General Supercharger Thread
  1. Apr 17, 2023 at 1:03 PM
    #7771
    AZTundra
    Paul
    Phoenix, AZ
    No call back yet, but I sent their shop manager a text. I'm guessing since they are normally swapping the stock injectors for the green ones during their supercharger installs it likely appeared that I was going backwards in injector size since the FiveO's resemble the stock injector. That's probably what threw them for a loop.
  2. Apr 17, 2023 at 1:24 PM
    #7772
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    My Five-O's wern't Orange though...they were stock color, Tan
  3. Apr 17, 2023 at 1:26 PM
    #7773
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Mine too.
  4. Apr 17, 2023 at 1:30 PM
    #7774
    AZTundra
    Paul
    Phoenix, AZ
    Maybe the lighting? I'm pretty sure mine were tan as well when I opened the box. Don't get me all paranoid now...
    Edit. Here is a picture saved on my phone.
  5. Apr 17, 2023 at 1:55 PM
    #7775
    M3Tundra-JK
    Scott
    2005 GX470
    ok ya, I just wanted to make sure!
    AZTundra[QUOTED] likes this.
  6. Apr 17, 2023 at 3:20 PM
    #7776
    AZTundra
    Paul
    Phoenix, AZ
    Ok guys, a few questions for you...
    So I just got a call and they went over a few things with me. They do not want to install the Walbro 450 based off their research and prior builds. I was told that it was highly recommended that a fuel pressure regulator be used with that pump and also upgrading the output and return lines which is a little outside their wheelhouse. They don't want any liability issues w/o doing those additional items, but again that is not something that they handle so they don't want to swap the pump only. They said to keep the stock flex fuel pump in place, but they will install the 750cc injectors and replace the coupler and swap the smaller pulley on. Will this cause me any issues? They recommended Dyno Comp to install the fuel pump and any additional required items for that. They also said that the AFR gauge they wanted to pass on because the whole header needed to come off to install the bung in the correct location.
    So I guess my question is how screwed will I be if they keep the flex fuel pump in place and I used the 750 injectors and smaller pulley? @snivilous is it okay to still flash my 750 tune? I assume the tune is still needed due to the larger injectors, but wondering if I'll be running out of fuel with my current pump. Is it okay to keep like that and then see if Dyno Comp can do my fuel pump and gauge at a later date? I hope I'll be okay as long as I don't run WOT?
    Edit: Just to add, their tech talked to Jeff who was pushing 700hp on his Tundra and was still running the flex fuel pump w/o issues for what it's worth.
    HulkSmurf14 and Fastlane47 like this.
  7. Apr 17, 2023 at 3:29 PM
    #7777
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    I can tell you I ran out of fuel with the stock Magnuson pump with a 2.45 pulley, I installed the 450 pump only and all was good.
    AZTundra likes this.
  8. Apr 17, 2023 at 3:32 PM
    #7778
    AZTundra
    Paul
    Phoenix, AZ
    Regular or flex fuel pump? Did you also run the hardwire kit or just drop the pump in place?
  9. Apr 17, 2023 at 3:34 PM
    #7779
    Fastlane47
    Maryland
    2018 Platinum
    Regular, I dropped the pump in, needed a few adjustments, I also ran a inline filter.
    HulkSmurf14 and AZTundra like this.
  10. Apr 17, 2023 at 3:55 PM
    #7780
    e30cabrio
    There is a pipe between the header and catback that the place I had the bung installed by r&r'd in under 15 minutes.
    Also, the flex pump looks like the 450.
    AZTundra, Fastlane47 and HulkSmurf14 like this.
  11. Apr 17, 2023 at 3:56 PM
    #7781
    Fastlane47
    Maryland
    2018 Platinum
    Yes, the mid pipe is easy to remove and install the bung.
    reywcms likes this.
  12. Apr 17, 2023 at 3:59 PM
    #7782
    AZTundra
    Paul
    Phoenix, AZ
    Yeah, I recall seeing your picture. I was thinking of showing that to them and see if I can get the ball rolling again on that piece at least. Maybe I can get them to drop the Walbro 450 in as just a pump replacement and utilize the factory wiring for now? I know that's not what they want to do, but maybe I can sign a waiver or something...I'm thinking the Walbro 450 on stock wiring is better than keeping the stock flex fuel pump at this point.
    Black@Blue19, reywcms and Fastlane47 like this.
