General Supercharger Thread
  1. Apr 11, 2023 at 11:01 AM
    #7501
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Just for reference, I had posted how mine was wired in the past. The gauge itself doesn’t use much current, but the O2 sensor has a little heater that draws a little more power. It’s more for the safety of if a short occurred for me. https://www.tundras.com/threads/general-supercharger-thread.85513/page-180#post-3068417
  2. Apr 11, 2023 at 2:40 PM
    #7502
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I did not wire in the relay and it still works. I think I read somewhere a heated O2 sensor only needs like 3-5 amps.
    e30cabrio and AZTundra[QUOTED] like this.
  3. Apr 11, 2023 at 3:41 PM
    #7503
    AZTundra
    Paul
    Phoenix, AZ
    I did call Innovate this afternoon to talk to their tech support. He pulled up the specs and looked at the manual and said for my case, just powering up the gauge for AFR/Boost readings the relay wouldn't be required. If connecting to a boost controller solenoid for the Power Safe functions then he said it would be needed. So I think I'm just going to leave it as-is and let Westcott install it how they see fit.
  4. Apr 11, 2023 at 4:52 PM
    #7504
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I like that as I am not using the relay.
    lol
    AZTundra[QUOTED] likes this.
  5. Apr 11, 2023 at 5:06 PM
    #7505
    AZTundra
    Paul
    Phoenix, AZ
    Are you all dialed in now and just waiting for the dyno/tuning again?
    e30cabrio[QUOTED] likes this.
  6. Apr 11, 2023 at 5:08 PM
    #7506
    e30cabrio
    I'm hoping. It's been 2 full days excitement free.
    Assuming it stays this way, Friday at 3 is dynothyme!
  7. Apr 12, 2023 at 7:42 AM
    #7507
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Got the truck on the schedule for estimate and repairs, finally. But it's getting traded in as soon as it's fixed.
    Looking at getting into a Lexus. Really just need room for me and a dog or two. Wondering if there's anything suitable for boosting in wagon/hatchback/small suv category? I know all of the new models have the small engine and turbo, but anything in the V6 range that can get s/c or turbo'd?
    Still looking for RCSB 4x4 5.7l project also. Want to do an AWD conversion on it for a little rally/street style truck
    nags, Saltyhero13, Silver17 and 4 others like this.
  8. Apr 12, 2023 at 11:31 AM
    #7508
    e30cabrio
    These came, don't remember what the adapter is for. lol
  9. Apr 12, 2023 at 11:33 AM
    #7509
    mista_g
    mista_g New Member
    2016 Quicksand TRD Pro
    Lots of pages here fellas, so sorry if this has been answered, which 99.9% sure it has been. California fellas, what Tune does the Magnuson come with? My Tacoma came with the Bullydog, which I quickly switched over to an HPTuner from a tune from a TW member. Pretty sure I read HPtuners have something for Tundras now, may have read Magnuson uses them now but I am not 100% sure.
    These were my upgrades on my Tacoma: quickhub change for the pulley with a 2.8 (haven't read much about Tundra pulley size yet), CSF radiator, Deatschwerks Fuel pump, and then a catch can. I'm not sure I want to mess with a smaller pulley right out the gates, cutting back the snout was annoying on the Tacoma. But would all the others:radiator, fuel pump, catch can, be suitable enough and I could call it a day? Obviously get a good tune as well.
    Thanks for the help and sorry for not reading :eek2:
  10. Apr 12, 2023 at 11:33 AM
    #7510
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Converts fittings on top of fuel basket to -6AN, need one for feed, one for return if replacing the lines both ways.
  11. Apr 12, 2023 at 1:57 PM
    #7511
    M3Tundra-JK
    Scott
    2005 GX470
    So my new top option, I think, is a Lexus LX570. The overall dimensions of the 2008-2015 are considerably smaller than the crewmax, over 2.5ft shorter in length! I should also be able to swap over the current supercharger, and 22" TRD Forged wheels. Idk about the sway bars, and definitely not the lowering kit.
    nags, Saltyhero13 and e30cabrio like this.
  12. Apr 12, 2023 at 1:59 PM
    #7512
    e30cabrio
    I have your Longtiubes!
  13. Apr 12, 2023 at 2:03 PM
    #7513
    M3Tundra-JK
    Scott
    2005 GX470
    Welcome! I'm scootter82 over on Tacomaworld, active in their s/c thread. I think you pretty much got it all right. A lot of the general knowledge from the Taco s/c transfers over here. Just a lot of differences in the engine itself, obviously lol
  14. Apr 12, 2023 at 2:12 PM
    #7514
    snivilous
    SW UT
    300k+ Supercharged 2008
    Yes HPT supports Tundras, that or one of the other software is definitely the way to go and while the stock Magnuson tune works there is a lot of improvements that can be made with a custom tune.
    The Tundra does NOT require any modification of the supercharger to install a smaller pulley. Though you most likely will need to pull the snout so you can remove/install a different pulley (I'm sure the taco is the same), but the snout itself requires no changes for any of the pulley options on the market, you just get a smaller serpentine belt.
