Tips for installing the Camburg LT kit?
Discussion in 'Long Travel Suspension' started by jojo9878, Apr 7, 2023.
  1. Apr 7, 2023 at 7:56 AM
    jojo9878
    jojo9878 [OP] New Member
    Joseph
    2016 magnetic grey 1794
    Front: 2.5 king 2.5 coil overs Rear: 2.5 kings
    Seeing if I can get anybody to share a couple tips of installing the camburg LT kit or help me find the right thread for it. Also more than welcome to share your tundras on this thread that have any long travel kits. I currently have king 2.5s and wanted more
    I just recently bought a kit for a heck of a deal. Here’s a picture of my ride before the kit is installed. Once I have it on I’ll share some more pictures!
    550E05A9-3776-4C7C-BA05-47D6C759034F.jpg 31DE436B-37E2-4FF0-8771-5D0352952187.jpg
  2. Apr 7, 2023 at 7:57 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  3. Apr 7, 2023 at 8:19 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I see I have been summoned lol. I’ve got the Camburg kit upfront and mix of a custom kit and dirt king items on the rear. Couple things below. Also not sure on the kits condition but I would replace all the joints and bushings etc before the install and have the shocks serviced as well.
    Do you have fiberglass fenders? You’ll want install those at the same time.
    Did you get the kit with coilovers only or with bypasses?
    Do you have any other mods upfront done? I.E. body mount chop, secondary pump intake relocated,
    What size tire you planning on running?
    If you have a diff drop you’ll want to remove that. It will cause the axle to rub the coilover. Alignment spec wise it’s recommended 6 to 6.5 of caster and everything else in stock specs.
    Feel free to cruise my build thread if you need more info and let me know if you have questions. There’s a lot to moving into LT fyi be ready lol but it’s worth it in my opinion.
  4. Apr 7, 2023 at 8:22 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Couple pics added
  5. Apr 7, 2023 at 8:25 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  6. Apr 7, 2023 at 11:00 AM
    jojo9878
    Joseph
    I replaced all the uniballs on the kit, along with new limit straps, I also had the kings rebuilt and new valving to be safe. I don’t have the secondary bypass shocks “yet”. I didn’t know about the secondary air pump. I’m running 35x12.50r17 with +25 offset. Will upgrade to 37s km3 or wrangler mtr with Kevlar. I need fenders still, either looking for a deal on some or going to have wait for them to be built. Does the secondary pump relocation have to be moved right away. Also I don’t have the diff dropped installed. Also the kit came with a new set of LT axles already built
  7. Apr 7, 2023 at 11:44 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Sweet it looks like you’re heading in the right direction. Secondary air pump isn’t immediate but definitely plan for is as it will rub there and get debris in it. I actually sleeved mine with a prefilter until I pieced a kit together.
  8. Apr 8, 2023 at 4:20 AM
    jojo9878
    Joseph
    If I’m correct isn’t the kit to relocate is just a -8an line with some fittings and filters that moves the filter to inside the engine bay?
  9. Apr 8, 2023 at 4:25 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Something similar yes. Myself and a few others have a parts list on it in another thread you can search and find it. Doesn’t need to be any special braided line or anything.
    CaptRussia253 and HulkSmurf14 like this.
  10. Apr 8, 2023 at 4:30 AM
    jojo9878
    Joseph
    you’re a lifesaver ima go stalk your build and look at the threads your in
    IsaiahCanada, Sunnier and reywcms like this.
  11. Apr 8, 2023 at 6:49 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Happy to help. You’ll need to start a build thread lol
    HulkSmurf14 likes this.
  12. Apr 8, 2023 at 7:03 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  13. Apr 8, 2023 at 8:29 AM
    jojo9878
    Joseph
    1UP[QUOTED] likes this.
  14. Apr 8, 2023 at 5:00 PM
    jojo9878
    Joseph
    So my kit came with 700lb springs and also came with a spare set of eibach 600lb springs with tender springs. I never seen someone on here run a dual spring set up on the tundra unless it’s a 10+inch coilover. What do you guys think should I run the 700s or the dual rate?
