General Supercharger Thread
  1. Apr 14, 2023 at 11:18 AM
    #7621
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    From Tuner on crank issue:
    I don't really have a lot to add as I have no idea how they're setting up their fuel and airflow models, what data they're using, how precise they're being with the edits they making, if there are external variables at play (burst fuel lines for example ;) ) or if the injector data they are using is even accurate.
    I don't generally see any problems with extended start on larger injectors unless there's a check valve problem or other fuel delivery system problem/airflow modeling issue. Sometimes you can get a hint of extended crank time when you're using very large injectors (~2x factory size) where the stock ECU just simply has a hard time controlling these at such small Inj PW's. The fuel delivery will just not be as precise or consistent with really low Inj PW's and you'll see a bit more oscillation in the fueling/trims when this is a "thing".
  2. Apr 14, 2023 at 11:33 AM
    #7622
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sounds logical, and I suspect that we've kind of suspected that it may be something of that nature. It's reassuring that we seemed to have the right suspicions. I can understand where at my elevation it would be even more difficult trying to get a precise/consistent start mixture with such an oversized injector, not to mention the great number of variables in the many components involved. It will be interesting to see if it lessens when I eventually take a drive to a lower elevation. It's not the answer that dreams are made of, but it's still better than a poke in the eye with a sharp stick.
    Thanks for relaying their reply.
  3. Apr 14, 2023 at 11:45 AM
    #7623
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I quick dashed over to their site and read all replies. Something I noticed is that most respondents appeared to assume that there was a fuel shortage aspect to what what being experienced. At least in my observations, with the black exhaust, it's look to be too much fuel. With that side note, a lack of precise PW control would still seem an applicable hypothesis.
    Also, what is being described when "fuel/airflow models" are being mentioned?
    Silver17 likes this.
  4. Apr 14, 2023 at 1:43 PM
    #7624
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Anyone have a pic of a single radium and maggy? Looking to confirm the line routing.
  5. Apr 14, 2023 at 1:54 PM
    #7625
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    If you could document the can as it sits in your truck now for me I'd appreciate it!
  6. Apr 14, 2023 at 1:57 PM
    #7626
    AZTundra
    Paul
    Phoenix, AZ
    I can get you one next week... :(
  7. Apr 14, 2023 at 2:04 PM
    #7627
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Are you referring to the catch cans? If so, the green connection on the engine goes to the top of the catch can, and the bottom goes back to the Maggy.
  8. Apr 14, 2023 at 2:04 PM
    #7628
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  9. Apr 14, 2023 at 2:05 PM
    #7629
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Hey not a peep out of you until we see those dyno results. :boink:
  10. Apr 14, 2023 at 2:05 PM
    #7630
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea, I'd like a full pic has I think I'll need to add some fittings from the previous setup
  11. Apr 14, 2023 at 2:11 PM
    #7631
    AZTundra
    Paul
    Phoenix, AZ
    Truck update. So, my install was delayed due to their lead tech being out sick for a couple days. Got a call today that he's back, but just finished up the Jeep that was scheduled to be completed before mine was started. My truck won't be started until Monday which is a bummer, but things happen and I understand. They are covering the cost of my rental from Enterprise for this week and Jeff let me take home his Yukon until my truck is completed.
    Since the Cravenspeed gauge pod arrived on Wednesday I was able to drop that off when swapping vehicles so they will now be able to mount the gauge as opposed to just resting it on the steering column until I moved it into the pod. They listened to the slight squealing issue I had which was posted in another thread...Toyota replaced the belt tensioner and the fan bracket, but the noise was still there. Westcott believes it's coming from the supercharger idler which is good news since I had already picked one up to have them replace while the belt was off. Sounds like they are planning to have it wrapped up by end of day Wednesday or Thursday morning.
    The Yukon is a beast compared to the Nissan Altima rental I've been using this week. Going to check it out more this weekend when I have time, but it's lifted on 35's I believe with their roof rack and rear tire carrier.
    Fastlane47, M3Tundra-JK and Wynnded like this.
  12. Apr 14, 2023 at 2:15 PM
    #7632
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I have the Harrop, but from the Radium catch can it connects to the connection marked by the red arrow:
    M3Tundra-JK and reywcms[QUOTED] like this.
  13. Apr 14, 2023 at 4:15 PM
    #7633
    e30cabrio
    Just got done!
  14. Apr 14, 2023 at 4:16 PM
    #7634
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    We will be starting the PS fuel system in my truck Monday morning. I will be setting the FPR to 60psi as they recommend in the instructions. I have 750 injectors and a 450 fuel pump, luckily no extended crank issues.
  15. Apr 14, 2023 at 4:27 PM
    #7635
    Saltyhero13
    Saltyhero13 Throbbing Member
    Nice numbers!
  16. Apr 14, 2023 at 4:29 PM
    #7636
    Fastlane47
    Maryland
    2018 Platinum
    How was the a/f?
    Saltyhero13 likes this.
  17. Apr 14, 2023 at 4:56 PM
    #7637
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    How was the drive home?
  18. Apr 14, 2023 at 4:58 PM
    #7638
    M3Tundra-JK
    Scott
    2005 GX470
    Nice!! I'm jealous
  19. Apr 14, 2023 at 5:11 PM
    #7639
    Silver17
    Eastern PA
    Hot damn, that 574lbft at 2500 rpm. Tires don’t stand a chance!
  20. Apr 14, 2023 at 5:11 PM
    #7640
    e30cabrio
    Afr is 10-11. He said the belt was slipping. It could have been higher
  21. Apr 14, 2023 at 5:15 PM
    #7641
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    How is that determined, does it polish the ribbed side, or leave a bunch of belt dust? I wouldn't guess it would be audible with all the other noise going on.
  22. Apr 14, 2023 at 5:47 PM
    #7642
    e30cabrio
    The boost graph showed as wavy at wot. He said it meant it was slipping. :dunno:
  23. Apr 14, 2023 at 6:06 PM
    #7643
    e30cabrio
    I asked for the graph.
  24. Apr 14, 2023 at 6:59 PM
    #7644
    AZTundra
    Paul
    Phoenix, AZ
    Did you ever give installing the green belt another try? Wondering if that may help with the slip if you are still running the stock size belt.
    Fastlane47 likes this.
  25. Apr 14, 2023 at 7:11 PM
    #7645
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You now own a thoroughbred! Wow! Impressive numbers as stated!!
  26. Apr 14, 2023 at 7:11 PM
    #7646
    e30cabrio
    Nope, guess it needs to go on when I install the 2.2.
  27. Apr 14, 2023 at 7:13 PM
    #7647
    HulkSmurf14
    2014 Tundra Limited
  28. Apr 14, 2023 at 7:14 PM
    #7648
    AZTundra
    Paul
    Phoenix, AZ
    Curious if there will be another dyno run after the 2.2 is installed.
    snivilous[OP] and Saltyhero13 like this.
  29. Apr 14, 2023 at 7:44 PM
    #7649
    snivilous
    SW UT
    300k+ Supercharged 2008
    I've been planning on designing a bracket or something to add an additional idler pulley to increase the belt wrap and allow more belt options for the smaller pulleys. Sounds like I need to get on that sooner rather than later.
  30. Apr 14, 2023 at 7:50 PM
    #7650
    e30cabrio
    He said I can go 2.2 no problem. We'll see. The pulley is still "out for delivery by 7pm" except it's 7:50.
    Lol
