Torque Specs
Discussion in '1st Gen Tundras (2000-2006)' started by TX-TRD1stGEN, Sep 20, 2019.
  1. Sep 20, 2019 at 2:05 PM
    TX-TRD1stGEN
    TX-TRD1stGEN [OP] Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Made some tables for torque Specs 2000-2003. Enjoy
  2. Sep 20, 2019 at 2:05 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
  3. Sep 20, 2019 at 2:26 PM
    This is much better than the one I made. Well done.
    @Pinay can you add this one to the 1st gen info dump at some point. No rush.
    Tundra2, deke1691, bmf4069 and 2 others like this.
  4. Nov 3, 2019 at 3:31 PM
    Shit stain
    Shit stain New Member
    Shit stain
    2000 Drk Green Tundra 4x4 slightly used TRD
    Front Bumper
    Really good chart .BEST I'VE SEEN
  5. Nov 3, 2019 at 3:43 PM
    Shit Stain? Wow...
  6. Nov 3, 2019 at 3:57 PM
    wakeboarder
    wakeboarder New Member
    13 Tundra
    Really shitty username. SHITTIEST I’VE SEEN
    :poking::crapstorm:
    BroHon, G_unit3000, Tundra2 and 4 others like this.
  7. Jun 7, 2020 at 10:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Anyone got the bed bolt torque specs?
    Access cab. The six T55?
  8. Jul 19, 2020 at 9:25 AM
    @TX-TRD1stGEN
    Is "center bolt" for the pivot bolt on the upper control arm? Trying to find the torque spec.
  9. Jul 19, 2020 at 9:29 AM
    It seems like it would be the center bolt, I was also thinking it could be the 72 , upper suspension arm to chassis frame
    TX-TRD1stGEN[OP] likes this.
  10. Jul 19, 2020 at 9:31 AM
  11. Jul 19, 2020 at 9:36 AM
    Thanks. Torque from bolt or nut? Or whichever I can fit? From memory, torque wrench only fits on one side.
  12. Jul 19, 2020 at 9:38 AM
    I think your always supposed to torque from the nut side, but I also think your right about only being able to fit on one side, that’s how the 4runner is. Besides a crows foot, just guesstimate, just get her tight, maybe check on it in a week
  13. Mar 24, 2021 at 6:27 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    One of my passengers side seat x body bolts have worked loose. Figured I'd share my findings here.
    Neo likes this.
  14. Apr 17, 2021 at 11:10 AM
    G500XL
    G500XL New Member
    SA, Tx
    Sliver 05DC 2wd
    Thanks this is very helpful!
    I’m guess these also go Thur 2006 too?
  15. Oct 10, 2021 at 12:22 PM
    Jcross0304
    Jcross0304 New Member
    Johnathan
    2006 Tundra SR5 DC 4wd
    Did you find out if they are good for 06 also?
  16. Nov 1, 2021 at 12:10 PM
    G500XL
    G500XL New Member
    SA, Tx
    Sliver 05DC 2wd
    Yes, it works for my 2005 based on the FSM.
  17. Apr 12, 2023 at 3:02 AM
    Serge928
    Serge928 New Member
    Serge
    2005 Grey Double Access 4wd SR5 4.7L
    did you ever find out torque for the bed bolts? I’m looking to replace a few of them. Thanks
  18. Apr 12, 2023 at 4:09 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    This should be a sticky.
  19. Apr 12, 2023 at 4:19 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    No, I didn't find anything first gen specific. I used the 2nd gen torque spec of I think 85 ft.lbs?
  20. Apr 12, 2023 at 5:32 AM
    Best I can do is drop it in the 'so you just bought a 1GT eh?' sticky thread along with links to all the other important/pertinent docs I could find. So, if you ever need it, just open that sticky thread and it's right near the top.
    Serge928 likes this.
  21. Apr 12, 2023 at 5:43 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    According to the 00-03 Safety Recall (Special Service Campaign) – 90M and the 04-06 Limited Service Campaign(LSC) D0D, both mention 63ft/lb when re-installing the bed. They both use 90467-13076 for the bolts if needed.
    00-03....Microsoft Word - 90M Dealer Letter Final 5.doc (carmd.com)
    04-06....MC-10131878-9999.pdf (nhtsa.gov)
    Serge928[QUOTED] and Tundra2 like this.
  22. Apr 12, 2023 at 5:47 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    shifty` and Tundra2 like this.
  23. Oct 9, 2023 at 4:42 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Little more i didn't find on here for 2005-2006.
    shifty` and FrenchToasty like this.
  24. Oct 13, 2023 at 12:44 PM
    These will show a broader view of the stuff on the front-end for the '05-'06 in case anyone needs it.
    Note the legend in the bottom left corner so you don't over-torque anything:
  25. Dec 25, 2023 at 7:31 PM
    Neo
    Neo New Member
    Alabama
    I'm about to replace the broken driver side seat belt buckle in my brother's 2002 Tundra Limited Access Cab. This thread lists the torque specs for the seat mounting bolts. (Thanks, @Tundra2 !) Is there one for the bolt that holds the buckle to the seat? I downloaded the 2000-2003 Tundra FSM, but didn't see it there. I also ran a search of the 1st Gen Forum and it was not readily apparent.
  26. Dec 25, 2023 at 7:42 PM
    Huh. I swore we talked about this pretty recently and decided almost anything seat belt related was 42Nm. The 2000-2003 FSM seems to indicate that in the specifications section.
  27. Dec 25, 2023 at 8:15 PM
    Neo
    Neo New Member
    Alabama
    Okay, so apparently I didn't know the correct term. I was searching the documents and forum for "buckle". (Couldn't find the facepalm emoji.)
  28. Dec 31, 2024 at 1:44 PM
    mattmf01
    mattmf01 New Member
    matt
    2021 TSS Tundra
    Non yet
    Would be nice to see one for the 2.5 gen; the non 4x4 non TRD SR5s. Anyone out there have these?
  29. Dec 31, 2024 at 2:12 PM
    The 2.5 gens would need to come together and produce it.
    THIS! IS! FIRST GEN!!!
    (Insert Leonidas meme here)
    BroHon and Elevatorguy like this.
  30. Dec 31, 2024 at 2:42 PM
    Hi06silver
    2006 DC 4x4 Waltrip
    HA! Are memes banned now? I used to see that one all the time.
    KNABORES[QUOTED] likes this.
