22+ 3rd Gen Wheel offsets/fitment thread
Discussion in 'Wheels & Tires' started by randomquickness, Dec 23, 2021.
  1. Mar 29, 2023 at 6:15 PM
    #481
    trailhunters
    trailhunters New Member
    I'm thinking 18s because I also tow and would like the shorter sidewall for stiffness.
  2. Mar 29, 2023 at 6:15 PM
    #482
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Falken Wildpeak tires
    Yes, a larger diameter wheel than stock will affect the accuracy of Speedo & odo, as they are calibrated for the stock diameter set up. It will be off by a % equal to the % change in wheel diameter.
  3. Mar 29, 2023 at 7:41 PM
    #483
    pawner
    pawner New Member
    Chattanooga, TN
    2022 Tundra Limited with Leer 100XR
    Contrary to most popular setups on here, I got aftermarket rims but stock tire size to keep the plush ride quality, not lose any power, and not have to recalibrate speedo.
    Method 705s 18x9 with 18mm offset.
    Michelin Defender m/t 275/65/R18. Stock is 265/70/R18 but discount tire messed up the order by 1 size. I decided to keep since it's nearly identical in sidewall height, and 275s have just a tiny bit more grip.
    Significantly better ride quality than the stock 20s I have to say.
    Lastly, I ordered some custom metal decals from etsy that say "TOYOTA" to cover up the MR center caps in an attempt to keep the OEM look. Not sure how it will turn out though
    ropedrag likes this.
  4. Mar 29, 2023 at 8:15 PM
    #484
    Tundrafarm
    Tundrafarm New Member
    22 hybrid limited 4x4
    No regrets here 17s +25 offset and 285/70/17.
    ropedrag and pawner like this.
  5. Apr 7, 2023 at 5:58 AM
    #485
    Tundralicious
    Tundralicious New Member
    Toytoy
    2020 Tundra TRD Sport Premium
    Stock for now
    Here is pics of my truck. It has a Ready Lift of 3"/1.25 with 33×12.50×20 on 20x9 +1 Offset Fuel Rims D744 I believe.
    It was rubbing a bit in front so I had to remove the mudflaps. I'll add some fender flares or aftermarket mudflaps to help the paint on my truck.
  6. Apr 7, 2023 at 6:12 AM
    #486
    Tom
    Tom New Member
    17” tires are cheaper ?
    Yaboy likes this.
  7. Apr 24, 2023 at 11:20 AM
    #487
    TexAg03
    TexAg03 New Member
    BJ
    2022 Tundra Capstone
    3" Readylift SST Supsension 20x9 Platinum Fuel Cycle Wheels 315/60/20 Nitto Recon Grapplers
    I went with the 20x9 Fuel Cycle Wheels, 1mm offset. Tires are Nitto Recon Grapplers, 315/60/20. I chose this size vs the traditional 35x12.5's because they weigh 57 lbs vs. 70 lbs and are slightly larger. Lift is Readylift SST 3" lift. The rear 1.25" lift wasn't enough for me, swapped out the 1.25" for 2" rear spacers. Now rear sits .5" higher than front. No rubbing after pinning back inner fender lining.
    Before:
    After:
    Bucng8r, 2010bigdog, U Sh00k and 10 others like this.
  8. Apr 24, 2023 at 11:27 AM
    #488
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    first Capstone I see/read about that doesnt have rear air. Looks awesome!
    TexAg03 likes this.
  9. Apr 24, 2023 at 11:34 AM
    #489
    gearnuts
    gearnuts New Member
    Joel
    Greer, SC, United States
    Dang sweet truck, that is the nicest looking Capstone I have seen! Why they put 22" rims on that thing blows my mind, terrible design decision!
  10. Apr 24, 2023 at 11:39 AM
    #490
    TexAg03
    TexAg03 New Member
    BJ
    Thanks, totally agree!
  11. Apr 24, 2023 at 12:46 PM
    #491
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    That is one damn good looking truck! :101010::hattip:
  12. May 3, 2023 at 8:22 AM
    #492
    dodgemaniac
    dodgemaniac New Member
    Does anyone know if a 275/65r20 on MR30520x9 +18 will fit on a stock avs equipped truck without rubbing?
    I am looking to go woth this wheel and tire option around 34" but would prefer to keep mudglaps and not lift if not neccessary.
  13. May 3, 2023 at 2:24 PM
    #493
    FLKX
    FLKX New Member
    Yeah but you'll poke 1-2 inches past the fender depending on how + your camber is.
