High performance lubricants
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sumo91, Dec 5, 2021.
  1. Dec 5, 2021 at 4:18 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    So I've been researching oil on my other favorite forum, BITOG, and ran across High performance lubricants. They appear to have fantastic oils, so I sent them a message and asked some questions about switching over to their oil. The owner, David, messaged me back and told me to give him a call today, which is Sunday. Awesome customer service so far! So I called and we discussed oil. I brought up the 75w transfer case oil, and if they made. He told me they can make it to order, and it will be about the same price as their gear oil, so not crazy expensive like the Toyota stuff, and also way better than anything currently available. So I'm about to swap my truck over to their oils front to back. Hope this helps someone, I highly suggest giving them a look
    Corndog123 and BTBAKER like this.
  2. Dec 5, 2021 at 6:59 PM
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    The 3rd gen Tundra uses Toyota Genuine ATF WS in the transfer case, not 75W anything.
    It does use 75W-85 in the front and rear differentials, though.
    Corndog123 likes this.
  3. Dec 5, 2021 at 7:01 PM
    Sumo91
    TN
    This is completely and entirely incorrect
    Rocko9999 likes this.
  4. Dec 5, 2021 at 7:16 PM
    Sumo91
    TN
  5. Dec 5, 2021 at 7:17 PM
    Sumo91
    TN
    Also meant to make this post in the 2.5 gen thread. Still used to calling it a 3rd gen
  6. Dec 5, 2021 at 7:48 PM
    stevj
    stevj New Member
    That information came from the 2022 Tundra Owner's Manual.
    Perhaps we have different owner's manuals.
  7. Dec 5, 2021 at 7:56 PM
    Sumo91
    TN
    See above post
  8. Dec 5, 2021 at 8:02 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Which one is it?
    Sumo91[OP] likes this.
  9. Dec 5, 2021 at 8:07 PM
    Sumo91
    TN
    2014-2021 takes 75w per toyota
    HPL makes the 75w to order. Give them a call and they can make a batch when you need it. I believe they may only sell In minimum quantity of 6qts though. I'm going to be placing an order in a few days for 4 gallons 5w30, 12qts 75w90 diff fluid, and 6qts? 75w transfer case oil
  10. Dec 6, 2021 at 4:57 AM
    2mchfun
    Not to jack your thread, but since you are big on oil, I'm curious if you have a prestart up lube pump?? I'm currently looking.
    Corndog123 and Sumo91[OP] like this.
  11. Dec 6, 2021 at 5:07 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Good to know. I’m running Ravenol right now without issues but it’s nice to have alternatives. Thanks.
  12. Dec 6, 2021 at 5:14 AM
    Sumo91
    TN
    I don't think it is necessary at all.
    Yes, most of your wear occurs on start up, but I'll show you my last UOA, 10.2k miles with miles to spare. Notice the extremely low wear metals. If you added a pre oiler, how much more could you bring these numbers down? And would it be worth it? I don't think it is. Wear is also linear, so the longer you run your oil, the more wear metals show up as evidenced by many UOA on bitog. The oils I like also have lots of moly, which essentially "plate" the internals of the engine with a super slick, super tough (500k psi) barrier.
    The Schaeffers has been great, but im switching to HPL products as they have much better additive pack, extended drain intervals of 20-25k, and they have alot of Ester in the oil which cleans your engine extremely well of any sludge or varnish, and its my opinion that it will keep the timing chain tensioner from getting dirty, sludged, or clogged, and keep it in good working order. I priced a case of 4 gallons and it equals around $10qt.
  13. Dec 6, 2021 at 5:15 AM
    Sumo91
    TN
    I'll post mine when I get it :thumbsup:
    BTBAKER[QUOTED] likes this.
  14. Mar 31, 2023 at 5:05 PM
    blenton
    blenton New Member
    Just drank the Koolaid. Gonna give HPL a try in the diffs, T case, and engine after running their cleaner for the next few thousand miles.
