Been changing oil every 10k. Did this affect my car?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ealxele, Jan 24, 2023.
  1. Feb 2, 2023 at 3:15 PM
    #181
    AZBoatHauler
    So.Arizona
    When I put the Royal Purple in, my rear magnet was loaded and the front had a small amount - all paste, no chunks. When I swapped the RP for Severe Gear, there was almost nothing on the rear and absolutely nothing in front. It had been about 25k miles between changes.
    Wallygator likes this.
  2. Feb 2, 2023 at 3:17 PM
    #182
    AZBoatHauler
    So.Arizona
    75-90 here. I’m sure 75-140 would be superior but I’m trying to avoid my MPGs dropping to single digits. :D
  3. Feb 2, 2023 at 3:27 PM
    #183
    Wallygator
    75w90
  4. Feb 3, 2023 at 11:59 AM
    #184
    eagleguy
    eagleguy New Member
    Just got Super Tech 0/20 from Wally. $21 per 6 quart jug.
  5. Apr 21, 2023 at 7:36 PM
    #185
    blenton
    blenton New Member
    I spoke with the folks at High Performance Lubrication and inquired about moving from a synthetic 75-90 to a 75-110 or 75-140. Their opinion was that a good 75-90 is superior to the other weights in our trucks, as well as most trucks these days, including 3/4 tons. The 75-110 is a “tweener” oil that is practically irrelevant and the heavier oil is completely unnecessary for most applications.
    Incidentally, I also asked about the Toyota spec 75w-85 spec oil and they said it was mostly to be different… but that there is zero issue with using a good 75w90.
  6. Apr 21, 2023 at 7:38 PM
    #186
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did you do an engine flush before you switched to a thicker viscosity?
  7. Apr 21, 2023 at 7:45 PM
    #187
    blenton
    blenton New Member
    I had the exact same experience. After my first 5k service, I got home and popped the hood to discover the oil hadn’t been changed, so I turned right around and marched in to the dealership to show them what they forgot to do. They simply told me no. I asked them if they would change it now instead of 10k. They said no again. I adamantly pressed them to change it at 5k reminding them that I tow and haul, and according to the service manual it was due for a change. They said no again, because I wasn’t towing down a dusty dirt road ALL day EVERY day it didn’t count. So I asked to for the oil and filter to do it myself. They said no. I asked if I could buy the oil and filter to do it myself and they said technically yes, but insinuated that if I wanted to keep my warranty intact I had to follow “Toyota’s” schedule.
    But as soon as Toyota care ran out, they slapped a 5k OCI sticker on my truck. When I inquired about what the hey when they wouldn’t change it at 5k earlier, they simply replied “oh, yes we would have done that not problem.” Eehhhhhhhggghgghhgg….
    JLS in WA and NoMoreGreen like this.
  8. Apr 22, 2023 at 1:38 AM
    #188
    AZBoatHauler
    So.Arizona
    No - just drained it.
  9. Apr 22, 2023 at 5:36 AM
    #189
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Its for mileage. I've seen a far far greater uplift in mpg changing the gear oil back from 75w-90 to 75w-85 than any difference between 0w-20 vs 5w-30 engine oil. As long as the film strength is sufficient for the application the thinner oil will run cooler as well.
    omgboost likes this.
  10. Apr 23, 2023 at 5:50 PM
    #190
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    I really need to change my differential and transfer case fluids..... I just don't have the time. I may just bring it to the dealer. 80K miles...... No towing or abuse, mostly normal driving and highway.
  11. Apr 29, 2023 at 2:06 PM
    #191
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    On sale again at Costco
    JLS in WA likes this.
  12. Apr 29, 2023 at 3:56 PM
    #192
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    I used 75w-140 in the rear of my Tundra (I tow a lot) and the MPG loss is negligible (unladen). If I told you guys what motor oil I run you'd lose your minds LOL.
    Mike59 and Leo's first like this.
  13. May 19, 2023 at 11:45 AM
    #193
    Wallygator
    The craziest part of your story to me is that after the "no, no, no" incident, you actually went back to that dealer.
    Mike59 likes this.
  14. May 19, 2023 at 2:16 PM
    #194
    blenton
    blenton New Member
    I purchased an extended warranty and maintenance plan with the vehicle when I bought it new; I was told I had to have service records in case of a claim so it made sense to pay for the service. Not saying that is true, but that’s what they told me so I did my due diligence. Until it was due for a diffs and t-case and they told me service plan didn’t cover that (despite it being listed in the manual that I showed the finance manager and asked specifically about before purchasing the vehicle or plans). No, I don’t like that dealership. But its the one in town.
    Wallygator[QUOTED] likes this.
  15. May 19, 2023 at 2:27 PM
    #195
    Wallygator
    Sorry that it's the only one in town, that sucks.
  16. May 19, 2023 at 3:26 PM
    #196
    Bergmen
    Bergmen New Member
    Ukiah, California
    I've watched several of this guy's videos and I have respect for his experience. I don't see any substantiation of his claim that piston rings have less tension against the cylinder walls. This may be true but he needs to back this up with data, otherwise I chalk this up to opinion.
    Mike59 likes this.
  17. May 25, 2023 at 7:44 AM
    #197
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    Why did I read this whole thread? My head hurts. I'm going to bed now. I'll probably dream about OCI's.
