6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Dec 30, 2022 at 4:57 PM
    #2101
    RW-3
    RW-3 May the Mods be with you
    Rob
    16 Black TRD CM 4x4
    Lights: 2018 OEM Black Chrome LED’s Morimoto XB Fogs Interior LED upgrade - VLED’s LED reverse / cargo - VLED’s Footwell lights, vanity lights, break lights, rear turn signals, 3rd break light - All VLED’s 30” Rough Country light bar hidden in bumper w/ Rago Fab Brackets Matt Gecko LED bed lights (red & white) and hood lights Exterior: Truxedo Lo Pro QT WeatherTech in-channel window deflectors Interior: Husky X-Act Contour front & rear Front, back and rear windows all tinted 10% Ceramic Heat Film on Windshield 70% OCD console organizer OCD console tray TRD 4x4 inserts on Husky mats by Achuop Tacoma TRD Pro shift knob with TRD leather boot AJT Design vent ring trim - chrome delete Center console wireless charger Drivers side grab handle Performance: Dirty Deeds BA Muffler 12” Budget Standard System TRD Rear Sway Bar AFE Pro Dry S Air Filter Bilstein 6112 1.9” clip Bilstein 5100 - rear Coachbuilder +1’s Nitto Ridge Grapplers 285/70/18 Audio: Infinity dash speakers Tech12Volts custom center dash speaker Hertz Uno door speakers JL Audio RD 900/5 amp 2 JL Audio 10w-0 v3 10” subs in custom Tech12Volts box Protection: McGuard Tailgate Anti theft lock OEM tailgate lock w/ Dynamat TRD Pro skid plate SNS ARB sensor guards Misc: TRD key fob case AJT Designs Rear diff breather mod Fortin remote start with Car Link CL6 TRD battery bracket by Coupe TRD valve stem caps TRD interior handle inserts by abomb60 (Adam)
    Question for those running 2 CB shims on the driver side. Anyone have a pick of the bolts/nuts on top of the coil over? I’ve got 1 CB shim on the driver side but going to add another. Just curious as to what the studs/nuts look like after adding the second.
    Current setup is 6112 on 1.9 setting, 1 CB shim. CB+1’s in the back and Nitto Ridge Graps 285/70/18
    Future setup - adding 2 more shims in the front and going to +2’s in the back with carrier bearing drop. Have Bora 1.25 spacers and will be putting on 295/70/18 Ridge Graps when the current tires wear out.
    SAGE63 likes this.
  2. Dec 30, 2022 at 5:26 PM
    #2102
    SAGE63
    San Diego County
    Might not be the view you are looking for but here is mine 2 cb shims on 6112 driverside
    RW-3 likes this.
  3. Dec 30, 2022 at 5:29 PM
    #2103
    RW-3
    Rob
    16 Black TRD CM 4x4
    Yes sir. Thank you!
  4. Jan 4, 2023 at 2:26 PM
    #2104
    trent61
    trent61 New Member
    FNG here - where are you all getting your 6112's/5160 combos? Amazon?
    Links appreciated - thanks all
  5. Jan 4, 2023 at 3:29 PM
    #2105
    SAGE63
    San Diego County
    mine are FS on the marketplace. everything in that picture and more.
    Update: guess he saw my FS before I mentioned it...sent me a PM already about shipping.
    joseph_womack likes this.
  6. Jan 5, 2023 at 9:11 AM
    #2106
    dhalsey
    dhalsey New Member
    I don't know who needs to hear this but all these trucks are different.
    These are the different configurations I've had to go through to get the truck level.
    1st, 1.9 setting with a .50 spacer on the drivers side. Result = .50 inches low on the drivers side. (This is what everyone recommends)
    2nd, 1.9 setting with a .50 and .25 spacer on the drivers side. Result = .25 low on the drivers side. (This wasn't bad but it still looked low to the eye and was softer feeling then the passenger side. The soft feeling is what made me unsatisfied.)
    3rd, 2.5 setting plus a .25 spacer on the drivers side. Result = .25 high on the drivers side. (With me in it, it is completely level. Also, Getting the front driver side higher evened out the right rear as well. I don't have a lean at all even the the tank is full.) It rides great.
    Anyone that has owned a Tacoma and has put Bilstein's on will know that they recommend two different heights. I wish they would have written that in the directions for the tundra. I would have saved a lot of time.
    Hopefully it helps someone..
  7. Jan 6, 2023 at 10:11 AM
    #2107
    kvnbss
    kvnbss New Member
    Kevin
    Looks solid man!
  8. Jan 20, 2023 at 11:49 AM
    #2108
    Krisgo316
    Krisgo316 New Member
    Kris
    Western NC
    2015 MGM Tundra TRD
    I have a question. I have flipped through most of these pages and didn’t see an answer but that doesn’t mean one isn’t posted somewhere. I have a 2015 Toyota Tundra crewmax. Right now I have spacer lift on front and blocks in the back. If I out the Bilistein 6112’s and 5160’s on my truck does that replace the spacer lift? Might sound like a dumb question but I have never messed with any lift before.
  9. Jan 20, 2023 at 12:13 PM
    #2109
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Yes, the space lift will come out with your existing struts.
