2023 tundra aligment
Discussion in '3rd Gen Tundras (2022+)' started by hui894960887, Apr 8, 2023.
  1. Apr 8, 2023 at 4:19 PM
    hui894960887
    hui894960887 [OP] New Member
    Roy
    2023 Tundra platinum
    Just bought my tundra .but when I pull the wheel straight.it turn to the left .anyone can help to see the numbers?
  2. Apr 8, 2023 at 7:07 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Those numbers look good.
    Perhaps try rotating the wheels and tires. And confirm the air pressure is correct.
    Also check to see if the left brake calliper is dragging. A thermal gun can measure the brake temps. If one is higher, it could be the reason for the pulling.
    hui894960887[OP] likes this.
  3. Apr 8, 2023 at 7:18 PM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    I had a very similar problem on my 2023 1794. I had to have the steering wheel about 5 deg to the left to drive straight. Took it to the dealer and they adjusted Toe-in and now it's perfect. I'm sure it came that way from the factory.
    Also note that there was a TSB just a month ago for a similar problem, where Toyota adjusted the alignment due to premature tire wear, maybe a pull to one side too. I'm glad that I waited to get this done and by chance waited long enough for that TSB to be released...thus updated alignment.
