295/70/18 tire thread
Discussion in 'Wheels & Tires' started by Longtimecoming07, Sep 3, 2020.
  1. Oct 15, 2022 at 2:33 PM
    #241
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    How was the clearance in the rear of the wheel well ? I have +40 mm which is 20mm further out than stock which is just shy of an 1” so it should be pretty similar situation. I have a CBI bumper so the front isn’t a problem. Thanks!
  2. Oct 15, 2022 at 2:34 PM
    #242
    Tundra694
    AJ
  3. Oct 17, 2022 at 5:39 AM
    #243
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    You'll definitely need to remove that little mudflap and then you should have no problems. I didn't need to trim anything in the rear of the wheel well.
  4. Oct 17, 2022 at 5:42 AM
    #244
    Tundra694
    AJ
    Okay good to know. I’m good on the front because I have a CBI. My concern was the rear of the well. Thanks!
    300BLK[QUOTED] likes this.
  5. Oct 17, 2022 at 9:21 AM
    #245
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    I didn't have to do anything in the rear.. kept the rear mud flaps :thumbsup:
    Tundra694[QUOTED] likes this.
  6. Oct 26, 2022 at 6:02 AM
    #246
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    You will have no issue in the rear, rear easily fits 35inch tires stock.
  7. Oct 30, 2022 at 8:00 AM
    #247
    bigsurtundy
    bigsurtundy New Member
    Laney
    2016 TRD Off-road
    Bilstein 6112/5160
    295/70/18 Baja Boss’s on stock rims. Bilstein 6112 at top setting and 5160s in the back. 1.25 Spidertrax spacers. Absolutely love the way the tires look, dealing with the same inside fender plastic rubbing issue. 884B4B3F-CD14-4FEA-85B9-321F04190387.jpg
  8. Nov 10, 2022 at 6:28 PM
    #248
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Has anyone thought about running 33x12:50 tires before they decided on 295/70/18’s. Or were they too wide for your decision? I have chatted with some that love the 33x12:50 size.
  9. Nov 11, 2022 at 9:41 PM
    #249
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'd think that there'd be rubbing issues on the UCA from the 33x12.5 since some folks are saying that certain brands are rubbing w/just the 295s; at least with a simple leveling kit or stock PRO for example.
    Personally, I wouldn't do a 12.5 on an 18x9 wheel either. I believe that tire is too wide for 9" wheel (IMO) under normal circumstances and even more so when airing down :notsure:
  10. Nov 12, 2022 at 8:40 AM
    #250
    RusPro21
    Don
    Pa.
    I don’t think it will be issue if you are running aftermarket wheel with a more off set like SCS wheels. I just not sure if I want that fatter tire over 295. Thanks. Also with my Pro will have the westcott lift added.
  11. Apr 3, 2023 at 6:56 AM
    #251
    21cementtrail
    21cementtrail New Member
    2021 Cement Gray Tundra Trail Edition
    Any pictures? I have the same lift and thinking about running 295s.
  12. Apr 4, 2023 at 7:06 AM
    #252
    21cementtrail
    Anybody have 295 70 18 ridge grapplers on a leveled sr5?
  13. Apr 10, 2023 at 4:36 PM
    #253
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    295/70/18 Goodyear wranglers on TRD rims with 1” spacers and 2” lift. IMG_7409.jpg
  14. Apr 23, 2023 at 5:18 PM
    #254
    Max2012trd
    Max2012trd New Member
  15. Apr 23, 2023 at 5:21 PM
    #255
    Max2012trd
    295 70r18 mud tires with stock everything. 2012 trd off road 5.7 double cab. Looks amazing!!!
    Did have the trd rims...
    PS: had to trim the corners off the skid plate, that's it!!!!!
    Yes 295 70r18 fit!!!
  16. Apr 23, 2023 at 5:25 PM
    #256
    Max2012trd
    No spacers, no lift!!! Your front wheel well is where u need to worry about!! Lift ain't shit!!!
    I'm so glad I didn't follow everyone's advice on all these forums and did my own thing!!
    My truck looks mean and I have nobody on these forums to thank except myself!
