  1. Mar 29, 2023 at 8:26 AM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    What’s special about the socket other than the slit in the side? Why couldn’t one just use a box end wrench or since I am replacing the sensor anyways cut the wire and use a normal socket?
  2. Mar 29, 2023 at 2:45 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    My O2 socket has a 90 degree 3/8" "coupler" if you will. Has made jobs possible which would not have been without it.
    Not sure where they mount the several O2s on the tundra or what else may be blocking access, but the proper tool really can come in handy.
  3. Mar 29, 2023 at 2:51 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    @17TundraDCEd sent a nice black exhaust tip and I finally had the time and weather, and a relatively pain free day (along with a exhaust pipe expander) to install it.
  4. Mar 29, 2023 at 5:22 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    yes either option could work if you can get in the area to do it, not sure where the O2s are on the tundra, but several cars that come through the shop just aren't possible with the socket or several other tools, only use the box end of the wrench and not open or you risk striping the O2 sensor nut
  5. Mar 29, 2023 at 5:47 PM
    20GR8 Super
    Corey
    PNW Outskirts
    Thanks guys! I could see what you mean on some vehicles. The Tundra doesn’t look horrible for access. Good to know I can rent one if I need to.
    8D86C59B-E0EF-4AE7-BB47-A0BA5D43B682.jpg C86AA600-F104-454F-824A-836D6F167A00.jpg
  6. Mar 30, 2023 at 5:05 AM
    joseph_womack
    Joe
    Louisiana
    Yeah that doesn’t look too bad, renting is also free, you just put a security deposit down and you get it back when you return the tool
    20GR8 Super[QUOTED] likes this.
  7. Mar 30, 2023 at 5:47 AM
    chrisf111
    chrisf111 New Member
    When I replaced my O2 sensor I picked this up. I can't remember if I ended up using it or not, but it was cheap insurance to make sure I didn't run into any snags.
    https://www.amazon.com/gp/product/B00GMN4D1Q?ie=UTF8
    This was the O2 sensor I used on my 07 tundra upstream driver's side. It's been in there for a year or so now.
    https://www.amazon.com/gp/product/B000C5UFSK?ie=UTF8
  8. Apr 1, 2023 at 12:29 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    Installed fancy pedals. Before/after:
    BD44CBA3-7A01-4C54-B629-D24C800A59B4.jpg 94CA967A-2EB7-499F-AF85-8BA85D95C55F.jpg
    They feel great! The install was easy, but not as easy as it looks.
    You need to drill through your existing pedals 3/16" to add machine screws and nuts. The parking and regular brakes are pretty thick steel so get a variety of specialty bits and work your way up. I had to remove the gas pedal to tighten the nuts.
    I broke my 1/16" bit and my 3/16" bit is now a 1/8"... So I'll be buying some new metal bits.
  9. Apr 1, 2023 at 2:13 PM
    TimS458
    TimS458 New Member
    2012 Barcelona Red TRD Off-road
    Did an oil change, differential drop, carrier bearing drop, and clearancing for my 37's. I thought I had enough room near the cab to fit them, but I kept rubbing against the rear fender liner, so I decided to cut a few sections in my pinch welds and folded them over. I then heated up the liner to reform it against the wheel well. Now I've got plenty of clearance everywhere. Now I just need a different front bumper. My current choices are Coastal Off-road, SS Built, or Ironman 4x4.
  10. Apr 1, 2023 at 5:12 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    I got to drive her again, following a transmission rebuild. Felt gargantuan after driving the Frontier...and quiet and comfortable, just like slipping into a well used pair of underpants. :yes:
  11. Apr 1, 2023 at 7:15 PM
    biggsy
    biggsy New Member
    Warren
    2010 Tundra DC Rock Warrior
    Attempted to install 6112, new tie rods, new LCA, Bilstein UCA but the infamous LCA is getting the best of me. One came out easy and been at the other with 2 saw blades. Will try angle grinder tomorrow. Also bent a cam tab so I may have a gusset in my future.
    can’t wait to finish these installs. All ball joints have been leaking for years.
  12. Apr 2, 2023 at 5:37 AM
    rmeyer7
    rmeyer7 New Member
    Roy
    2008 Double Cab 5.7L
    Yesterday, not today...but here's what I did to mine (so far) this weekend.
    Wiper arms were super faded, so I took them off for a proper cleaning, sanding, re-cleaning, priming and painting with a matte black automotive paint. Unfortunately I accidentally knocked them over and they hit the ground right after spraying the base coat, so now I'll have to re-sand today before putting on the final coats.
    Also had one of my cargo lights out in the 3rd brake light assembly, so of course I did the only sensible thing and replaced both of them with the brightest LEDs I could find! And replaced the weather stripping on top of the cab.
    Projects still on my list include a grille upgrade, console safe, swapping out the factory head unit and installing a backup camera with it, getting some running boards and maybe trying to find a new trim panel for the gauge cluster area since mine has a little crack in it. It's a completely stock '08 I found with only 74k on the clock, so I've got lots of plans and figure it has more than enough life left in it to be worth all the work!
  13. Apr 2, 2023 at 7:35 AM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Anybody ever shorten their shifter rod? It is ridiculously tall. Looking for best option to this.
    Mountun Goat likes this.
