Steering wheel swap
Discussion in '1st Gen Tundras (2000-2006)' started by Rampage7, Feb 14, 2022.
  1. Apr 13, 2022 at 11:10 PM
    #91
    daveeasa
    Ah, I understand better now, 3 different types of airbags you say, one conductor no audio, one conductor with audio, 2 conductor. That's a lot of change.
  2. Apr 13, 2022 at 11:11 PM
    #92
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    sequoias got the newer wheel first. but for a year or two they had a single plug with the newer style plug. 2003 was the updated wheel in the tundra. it had 2 connector.
  3. Apr 14, 2022 at 4:44 AM
    #93
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Due to folks installing audio controls or changing steering pad, I had wondered about that ?
    As for 2 connector airbags, according to the 05 New Features from TIS and looking at 03-05 EWD's, dual-stage SRS airbag system did not come about until 05 year model.
    That begs the question whether for looks or adding audio controls. can one install an 05 dual stage on a single stage designed year 01-04 ?
    1st Gen Tundras New Features Chronology | Toyota Tundra Forum
    from 05 SRS Airbag System New Feature....
    from 04 05 EWD, Access, Standard....DC is the same
    A17 bottom of steering wheel area....
    Balti_J likes this.
  4. Apr 14, 2022 at 5:04 AM
    #94
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    This is the clock spring for my 04 DC, single connector with steering wheel controls. When searching for cheaper prices than dealer, notice also that number is valid for Sequoia 03-04.
    2003-2004 Toyota Air Bag Clockspring 84306-0C021 | Toyota of Cool Springs vParts
    shifty` likes this.
  5. Apr 14, 2022 at 6:50 AM
    #95
    daveeasa
    How do people feel about OEM vs aftermarket on the clock spring? Given the airbag connector it’s not a good part to skimp on? But then again, it’s probably the same part from the same factory? Just discards or seconds or something?
  6. Apr 14, 2022 at 8:49 AM
    #96
    OEM, it's built to expected specs and lifetime expectancy. This is a part you're going to install and never touch again.
    Unless you're dying right now with strapped budget, why use anything except OEM in this case, knowing OEM already lasted this long so you'll likely never replace it again in this truck's lifetime, and there will never be a question in the back of your mind about compatibility?
    I would use OEM just because of all the BS "squib circuit" failure codes I've seen people post here and on other forums. Anything related to SRS, I just don't mess around with it, but if I must, I'm going with OEM, unmodified.
    My 2¢, take it or leave it.
  7. Apr 14, 2022 at 8:58 AM
    #97
    daveeasa
    My thoughts too but $20-$30 vs $250-$300 is a large jump, just wanted confirmation on the value. I set up a saved search. I found a few $120 OEM used options. I think I'll maybe wait for a harvest of my OG spring and see how it compares to the one I got for free with the dual airbag outputs. I wonder how dumb it might be to try to de-pin and re-pin the OG connector for my OG airbag somehow / some way. That seems safer to me than changing the bag to a new one and/or only plugging in one connector. If I'm able to do that with the springs I have (both of which are OEM) that might be one path forward. I realize it's airbags but it's also wire and aside from resistance there isn't a whole lot of tech in a wire.
    Just trying to formulate a plan for the smartest approach to this hodge podge of airbag/clockspring stuff to get the wheel going. I'm not gonna lie that I am a little tempted to yank all the airbag stuff entirely but that's a bit too much risk if I lend it out.
  8. Apr 14, 2022 at 9:28 AM
    #98
    Jeebus. I expected non-OEM would be more like $75-120 range for cheaper name brands like Cardone or whatever. $20-30 for some off-brand Chinesium garbage on fleaBay. What brands are you finding at $20-30? In my mind, I don't logically understand how that specific part, with the importance of its function, could possibly be manufactured for $20-30 unless it's cheap Chinesium garbage.
    Also, is this one of those cases where you can buy Denso/Aisin on RockAuto at significantly discounted pricing, sort of like our Radiators? I'd have a hard time dropping more than 9x-10x the cheap aftermarket. I can see paying 2x-5x depending on the part's function. But 9x-10x screams "something is out of whack", probably on both sides of the fence, and the "real" price should be in the middle somewhere.
  9. Apr 14, 2022 at 9:33 AM
    #99
    daveeasa
    Yeah, I'd prefer to pay about $60 for a used OEM part.
    $22 aftermarket new
    $120 used OEM
    #99
  10. Apr 14, 2022 at 9:46 AM
    #100
    Yeah I dunno. That $22 one just looks ... I dunno, sketch. Last thing I need is an airbag to the face. If that were to happen, who you gonna sue? Seller liweizhuo37028 with zero feedback on fleaBay? I bet that account is gone or inactive within 90 days. and replaced with liweizhuo37029.
