Apr 27, 2023 at 9:49 AM
    Darezee
    Moose Jaw
    2005 Tundra
    The ABS is non functional and light stays on.
    Replace one sensor when I bought the truck about 6 years ago and it worked fine for a couple years.
    Rear seals were done and brakes were adjusted. Still worked for a time after that.
  6. Apr 27, 2023 at 9:58 AM
    Darezee
    Moose Jaw
    2005 Tundra
    I just read up on that OBDLinkMX+ and it looks pretty good to me
  7. Apr 27, 2023 at 10:04 AM
    Rear seals is one of those red flags I mentioned. Bearings or anything with tone rings would be too.
    Have you simply tried pulling your ABS sensors, cleaning, and reinstalling, checking alignment in the hole, etc?
  8. Apr 27, 2023 at 11:01 AM
    Darezee
    Moose Jaw
    2005 Tundra
    That is one of the things I’ll have to try. I only did the one my friends scanner flagged.
    BTW… my rear windshield quit working. There’s no power at the switch and I didn’t find any bad fuses ‍♂️ Any tips?
  9. Apr 27, 2023 at 11:38 AM
    My 1st reply, 2nd link. The "So you just got a Tundra" (or whatever) thread. There's a link in the 3rd or 4th paragraph for EWD (wiring diagrams) that may be of help.
    I'm not as-familiar with the DC, I've got an AC. We don't get the cool overhead console with temp gauge you DC drivers have, nor the vertical rear slider. I don't recall or know which fuse the rear slider is associated with, and I assume there may be a relay associated with the circuit too, no power to the switch is an interesting observation which screams "fuse" to me, unless the switch is ground-only, i.e. when you throw the switch it connects the circuit to ground, which then trips a relay. But again ... check the EWD.
  10. Apr 27, 2023 at 12:26 PM
    Darezee
    Moose Jaw
    2005 Tundra
    Ah yes I saw that and printed the diagram. I believe there’s a relay in the window cavity. I guess I’ll go there next.
  11. Apr 27, 2023 at 12:37 PM
    One of the other DC owners may actually be able to help.
    A significant number of members are away in Sedona this week for a national gathering (Tundras2Sedona). Things are quieter than usual as a result.
  12. Apr 27, 2023 at 1:19 PM
    Darezee
    Moose Jaw
    2005 Tundra
    Ahh. Well that sound like fun.
