General Supercharger Thread
  1. Apr 6, 2023 at 7:04 PM
    #7351
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was going through this last night and was getting radically different injector constant values versus scaling. It was making me wonder if my starting value was incorrect.
    armyoffoo[QUOTED] likes this.
  2. Apr 6, 2023 at 7:34 PM
    #7352
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Did sctundra post that as an attachment? I am not a site member there so i cannot view attachments.
    Edit. I am now a site member but waiting on approval to view/post I am guessing.
    Wynnded[QUOTED] likes this.
  3. Apr 6, 2023 at 8:09 PM
    #7353
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Do they charge for it?
  4. Apr 6, 2023 at 8:11 PM
    #7354
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
  5. Apr 6, 2023 at 8:46 PM
    #7355
    e30cabrio
  6. Apr 6, 2023 at 9:01 PM
    #7356
    armyoffoo
    armyoffoo Member
    Cypress, TX
    There were several people with the same mindset, thinking that the new software locked it out completely, I guess they didn't read the fine print. HPTuners wouldn't do that, unless they absolutely had to, like a cease and desist order.
  7. Apr 6, 2023 at 9:11 PM
    #7357
    e30cabrio
    I'll tell him the 14th
    armyoffoo likes this.
  8. Apr 6, 2023 at 9:15 PM
    #7358
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I took it at the end of February and it expires after 1 year, so it will likely be a yearly compliance thing...
    M3Tundra-JK and Wynnded like this.
  9. Apr 6, 2023 at 10:11 PM
    #7359
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yes, he did.
    ZPhilip[QUOTED] likes this.
  10. Apr 7, 2023 at 7:01 AM
    #7360
    e30cabrio
    I started to work on wiring the new pump harness, the relay it appears needs to be near the pump, the wires going to the pump & its ignition on switch are also there & the wires are too short the Radium harness is small gauge. I'm confused.
  11. Apr 7, 2023 at 7:22 AM
    #7361
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The plug that connects to the pump is the same wiring gauge as the pump, 14 gauge. It looks like the relay wiring will need to be extended, I used 10ft of 10 gauge wire to get from the fuel basket to the engine bay where I have my relay.
    e30cabrio[QUOTED] likes this.
  12. Apr 7, 2023 at 7:37 AM
    #7362
    e30cabrio
    Doesn't using that 14ga defeat the entire project?
  13. Apr 7, 2023 at 7:55 AM
    #7363
    e30cabrio
    Ordered 10ga, hope it works with that 14 ga harness.
  14. Apr 7, 2023 at 7:55 AM
    #7364
    armyoffoo
    armyoffoo Member
    Cypress, TX
    It's the total distance that matters, the pump wiring is 14ga and is sufficient for powering the pump, but not the entire length at 14ga.
  15. Apr 7, 2023 at 8:03 AM
    #7365
    e30cabrio
    Thank you sir!
  16. Apr 7, 2023 at 8:04 AM
    #7366
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Shoot, sorry man...I thought you purchased a kit that already had the wiring, similar to what I had bought. I purchased the below, which had the wiring included.
    http://www.radiumauto.com/DIY-Fuel-Pump-Wiring-Kit-P368.aspx
  17. Apr 7, 2023 at 8:07 AM
    #7367
    e30cabrio
    Mine is from Deaschwerks & those wires are short
  18. Apr 7, 2023 at 8:19 AM
    #7368
    armyoffoo
    armyoffoo Member
    Cypress, TX
    It looked longer from the picture on Amazon, and I saw the relay and fuse provisions so I figured it would be good to go. You should be able to find wiring locally, so you don't have to wait on shipping. The terminals kit comes with the ring terminals you'll need for the top connections, but you might need some butt connectors or another means to connect the 10ga power to the relay wiring.
  19. Apr 7, 2023 at 8:48 AM
    #7369
    e30cabrio
    I ordered shrink tubing & while I was there said fuck it & ordered the fuel lines, I am fully past the Rubicon & sitting in the Roman Senate!