    Search fleaBay for 194582739846. I might feel a little more confident buying from an established seller where there are 5 part reviews with 5 stars like that @ $70. Better yet, I'd consider seeing if they (North Park Auto Parts?) have a direct parts website. fleaBay profile says they're based out of SA TX. Maybe you can order direct, just for the peace of mind that someone legitimate will be responsible.
    daveeasa[QUOTED] likes this.
  11. Apr 14, 2022 at 10:09 AM
    #101
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I like the seller's comment on the North Park Auto listing:
    "NEW 2ND GENERATION MODEL!! No longer malfunctions when exposed to high levels of heat from interior during hot weather conditions!!"
    shifty`[QUOTED] likes this.
  12. Apr 14, 2022 at 10:40 AM
    #102
    And that's the exact kind of stuff I'd expect from a sub-$120 part.
    Granted, there's no guarantee buying used you're actually going to get OEM unless you can visually inspect the part being shipped, either.
    But yeah. I'm guessing that $22 part is going to have lots of little issues like this. "Good enough, but likely to have issues".
  13. Apr 14, 2022 at 10:41 AM
    #103
    daveeasa
    Which is precisely why I lean towards using the clock spring I got for free which was in the vehicle with this wheel. If I can solve the airbag connector issue. That seems like the smartest path to me, despite the fact that it's also minimal cost.
  14. Apr 14, 2022 at 11:49 AM
    #104
    empty_lord
    05 rollover special
    Oh maybe I’m wrong. It’s been years since I’ve had an older tundra apart at work. It’s possible the single plug is on the 03-04 trucks
  15. Apr 27, 2022 at 9:37 AM
    #105
    daveeasa
    Hmm, doesn’t match perfectly but not too bad. I should keep hunting for a more stock look. Decent backup plan though.
    Kimosabe likes this.
  16. Apr 27, 2022 at 11:55 AM
    #106
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    @daveeasa let me know if you decide to start sourcing and selling steering wheels with audio controls. Haha
    daveeasa likes this.
  17. Apr 8, 2023 at 9:40 AM
    #107
    Northboundtundra
    Northboundtundra Northboundtundra
    1st gen v8 Tundra with manual transmission conversion
    Manual transmission and transfer case converted with lift, sliders, RTT rack, offset wheels and mud tires
    Very informative and interesting thread here. I've just gotten started with a light restoration of my 2001 AC SR5 that I have manual swapped and getting a new steering wheel for it is next on my list of items to replace. Being that this involves the airbag and so many different options makes it a little sketchy but the later model wheels seem easier to get and the audio controls would be near priceless.
    If I have the OG style setup with nothing pre-wired, can I replace the wheel, airbag, and clockspring all at once with an 05-06 style setup and drop it all in with only needing to pin the harness and run wires to HU? Or do I need to get a specific clockspring and airbag?
    Sorry if this has already been covered. You guys have done a lot research and compiled a ton of great information, it's extremally helpful so thank you in advance.
  18. Apr 8, 2023 at 9:49 AM
    #108
    daveeasa
    From what I know, since my bags are single stage, I assume yours would be as well. I think your options are:
    1. single stage bag cut for audio controls (no black option)
    2. Cut your bag cover to match profile
    3. Swap charge from your bag to new bag
    4. Swap the bag cover (drill and redo rivets)
    5. Connect only one of the two leads
    But, you need a clockspring that has the audio control wires pinned. That’s where I’m not sure at all as I haven’t started mine. That clockspring may be your existing one or maybe a new one and then it may be single stage or dual stage on the airbag connectors.
    but for the airbag itself you have some decent options.
    One thing I’d probably consider is scrapping the entire airbag setup and going to ‘05-‘06 style but I’m not sure if the ECU would reject that or how compatible it might be.
    right now I have the following parts and no time to tinker:
    dual stage clock spring should be pinned for audio
    Black wheel w audio controls
    Grey wheel w audio controls
    Grey bag single stage
    Passenger airbag single stage
    Spare black airbag cover for audio which doesn’t match perfectly
    Stock wheel in moon mist, no audio
    Stock bag in moon mist, single stage, no audio
    Stock clockspring w single stage
    FYI, swapping the cover on the passenger bag is no problem.
    I’m only tinkering with that because my passenger bag is apparently faulty.
  19. Sep 22, 2023 at 4:31 AM
    #109
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Did you separate the airbag cover from the airbag/inflator or just go to town with it all as one unit? I have the left and right buttons to add to mine and haven't been able to find an airbag cover for the steering wheels with buttons already on them so I think I'll probably just cut my cover as well. Thanks.
  20. Oct 23, 2023 at 6:52 AM
    #110
    Looping back on this point ... I searched all over eBay and ... while it's a bit longer than 90 days from my reply, seller "liweizhuo37028" is, in fact, gone/inactive: https://www.ebay.com/usr/liweizhuo37028
    It's such a typical M.O. these days. Pop on, sell a gaggle of counterfeit/shit parts, then setup your next batch of accounts to sell similar from.