  13. Apr 17, 2023 at 4:45 PM
    #7783
    Vizsla
    Vizsla 2 = 2.5
    Don’t be surprised shops don’t want to install that pump, if you haven’t, read back a bit and see the customer support @e30cabrio received. It’s solid advice, way better for reliability and troubleshooting/servicing if the stock pump is fine…, don’t doubt Jeff but:notsure:. Need a fuel pressure gauge regardless with fuel system mods, might be good place to start. Just take it somewhere else for the AFR gauge.
  14. Apr 17, 2023 at 5:14 PM
    #7784
    Fastlane47
    Maryland
    2018 Platinum
    M3Tundra-JK and reywcms like this.
  15. Apr 17, 2023 at 5:18 PM
    #7785
    e30cabrio
    After the bung was installed, installing the PSB-1 was easy.
    AZTundra and HulkSmurf14 like this.
  16. Apr 17, 2023 at 5:38 PM
    #7786
    AZTundra
    Paul
    Phoenix, AZ
    I'm going to give it another shot with them tomorrow. I need to swing by late morning and flash the new tune for the 750 injectors. I'll show them the mid pipe and placement I'd like (copying your picture) and see if that changes anything. Also, if they will reconsider just dropping the pump in w/o the hardwire kit. I think I'd feel better taking that route than nothing at all. Whatever doesn't get installed I'll follow up with Dyno Comp to see if they will handle.
  17. Apr 17, 2023 at 6:05 PM
    #7787
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    o2 trickers for the headers came in today. Larger than I thought!!
  18. Apr 17, 2023 at 6:12 PM
    #7788
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    It’s crazy to me that to this day no one can quote the actual flow rating of the stock FFV pump. I have read it’s “over 255lph” and that it’s a lower output version of the Ti/Walbro 450 pump.
  19. Apr 17, 2023 at 6:16 PM
    #7789
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    That’s huge! So that just screws in and you add those the valves
  20. Apr 17, 2023 at 6:19 PM
    #7790
    e30cabrio
    They look identical.
    reywcms and AZTundra like this.
  21. Apr 17, 2023 at 6:20 PM
    #7791
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Yeah, there's three different sizes of restrictor rings that come with each defouler. Figured for $25 ea, I'd go this route. Will keep posted of course on how it goes, but the guy doing my exhaust said he's used them on a lot of Tundras with no issues.
    M3Tundra-JK and reywcms[QUOTED] like this.
  22. Apr 17, 2023 at 6:41 PM
    #7792
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Sweet! I’ve been wanting to remove the secondary cats.
  23. Apr 17, 2023 at 6:45 PM
    #7793
    Silver17
    Eastern PA
    You already can remove those and not get codes, since they located after the secondary O2s. Been thinking about it myself to keep them for if my primary cats blow out, then I can have those welded in their place and not have them destroyed by the failing primaries.
  24. Apr 17, 2023 at 7:21 PM
    #7794
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Silver17[QUOTED] likes this.
  25. Apr 17, 2023 at 7:24 PM
    #7795
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Even better! Whelp add it to the list lol
    Silver17[QUOTED] and HulkSmurf14 like this.
  26. Apr 18, 2023 at 7:37 AM
    #7796
    M3Tundra-JK
    Scott
    2005 GX470
    The stock pump that came out of my 21 also looked the same
  27. Apr 18, 2023 at 7:39 AM
    #7797
    M3Tundra-JK
    Scott
    2005 GX470
    Don't start that truck in the garage, it's gonna be a stinker! The tacoma smelled like rotten eggs after I went catless. I added the secondary cats back on not too long after.
    reywcms[QUOTED] likes this.
  28. Apr 18, 2023 at 7:42 AM
    #7798
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    My 2014 is a FFV. When I installed my Harrop with the stock injectors and was having a problem tuning it to be rich enough at Stage 1, I spoke to Chris at Harrop about it. He did not recommend installing the DW pump that came with the kit as he told me the DW was smaller than the factory FFV pump. I went with the 650 injectors and the Stage 2 80mm pulley and have had zero issues. Tuned at 10-10.5 AFR at WOT. Made 512 rwhp on a conservative tune.
  29. Apr 18, 2023 at 7:48 AM
    #7799
    Bluecobra
    2014 Tundra
    Must have been your Tacoma. My Tundra has been catless since the SC install and it doesn't smell. Maybe from behind me if I am into the throttle but when i pull it into the garage, no smell. The rotten egg smell is usually from the cats.
  30. Apr 18, 2023 at 8:04 AM
    #7800
    ZPhilip
    Philip
    West Chester, PA
    My catless 350Z stunk! Don’t miss that smell at all.
