Is this tennis elbow?
Discussion in 'Sports, Hobbies & Interests' started by T-Rex266, Nov 5, 2022.
  1. Nov 10, 2022 at 10:55 AM
    VTsuckah
    VTsuckah New Member
    2018 Tundra Limited CM 4x4
    I think your issue is actually a brachialis strain, not tennis elbow. Supinated and neutral grip bicep curls should be much more painful to execute than your standard pronated curl if this is the case. Standard straight bar pull ups should cause you pain in the same area. I had this issue about a year and a half ago and it took the better part of 3-4 months to fully go away. Like you, I continued to train, but had to heavily restrict my workouts to not aggravate the area. I still was able to work biceps and perform curls, but had to over exaggerate a supinated grip while keeping my wrists and elbows firmly rigid. Same with back days...all movements like pull downs, rows, etc had to be with supinated grips....and chin ups. The only thing that I found helped was ice and advil. Massaging just continued to irritate the area.
    T-Rex266[OP] likes this.
  2. Nov 10, 2022 at 11:38 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Honestly, you're going to want stay away from anything remotely heavy that involves grip; such as deadlifts, rowing and other back exercises, and even carrying plates will aggravate it pretty easily (it's the rolling/curling motion coupled w/static tension in your fingers, etc.). I had this in my early 20s from heavy curls. Not sure if you've ever had shin splints, but if so, I think you'll find the pain is relatively similar; and minimizing the pain is similar in terms of heavy wrapping/taping around the forearm will mitigate it (w/shinsplints you'd tape the calf tightly pulling it forward to reduce stress on the bone).
    Also, think of it like shin splints in terms of recovery. You have to avoid that heavy work for a decent amount of time to allow the injury to heal. You may get away w/a heavy workout or two once it's feeling better, but you'll soon be right back in the same boat. I know it's hard to stay away from the chase, but sometimes you've gotta back off for quite a while.
    If you want to kinda confirm what I'm talking about, grab a friend and a light weight that will stimulate the pain (don't pick the friend up). Manipulate the weight in a manner that stimulates the pain and have your friend wrap both hands around your forearm and squeeze tight (very tight); if the pain goes away w/the squeezing pressure you are (probably) dealing w/a similar injury!!
    So, if it's the same the reason massage is reducing pain is because it's relaxing the muscles, etc. around the injury that have tightened up to try and protect and shield it. This is why even though you feel better (acutely) the root injury may still be highly aggravated and susceptible to long term issues if you try and get back at it too soon!!!
    Besides what is they say??... it's 90% diet!!! So, missing some heavy work for a couple of months shouldn't mitigate too much of that mass :muscleflexing:...
    Alternating heat and cold really helped me also. Like someone said above, the ice massages really help reduce that immediate flaring up pain as everything starts to fire up by numbing things up and reducing the swelling. But, getting some hot compress sessions in also help by increasing blood flow to the targeted area; which is especially good after you've had a good high protein meal or have taken some BCAAs...
    Good luck!!!!!
  3. Nov 10, 2022 at 11:48 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
  4. Nov 23, 2022 at 11:58 AM
    guyfromky
    guyfromky New Member
    It can be an aggravating and painful thing. I used to play tennis and had this a couple times. I couldn’t even pick up a television remote.
  5. Nov 30, 2022 at 7:49 AM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
  6. Nov 30, 2022 at 7:56 AM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    After years of being a defensive tactics instructor, which also means I'm the tackling dummy for most drills and getting the ol' "arm bar" technique (you know, the pressure toward hyperextending the elbow joint), I could no longer do pullups or any bicep work without feeling it in same spot. Friend who was an athletic trainer basically said, "You can rest it for a while, months maybe, until it's not painful anymore OR you can continue until you rupture a tendon." I rested it for a LONG time, worked around it and even now will do an extensive warm up before doing anything like pullups or adding any weight to an overhead pull down exercise. Kept reminding myself that the triceps is 2/3 of the arm's size anyway so it was an opportunity to hit that area a little harder. (although no one ever showed off their triceps when hanging their arms out the car window).