  17. Apr 23, 2023 at 8:12 PM
    #257
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    :thumbsup: You should have asked me... :rofl:
  18. Apr 27, 2023 at 9:29 PM
    #258
    Jrad08tundra
    Jrad08tundra New Member
    Jared
    San Diego
    2008 sr5 crewmax
    Bilstein 5100 all around Limo tint all around Airlift airbag kit Plastidip emblems K&N intake Black housing headlights with led’s Method 305 nv 285/65/18 Yokohama at g105 Pioneer head unit with alpine type r 8” sub.
    How do you like the coopers on your sequoia?
  19. Apr 29, 2023 at 8:59 PM
    #259
    Max2012trd
    2012 trd off road. 295 70r18 mud tires. Stock everything! No problems at all!!
    Just had to trim the corners off the skid plate.
    Lift ain't gonna do shit - all about clearance in front wheel well & upper control arm.
    Didn't even have to remove the little front mud flap!
    Hbjeff and Tripleconpanna like this.
  20. May 4, 2023 at 7:42 PM
    #260
    Jrad08tundra
    Jared
    San Diego
    2008 sr5 crewmax
    IMG_0336.jpg 2008 sr5, 1500 top setting, falken wildpeak at3w 295/70/18, method 305’s.
    Minor rubbing had to take off front mudguards and push fender in drill new holes super easy. Love them so far.
    08TRDOFFROAD likes this.
  21. Jun 3, 2023 at 9:02 PM
    #261
    HoodRiverTundra
    HoodRiverTundra New Member
    Riley
    Hood River, OR
    2011 TRD Crewmax
    ICON Stage 2, Roadmaster Active Suspension, 46 Gal TransferFlow Tank, 295/70/18 WildPeaks
  22. Jun 3, 2023 at 9:44 PM
    #262
    rruff
    rruff New Member
    Strange, I thought 295/70s didn't rub the swaybar with stock wheels? Yes, I'd suggest at least 25mm offset... it's hard to find 30-40mm but that would be ideal. Or get some quality 1" or 1.25" spacers. Less offset will give you clearance issues fore and aft.
  23. Jun 3, 2023 at 11:11 PM
    #263
    RetiredTundraBC
    RetiredTundraBC New Member
    San Diego County
    2020 Cement Tundra
    Snug Top, Icons, RXT Fuel Wheels, Toyo RT Trail, Prinsu Top Rack, Iceco Fridge,MIA RTT, RCI Skids,Sliders
    295/70/18 Toyo RT Trails
    D1S7N, cran2 and Tripleconpanna like this.
  24. Jun 4, 2023 at 9:40 AM
    #264
    HoodRiverTundra
    Riley
    Hood River, OR
    2011 TRD Crewmax
    @rruff Appreciate the response, that makes sense
  25. Jun 7, 2023 at 7:21 AM
    #265
    DVCNick
    DVCNick New Member
    2011 5.7 4x4 Double Cab
    My experience so far:
    Falcon shocks set to the level setting in front
    High clearance front bumper
    No skid plate
    Icon 18x9 +25 offset
    Falken AT3w 295/70/18
    No rubbing that I can detect at this time.
    Tripleconpanna likes this.
  26. Jul 9, 2023 at 1:21 PM
    #266
    Just went from 285/70/18's to 295/70/18's. What are you guys running for pressure and does it take a little while for the mpgs to level out after changing tire sizes?
  27. Jul 9, 2023 at 1:30 PM
    #267
    rruff
    rruff New Member
    You went from 285/75r18 to 295/70r18? What tires?
    MPGs to "level out"... I'm not sure what that means but I'm pretty sure the answer is no.
    I run my 325/65r18s at 38psi front and 32 rear. That's a little more than necessary, so that's probably ballpark for 295s.
  28. Jul 9, 2023 at 1:36 PM
    #268
    Edited the post. I went from 285/70 Ridge Grapplers to the 295/70's Ridge Grapplers.
  29. Jul 9, 2023 at 2:13 PM
    #269
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I went from stock 255 to 295. My gas mileage instantly plumeted and leveled out.
    rruff[QUOTED] likes this.
  30. Sep 21, 2023 at 4:46 PM
    #270
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    295/70r18 Toyo RT Trail, Bilstein 6112's at 1.9", no trimming, no wheel spacers, and no rubbing.