  20. Apr 7, 2023 at 8:50 AM
    #7370
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    @e30cabrio are you installing all this wiring to use a 450 pump, or are you going down in pump to the DW340?
  21. Apr 7, 2023 at 8:58 AM
    #7371
    e30cabrio
    I'm afraid of using the 450 & afraid the 340 might also need more voltage so I'm leaning to using the 340
    It occurred to me I don't seem to have what I need to go from the basket. Which fittings do I need?
  22. Apr 7, 2023 at 9:05 AM
    #7372
    Silver17
    Eastern PA
    Ok, just asking because thats the whole appeal of the 340. It can run fine on the factory 14 gauge wire with no alterations. In a 15’ run of 14gauge wire copper conductor at 14v drawing 12.3 amps, you’re looking at a 7% voltage drop at the pump. At a 7% voltage drop you’re looking at the pump drawing 12.7amps at 13 volts at 50psi instead of 12.3amps at 14volts at 50psi.
    If you’re going to the 340 I wouldn’t bother with all the wiring, but if you’re keeping the 450 then it makes sense. Just my .02, but if you’re in there and want to change the wiring that’s cool.
    snivilous[OP] and e30cabrio like this.
  23. Apr 7, 2023 at 9:13 AM
    #7373
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Are you replacing the fuel lines from the basket to the rails, or only changing the engine-side to dual feed, dual return?
  24. Apr 7, 2023 at 9:16 AM
    #7374
    e30cabrio
    I know no one can say with certainty but is the common wisdom the 450's issue is voltage & the wire will solve it? If so, would I be better off sticking with the 450 or should I switch it for the DW300? If I use the 300, it certainly can't hurt to have the more robust wires right?
  25. Apr 7, 2023 at 9:17 AM
    #7375
    e30cabrio
    I ordered the list from M3Tundra, that is just the rails? If so I'm done.
  26. Apr 7, 2023 at 9:20 AM
    #7376
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    I don't even think he really needs a wiring upgrade to run the 450. At 50 PSI and 12V its only using 14A and flowing 92.1 Gal/Hr which is 96% of injector capacity for 750CC
    The power fuse to the factory fuel pump ecu and fuel pump is a 25A fuse. You guys are saying its 14 gauge wire which I believe but Toyota clearly put a 25A F/PMP fuse on it. I assume the Fuel Pump ecu is using the B+ power feed to pass along to the pump. That's the one thing I have been unsure of here, does the fuel pump ecu tone down the voltage/power delivery to the pump based on commands from the ECM.
  27. Apr 7, 2023 at 9:34 AM
    #7377
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I don't think I got everything on that Amazon list right, I'd try and go more off the ViktorG sheet that was posted instead. It's why I eventually returned all the custom stuff and just ordered the Prospeed kit
    nags likes this.
  28. Apr 7, 2023 at 9:38 AM
    #7378
    armyoffoo
    armyoffoo Member
    Cypress, TX
    If you're just doing the rail dual feed/return you don't need all of that. You just need another barb fitting to replace the plug on your existing FPR, and the y-adapter below to split the single stock pressure line to two pressure lines.
    https://www.amazon.com/QFS-FTY-516-Quantum-Y-Fitting-Assembly-Splitter/dp/B08BWGGVBY
    If you're doing a full line replacement, you will also need a way to connect the new AN lines to the top of the basket, something like this, and a couple of 90 degree hose ends on top of them:
    http://www.radiumauto.com/Fuel-Pump-Adapter-for-Toyota-Hangers-P232.aspx
    M3Tundra-JK likes this.
  29. Apr 7, 2023 at 9:40 AM
    #7379
    armyoffoo
    armyoffoo Member
    Cypress, TX
    If it ever stop raining, I've got some sensors and gauges to install, so I'll be able to verify if my issue still persists.
    Wynnded likes this.
  30. Apr 7, 2023 at 9:43 AM
    #7380
    e30cabrio
    Shit! I thought your list was based on his.