  14. Apr 2, 2023 at 7:54 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I added an 8” tall knob to make it even taller :rofl:
  15. Apr 2, 2023 at 3:21 PM
    PhotoNerd
    Tony
    Waterford, CT
    Based on discussion in this forum, I changed my oil from 0W-20 to 5W-30 to see if it would quiet down some of the 5.7 rattle... Not much of a difference in a short drive but maybe it needs to circulate a bit?
    I installed Jowett Performance valve and metal oil filter housing which should make future oil changes easier and neater. I also have the RCI skid plate so I only need to remove a small panel to access the filter.
    785F9CB4-90A8-4024-B09C-280D2DCD1E4D.jpg 0823DB85-A716-48AF-9C60-BCFD8E16EF11.jpg
  16. Apr 2, 2023 at 5:21 PM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    And painted it purple! :rofl::burnrubber:
  17. Apr 3, 2023 at 8:18 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Hallelujah! :duh:
    Kiddnapped Tundra and Ohannon7 like this.
  18. Apr 4, 2023 at 5:06 PM
    Condor94
    Condor94 New Member
    2008 Toyota Tundra
    FOX 2.5 275/70R18 Coastal Offroad Bumper
    Hey, I just ordered the ICS dash plate as well about a month ago. Have you received yours yet? I haven't gotten a shipping confirmation or much in the way of response on order updates.
    20GR8 Super likes this.
  19. Apr 4, 2023 at 6:31 PM
    20GR8 Super
    Corey
    PNW Outskirts
    I got tracking either same day or the day after when I ordered mine and believe that it came within the week.
    Tripleconpanna likes this.
  20. Apr 4, 2023 at 8:49 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I had the same experience as 20GR8 w/mine....
    @Condor94 You may want to give them a shout in case some wires got crossed. I think most folks here on the forum have had good service from them.
  21. Apr 5, 2023 at 4:08 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    I just IM’d them and they said…
    “Hello we are currently out of those but have more coming in next week. You’ll get tracking info then”
    FYI @Condor94
  22. Apr 5, 2023 at 6:45 AM
    GSil
    GSil New Member
    2013 SR5 DC Tundra
    any noticeable difference yet?
    Filthyphil likes this.
  23. Apr 5, 2023 at 11:32 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Removed oem bumper bc friday the replacement comes in. RanchHand.
    no, it won’t match the front but it’s the best rear bumper for my needs which is to prevent serious trama in a rear end collision.
    Mountun Goat, WVI, chugs and 4 others like this.
  24. Apr 5, 2023 at 5:52 PM
    biggsy
    biggsy New Member
    Warren
    After 5 days of messing with this, I finally. finished my front suspension.
    OEM LCA
    OEM outer tie rods
    6112 (#3 setting)
    Bilstein UCA.
    off to alignment tomorrow. A lot of anger was involved with the seized LCA and UCA bolts but other than that everything went well. One of the outer tie rod jam nut is stuck so I hope the shop can fix it. The truck looks much better now after I took care of the rear last month.
    spark plugs, engine, diff, and trans fluid next on the list.
  25. Apr 6, 2023 at 5:06 AM
    COTundie
    Trey
    Pretty things
    Got a mobile domicile to tow behind it!
    Last week actually, but she pulls really nice... Even with a blowout.
    At least she's safely up at Basecamp for now.
    Let the adventures (and maintenance) begin!
    Ohannon7, MTRock, Pnoy_toy and 11 others like this.
  26. Apr 8, 2023 at 12:02 PM
    Retroboy1989
    Northern Utah
    Not today, but I sold my snugtop then turned around and bought a used softopper in awesome shape.
    Waiting on some clamps from Softopper. The ones it came with are for a Tundra without rails.
    PXL_20230408_172921527.jpg PXL_20230408_172915018.jpg PXL_20230408_172152481.jpg
  27. Apr 8, 2023 at 12:08 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    Nice! I used to have a Tacoma with a soft topper and I loved it
  28. Apr 8, 2023 at 1:19 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    I dicked up my front driveshaft yoke yesterday pressing new u-joints and couldn’t find a replaceable part number to save my life so I ordered a new driveshaft.
    joseph_womack and WVI like this.
  29. Apr 8, 2023 at 2:55 PM
    ACDC2ZZTop
    Travis
    Oregon
    Put a shine on the tires. Figured I’d do the same for the wife’s rig.
  30. Apr 8, 2023 at 5:38 PM
    RJVA
    RJVA Former Lurker
    Richard
    Idaho
    2008 Tundra Silver DC 4.7 4x4
    OEM 18" wheels off a 2.5 gen 275/70/18 Falken Rubitrek A/T FabFour Redsteel front bumper with HF winch. Dobinsons IMS with 2.25" coils (610) JBA UCA's Iron Man +300lb rear leaf packs with Dobinsons IMS shocks ECGS bushing in front diff Black Oak Led Flood Pods. 40watt (x2) Black Oak 20" light bar. 100 watt OEM style rear bumper, black powder coat, added aux reverse leds. Stubby AM/FM antenna Century Camper Shell with Roof rack and bed mat
    New balls joints in my JBA UCA's and 8 new Denso coils for the 4.7L. I noticed the coils were cracking 30k miles ago when i did the plugs... just now got around to swapping them out. Feels more peppy now.