    The radiator is overkill imo, most of the supercharger kits come with a fuel pump and if you want you can upgrade that. The Magnuson and I think the "stage 2" Harrop come with fuel pumps. Catch can is great, not needed. A lot of us have the radium single catch can. If you get the Magnuson it comes with larger injectors, the other kits do not but imo the other kits do need them even in stock form so keep that in mind. Injectors will require a different tune but otherwise are plug and play, the Magnuson tune is calibrated for the injectors they include which are 535cc, stock is around 400cc.
    You more than covered what you need. The Magnuson kit is the most comprehensive, though the other kits may be more efficient, powerful, or cheaper---those are the Harrop and the Whipple. Another modification people do but is not required is a larger intake (the Magnuson comes with it and is the common upgrade for the other superchargers).
  15. Apr 12, 2023 at 2:29 PM
    #7515
    mista_g
    mista_g New Member
    Appreciate the info. Good to know about the Fuel Pump (saw it listed in the parts list for Magnuson) and Radiator. I'll probably be going Magnuson as I know a dealer who can get me some % off.
    e30cabrio and HulkSmurf14 like this.
  16. Apr 12, 2023 at 3:16 PM
    #7516
    Silver17
    Eastern PA
    I’d say Whipple has the best value bang for the buck in what you get for the price, especially for fuel upgrades. Only the intake is lacking, which you can buy the Maggie one for $300ish. Magnuson kit as it comes is suitable for the provided pulley as far as fuel upgrades. The provided pump and injectors are insufficient for a smaller pulley though, so then you’re buying them anyway later. See this earlier post for a little more info as far as ideal upgrades for each kit. https://www.tundras.com/threads/general-supercharger-thread.85513/page-201#post-3102708
    mista_g[QUOTED] likes this.
  17. Apr 12, 2023 at 4:51 PM
    #7517
    e30cabrio
    Welcome, the guys here know what they are talking about and are super helpful. Good luck!
  18. Apr 12, 2023 at 5:44 PM
    #7518
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Whelp my maggy is sold just waiting for the funds to arrive next week and I'll order the Whipple and smaller pulley lol.
  19. Apr 12, 2023 at 6:07 PM
    #7519
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Heheheehehe I'm excited for you! :bikewhoops:
  20. Apr 12, 2023 at 6:21 PM
    #7520
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    If anyone’s in need of a 340lph pump and 650cc’s those will be available since I’ll be getting 750s.
  21. Apr 12, 2023 at 6:22 PM
    #7521
    HulkSmurf14
    2014 Tundra Limited
    Me me me!!
    reywcms likes this.
  22. Apr 12, 2023 at 6:22 PM
    #7522
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Boom!
    HulkSmurf14[QUOTED] likes this.
  23. Apr 12, 2023 at 6:39 PM
    #7523
    nchlsbr
    nchlsbr New Member
    2018 Tundra
    Just ordered a couple days ago from Deatschwerks. Would’ve scooped them up
  24. Apr 12, 2023 at 7:02 PM
    #7524
    M3Tundra-JK
    Scott
    2005 GX470
    Hey man, I'm thinking about downgrading the 750's for 650's if I get LX570. Won't be going as balls to the walls on that one.
    reywcms[QUOTED] likes this.
  25. Apr 12, 2023 at 7:16 PM
    #7525
    Silver17
    Eastern PA
    @Fastlane47’s issues got me thinking more about this pressure/flow situation your previously described. Sniv are you still running the stock FPR non-boost referenced? If so, you’re flowing less fuel per duty cycle percentage with your larger pump and 715cc injectors than I am with my 650s and 340LPH pump using a boost referenced FPR. Since the boost pressure effectively lowers your fuel pressure the same amount of PSI of boost you’re pushing. If you boost referenced yours, your duty cycle would probably drop majorly (like down to 80% at your lower elevation). With this in mind, at 95% duty cycle at a true 33psi on 715cc injectors you’re only looking at 626cc x 8 x 95% duty cycle comes out to 285lph at max even at your lower elevation.
    In my scenario I’m using 650s (at a true 650cc due to being boost referenced) at 85% duty which is actually flowing 265lph at max. Just food for thought, and shows how the pressure you run at is a huge factor to consider, and I believe this further supports that oversized fuel system components aren’t quite as necessary if your are running a higher pressure and using boost reference. Gotta get to bed, so won’t see replies until tomorrow but let me know your thoughts!
  26. Apr 12, 2023 at 7:20 PM
    #7526
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    @HulkSmurf14 claimed them but if that falls through we can work it out
  27. Apr 12, 2023 at 7:30 PM
    #7527
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    @e30cabrio the Prospeed catch can will be coming off sooner than the blower if you’re still interested
    HulkSmurf14, AZTundra and e30cabrio like this.
  28. Apr 12, 2023 at 7:31 PM
    #7528
    e30cabrio
    Yes please!
  29. Apr 12, 2023 at 8:14 PM
    #7529
    snivilous
    SW UT
    Completely agree! That's not something I had considered before, my injectors effectively get smaller as boost increases, the exact opposite of what you'd want.
  30. Apr 12, 2023 at 8:22 PM
    #7530
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Anyone know of any offroad/non cat headers that aren't back ordered/made to order? Thinking of going either Kooks or SW. Camping season is happening soon and I'm trying to avoid waiting a month or two for headers!