  15. Mar 31, 2023 at 5:06 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Can't go wrong
  16. Mar 31, 2023 at 5:31 PM
    blenton
    blenton New Member
    Did you do the full compliment of oils including the transmission? I’ve read tok many threads on the stuff on BITOG I can’t remember who did what. I PM’d Sumo about the transmission fluid but it’s always nice to have a test pool greater than 1. Haha. I’ve just always been hesitant about flushes and have done drain and fills every 30k or so with WS. Mines due for another but I was thinking of doing a drain and fill every 5 or 10k miles until I’ve exhausted my supply of WS, then maybe switch to HPL Green CC.
  17. Mar 31, 2023 at 5:46 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Tbh, I've only done the transfer case and diffs. I'm running it post-gear swap though and no issues.
  18. Mar 31, 2023 at 6:51 PM
    blenton
    blenton New Member
    No worries. Thanks for the feedback.
  19. Apr 1, 2023 at 5:04 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    can we just take a sec to acknowledge the 3rd gens take almost 6 qts oil in the rear diff? thats insane. how much larger is their rear end?
  20. Apr 1, 2023 at 5:40 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I like big rear ends
  21. Apr 2, 2023 at 6:02 PM
    Chadr7858
    Chadr7858 New Member
    I like amsoil and big rear ends
  22. Apr 3, 2023 at 9:21 AM
    MTAZ
    MTAZ New Member
    2019 tundra
    Many
    This is the only thing that Toyota recommends for their transfer cases...
    It ain't cheap but it's cheaper than have to replace a transfer case because you used the wrong fluid....
  23. Jul 11, 2025 at 9:30 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Any of you guys here still running HPL? I just ordered my first bucket of the basic PCMO 5W-30. I'm doing 30k highway only miles a year w/ 5k mile Costco oil changes and simply getting tired of doing oil changes every 2 months. Color me lazy but I'm seriously looking at pushing to a 15k mile OCI as was suggested by David Ward at HPL when I emailed him for his recommendation.
    Aside, how cool is it you can email the owner of the company and he'll give you his recommendation along with his cell phone number?
    Leo's first likes this.
  24. Jul 11, 2025 at 9:54 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    And high performance lubricants.
    hagrid and Corndog123 like this.
  25. Jul 11, 2025 at 10:06 AM
    Tbrandt
    Tristan
    Kansas City
    My inner 12 year old boy finds this hilarious.
    WILLINH and SD Surfer[QUOTED] like this.
  26. Jul 11, 2025 at 10:21 AM
    SD Surfer
    Bruce
    So Cal
    :yes::bananadance:
    Tbrandt[QUOTED], WILLINH and blenton like this.
  27. Jul 11, 2025 at 10:30 AM
    blenton
    blenton New Member
    I don't run it any more. My Blackstone reports came back with higher wear metals than any other oil, and both my diffs have had issues after running it. My Auburn turned in to a locker then self destructed. But the labs showed it to be a far superior ad-pack despite the excessive wear metals, so I don't know what was going on.
  28. Jul 11, 2025 at 10:33 AM
    Tbrandt
    Tristan
    Kansas City
    That's concerning. Higher wear metals for just the differential oils? Or were you also seeing the same for your engine oil as well?
  29. Jul 11, 2025 at 11:29 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I just ran the regular PCMO 5W-30 for 10k miles in my 2019. Analysis from Polaris showed tbn was still high and wear metals low. Filter was clean. 15k will be my next interval.
    I have always had good luck with Amsoil, Mobil 1, and Valvoline gear oils, so I don’t plan on changing there.
    Tbrandt[QUOTED] likes this.
  30. Jul 11, 2025 at 11:55 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    So why does Toyota(Harley does it too) specific oil matter? I understand the various weights and viscosity and the reasoning behind it all but I've never understood why an oil or grease or whatever lube has the vehicle manufacturer's name on it then it's "the best"? I mean, the way I see it, if I use a high quality 75W in a transfer case but the oil isn't Toyota, it's not like my TC is gonna all of a sudden fall apart and cause small children to cry. I get long winded sometimes......