    831Tun likes this.
  15. Apr 8, 2023 at 7:45 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    700 is the correct option IMO
    joonbug and reywcms like this.
  16. Apr 8, 2023 at 8:29 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I agree on 700 but I’d be curious on what that 600 would be like hmm lol
    831Tun likes this.
  17. Apr 8, 2023 at 8:36 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I believe TC and Camburg used to spec 600lb springs but changed a couple years ago to 700.
    joonbug and reywcms[QUOTED] like this.
  18. Apr 8, 2023 at 8:38 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Makes sense. These pigs are heavy. I did see a camburg setup with a 3.0spring and helper. I believe proyota is the guy on Instagram
  19. Apr 8, 2023 at 8:51 PM
    jojo9878
    Joseph
    I may take one for the team and try both of them and let y’all know. I think 600s and helpers would be good for like washbroad and daily but not for big hits
    Sunnier and reywcms[QUOTED] like this.
  20. Apr 9, 2023 at 8:14 PM
    jojo9878
    Joseph
    Guy in Texas is selling this bed cage for a LT it looks like. Says it’s evil brand. What do you guys think? Is it worth the buy 4FDCEBE6-E91B-40E8-953F-A31492D136CB.jpg
    831Tun likes this.
  21. Apr 10, 2023 at 5:38 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yea if the price is right and you want to do LT through the bed.
  22. Apr 10, 2023 at 8:17 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Building a LT truck is not cheap so I can understand if you're trying to save money but that cage has twice the tubing mine has. I don't know where you're located or what your budget is but there may be other options like Dirt King and Camburg I have an SS Built cage. They pretty much, at least when I got mine, only sell it along with installation
  23. Apr 10, 2023 at 8:49 AM
    jojo9878
    Joseph
    I’m willing to spend the cash, but I like deals I mean who doesn’t. I really wanna maintain my roll n lock bed cover if possible
    831Tun[QUOTED] likes this.
  24. Apr 10, 2023 at 8:54 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Not sure what the bed cover looks like but I’d be sure it clears etc. My cage fits under my bakflip cover which is nice for sure.
  25. Apr 10, 2023 at 9:27 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Where do you live and what kind of terrain you have?
    reywcms and 831Tun like this.
  26. Apr 10, 2023 at 9:30 AM
    jojo9878
    Joseph
    I live in Roswell,NM it’s pretty much desert but not like super sandy, 1 hour away we have mountains, and another 1 hour the other way we have super sandy areas
    reywcms and joonbug[QUOTED] like this.
  27. Apr 10, 2023 at 8:50 PM
    jojo9878
    Joseph
    After doing some research ima have to get a different bed cover because the shock cage doesn’t leave enough room for my current one. The sacrifices you gotta make.
    Also here’s a picture of the kit I bought for the front it was used but it came with new uniballs that needed to be installed, came with axles, straps, two sets of springs. I sent the coilovers to be rebuilt. Payed 3k for the kit what do you guys think was it worth the buy? D43F187E-4CAF-4C7E-84F5-794F1ED0AF3A.jpg
    CaptRussia253 likes this.
  28. Apr 10, 2023 at 9:02 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Definitely a good deal. I can tell they had a diff drop lol by the center rub mark on the axles.
    831Tun likes this.
  29. Apr 10, 2023 at 9:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you don’t weld, find a good fab guy. You’re going to need him quite a bit in the future. Bet you can build a custom bed cage and clear your tonneau for not much more than the Evil.
    831Tun and reywcms like this.
  30. Apr 10, 2023 at 9:14 PM
    jojo9878
    Joseph
    Yeah I saw that the axle had some tub for for sure. Do you think the axle is good to send it?
    the axle on the left side looks pretty worn
    yeah my uncle does fab work and powder coating I totally forgot I may have to give him the truck so he can fab something up for me.
    joonbug likes this.