  14. May 3, 2023 at 3:42 PM
    #494
    dodgemaniac
    I'm not too worried about the poke but part of the reason I do not want rub and want to keep mud flaps. I have Rekgens now and they do a great job keeping the steps and side of the truck clean. This combination should stick out 1-7/8" more then factory. If they poke out too much I will put a set of Pro flares on to help.
    From looking around it looks like the 275/65r20 will not rub on stock wheels, but I am not sure if they will with Method MR305 in a +18.
  15. May 6, 2023 at 12:13 PM
    #495
    EndlessWanderer
    EndlessWanderer New Member
    Aldergrove, BC
    2023 Tundra Crewmax Limited, TRD OR
    Hey all, I've about a month in with my '23 Limited TRD CM and looking to upgrade the tires. I'll be offloading the Michelin LTX Trail 265/70/18s but I did a quick check on FB Marketplace and found a several ads from people doing the same, $600 for the set, more than 50% off on a virtually new tire! I even saw one ad with the TRD rims included for $1200 (though they did have 10K on them), so it seems the TRD 18" rims are also going pretty cheaply at $150 ea. (this is all Canadian $$$).
    Is anyone getting a good return on their take offs and do you sell tires only or tires + rims?
  16. May 6, 2023 at 7:07 PM
    #496
    gmcguire7220
    Ontario Canada
    I sold my Michelin ltx trails a yr ago. Brand new takeoffs done at the dealer before pick up for $750, rubber only. Although, In Ontario, so maybe a market difference & it was last year.
  17. May 6, 2023 at 9:11 PM
    #497
    ropedrag
    ropedrag New Member
    Jerry
    2023 Tundra Limited TRD OR Lunar Rock Crew Max 6.5
    Can you share what the "poke" is on the tire/wheel combo please? Thanks!
  18. May 8, 2023 at 9:11 AM
    #498
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    zero regrets, helped that I already had the tires from my 19 tundra!
    Fxclm5[QUOTED] likes this.
  19. May 8, 2023 at 7:54 PM
    #499
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    The 18s I have coming in are sub 25 lbs. I'll hang them on the scale when they arrive for a more precise number.
  20. Jun 9, 2023 at 12:16 PM
    #500
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Bring this to the top again. Looked for an answer and didn’t find any.
    Does the oem spare have a TPMS sensor?
  21. Jun 10, 2023 at 4:37 AM
    #501
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    Went from OEM +60 to +15 on some new rims. Love it waaaaaaaay more now, completely more aggressive IMO....If I had my exact number for off-set, I would probably say +20 to +25, but no off-set choice with these aftermarkets. Next up will be mud guards to protect a bit more of the paint now.
    TRD L Power and Yaboy like this.
  22. Jun 10, 2023 at 9:20 AM
    #502
    TSS Army Green
    TSS Army Green New Member
    Looks more aggressive now and looks really good. Which rims are those and can you provide a link to it? What tires and size you went with?
  23. Jun 10, 2023 at 11:34 AM
    #503
    hollandsam
    hollandsam New Member
    2023 Toyota TUNDRA 1794 TRD 4X4
    Retrax bed topper
    Where did you get the hood protector? looking
  24. Jun 10, 2023 at 2:37 PM
    #504
    Mrconnsmythe
    Rims are from OEPLUS (https://www.oepwheels.com/)
    Tires are 295/65R18
  25. Jun 10, 2023 at 3:44 PM
    #505
    Mrconnsmythe
    Right from the dealership so its an OEM part.
  26. Jul 18, 2023 at 8:25 AM
    #506
    SaltLakeTundra
    SaltLakeTundra New Member
    Christopher
    2023 Limited Off Road
    I keep seeing the red/orange/yellow inserts on the grille, but cannot locate them. Link? Good looking rig by the way
  27. Jul 18, 2023 at 12:20 PM
    #507
    Fooyotatundra
    Fooyotatundra New Member
    2022 sr5 trd 4x4
    Running 17s love them
    Blackhorn bh-01 17x9 +12
    dan81, OutCasT, Yaboy and 1 other person like this.
  28. Jul 18, 2023 at 11:07 PM
    #508
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
  29. Oct 6, 2023 at 10:54 AM
    #509
    MTundra87
    MTundra87 New Member
    Bozeman, MT
    22 TRD OR
    Should've come here sooner. I made the mistake of 0 offset Nomad wheels this week. Just ordered +25 Methods in hopes that cures my bro brappp.
  30. Oct 6, 2023 at 1:26 PM
    #510
    DexterL
    DexterL New Member
    Yea 0 offset was a no go for me. Settled on 12 since it was the lightest wheel I could find outside of droping $5k on Volk's. So wide I had to get some color matched fender flares
    MTundra87[QUOTED] likes this.