  7. Nov 30, 2022 at 8:08 AM
    T-Rex266 [OP] Elon approved Staff Member
    Elbow is fine. It’s the forearm (brachiosaurus) area. Left one sucks- right is decent. It may just be a bicep tendon. I have no idea and haven’t (wanted to, anyways) have it checked out as I’m sure I’ll hear the same “give it a rest. Ice it”
    I concentrate harder on triceps, than biceps. Fortunately, upper body is more genetic for me. A few sets of hard biceps and I’m good to go. One of those I do hammer db curls, or hammer rope curls to help push it out more
    FlyingWolfe likes this.
  8. Nov 30, 2022 at 8:12 AM
    Wyoming
    Right, I was just meaning the "tennis elbow" was all. Have you rested and iced it, or have you been powering through?
    Also, because I can.
    Wallygator, Bprose, Bob and 3 others like this.
  9. Nov 30, 2022 at 8:13 AM
    I calmed down some lol. Still needs to get worked on again I think. It also sucks because I am left handed, so naturally I use my left much more.
    GODZILLA[QUOTED] likes this.
  10. Nov 30, 2022 at 8:18 AM
    Wyoming
    I didn't know you were a lefty. :eek:
  11. Nov 30, 2022 at 8:26 AM
    My dad is, as is my son as well
  12. Nov 30, 2022 at 8:34 AM
    Wyoming
    Ah, so it's a genetic condition. My condolences. :p
    Are you full blown left handed, or are you semi ambidextrous? Any tasks that you perform right handed?
  13. Nov 30, 2022 at 8:36 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Hes a witch!
  14. Nov 30, 2022 at 8:37 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    when did you know you were a south paw?
    my son is...we tried to convert him early...didn't work.
    T-Rex266[QUOTED][OP] likes this.
  15. Nov 30, 2022 at 8:39 AM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    I also have this condition. No ragrets
    Whatever you do, don't tear your bicep tendon! That fun pop sound is the indicator (@Cthulhu mentioned it earlier in the thread)
  16. Nov 30, 2022 at 8:53 AM
    Wyoming
    The owner and a Mod are lefties?
  17. Nov 30, 2022 at 10:30 AM
    Semi ambidextrous. I only throw with my right hand and will golf (Topgolf lol) right handed
    No idea. I think my dad just put a fork in my left hand growing up all of the time.
    Its one of the interview questions we ask so you get extra points added to the interview panel
    Wallygator and GODZILLA[QUOTED] like this.
  18. Nov 30, 2022 at 10:31 AM
    Literally LOL'd
  19. Nov 30, 2022 at 4:56 PM
    Wallygator
    Band'it!!!!
  20. Nov 30, 2022 at 5:37 PM
    #50
    Duct tape
    GODZILLA and Wallygator[QUOTED] like this.
  21. Nov 30, 2022 at 5:48 PM
    #51
    Wallygator
    The band'it was the only thing that worked for me. Maybe it will work for you. Duct tape won't work
  22. Nov 30, 2022 at 8:33 PM
    #52
    Lol it was sarcasm. Duct tape (it)
    How often did you wear it? I’ll order it
    edit: ordered
    Wallygator[QUOTED] likes this.
  23. Dec 1, 2022 at 2:50 PM
    #53
    Wallygator
    I knew you were messin. Wore it until the pain was gone completely. From what I remember it took a few weeks.
    Hopefully it works for you.
  24. Dec 4, 2022 at 11:00 AM
    #54
    Just arrived today
    Wallygator[QUOTED] and GODZILLA like this.
  25. Apr 6, 2023 at 2:43 AM
    #55
    trdskyline
    trdskyline New Member
    2023 LunarRock Limited Hybrid CrewMax
    Had the same area of pain in my forearms after playing flirt pole with my dog of all things. Never got a real diagnosis from a doc, and took a long long time to heal. Couldn’t get a firm grasp of things with my hand at times just felts wierd. After 3-4 month finally notice it went away mostly with some lingering but better than before and now can hit the gym again.
