spring seats
Discussion in 'Suspension' started by 1/2 ass tundra mechanic, Apr 6, 2023.
  1. Apr 6, 2023 at 7:20 AM
    1/2 ass tundra mechanic [OP] New Member
    2007 5.7 liter sand tundra
    morning, needed to replace spring seats on rear differential , like rest of the underneath carriage it is rusting out. does anyone know the torque specs for nuts on the u-bolt.Thanks in advance
  2. Apr 6, 2023 at 7:21 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  3. Apr 6, 2023 at 7:33 AM
    need change out body bushings next, any tips before i get started. Also so rusted out when hitting bumps making horrible banging. have not found much on the internet. Thanks again
  4. Apr 6, 2023 at 7:45 AM
    Let’s see some pics of this carnage
  5. Apr 6, 2023 at 8:33 AM
    i will shoot a photo of the awesome carnage tonight when home from work
  6. Apr 6, 2023 at 6:09 PM
  7. Apr 6, 2023 at 6:11 PM
    Those are pretty crusty. Replacing with OEM?
  8. Apr 7, 2023 at 8:53 AM
    yes oem unless there is another way out , pretty expensive part and need to do all of them. i want it done rite , any experience with after market or looking for trouble?
  9. Apr 7, 2023 at 9:14 AM
    OEM is the best bet, someone on here is redoing theirs with generic poly material
  10. Apr 7, 2023 at 10:17 AM
    great thanks, i am also sanding chassis and recoating with woolwax automotive undercoating. which is an automobile-marine rust protector but it does not dry i am finding out.it remains wet and every time i go under the truck to work on it i get a reminder i rust coated it. still have quite a bit to do, am using it for all the high stuff that i cant reach easily. would like to purchase a good rust proof-sealer that will dry for lower body parts, any experience with a good coating? thanks again