  10. Jan 20, 2023 at 12:49 PM
    #2110
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    The bilstien will take the place in the front, but not the back.
  11. Jan 20, 2023 at 1:40 PM
    #2111
    Krisgo316
    Kris
    Western NC
    2015 MGM Tundra TRD
    Is it ok to leave the block on the back with the new shocks?
  12. Jan 20, 2023 at 2:09 PM
    #2112
    FISHN43
    FISHN43 New Member
    Ohio
    You should be fine with the block in the back. You would have to use a block or longer shackles to get lift anyway since shocks don’t actually add lift by themselves.
  13. Jan 30, 2023 at 8:01 AM
    #2113
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    Installed my 6112s at 1.9 with a coachbuilder shim on each side. Getting alignment done now. Also installed diff drop which was more of as pain than the shocks. That driver side nut is a biatch to install. Not even sure I needed the drop or if it really seems to have done anything but it’s up there now. Tires later this week and pics to follow. Oh, still need to install rear components to lift it 1.5 back there but that will be for another day.
    RobertD and Skew12 like this.
  14. Feb 7, 2023 at 7:40 AM
    #2114
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Depends on how you like the stance now vs how you want the stance to be. Let's say you get 6112s to lift the front 2", have a 2" block in the rear, and like OEM rake. Then you won't have to change a thing!
    We do have 6112/5160s on the shelf here at Hotshot Offroad if you haven't sourced them yet!
    RobertD likes this.
  15. Feb 8, 2023 at 5:59 PM
    #2115
    DFW
    2021 Limited 4x4
    With my setup do I need bump stop extensions?
    HappyTraveller likes this.
  16. Feb 9, 2023 at 2:02 PM
    #2116
    SAGE63
    San Diego County
    just the thick washers that should have come with the shims...
  17. Mar 25, 2023 at 5:03 PM
    #2117
    TimS458
    TimS458 New Member
    2012 Barcelona Red TRD Off-road
    Here's my setup! 6112/5160 with the fronts on the top setting with 2 Coachbuilder shims on the driver's side and one passenger, Freedom Off-road UCAs, Toytec diff drop and carrier bearing drop, and soon Pro Form Fab lift shackles (if they ever ship). 17x8.5 +35 AlphaEquipt Echos and 37x12.5r17 Kanati Trail Hogs. Very little rub on the driver side fender liner, but not much.
  18. Mar 25, 2023 at 8:12 PM
    #2118
    COTundra23
    COTundra23 New Member
    i’ve had both. Both are great systems and provide a great ride. find which one you can ever get cheaper and let ‘er rip.
  19. Mar 27, 2023 at 5:26 PM
    #2119
    txtundra311
    txtundra311 New Member
    any regrets for going with 6112 & 5160 over something like trd pro fox suspension?
  20. Mar 29, 2023 at 4:38 PM
    #2120
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    -6112s @ 2.5”
    -Icon RXT leaf packs 1.75” lift
    -285/75R18 Wrangler Duratracs
  21. Apr 16, 2023 at 7:24 PM
    #2121
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    6112 on lowest .75” setting. I measured approximately 1.25” of lift. I have about a 1.25” rake, it’s perfect for me. It’s rides a lot better, very happy.
  22. Apr 19, 2023 at 8:49 PM
    #2122
    AG Tundra Lean
    AG Tundra Lean New Member
    Dustin
    2021 AG SR5 CM TRD offroad
    6112/5160 combo, Method MR 305 18x9, Falken Wildpeak AT3W 295/70/R18
    So, I started out with a cheap 2" leveling spacer with a .5" coachbuilder shim for the lean up front and I had a set of coachbuilder +1 shackles in the rear. This had me sitting with a 1" rake and only about 1/8" lean. Pretty perfect I'd say. But it did have a slight rub on the body mount when at full lock in reverse. And if I did any off roading it would frequently rub. Here's what that looked like.
  23. Apr 19, 2023 at 8:49 PM
    #2123
    AG Tundra Lean
    Dustin
    So I decided it was time to upgrade. And I wanted the improved performance and ride quality I read so much about in this thread. And of course, I wanted to eliminate the rub. So I purchased the 6112s pre assembled at 2.5; figuring that should lift the front .5" from where it already was. Turns out it somehow lifted the front close to 1.5 inches and increased the lean to about 3/8". So now I'm sitting 3/8" high in the front. So I'm going to lower the 6112s to the 1.9 setting and see what that looks like and also add a .25" shim to the driver's side. Here's the current look. I think it looks level, but I know it's slightly nose high.
  24. Apr 20, 2023 at 12:22 AM
    #2124
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Your bank account won't regret it!
  25. Apr 21, 2023 at 1:53 PM
    #2125
    GreatWhiteGax
    GreatWhiteGax New Member
    2016 SR5 Silver
    Leveling Kit, Wheels & Tires
    Lookin to do the same set up, except run the Icon RXT option 2 since I got about 415 lbs constant load in the back. What shocks you running in the back with your RXT leafs? Stock?
  26. Apr 23, 2023 at 8:19 PM
    #2126
    AG Tundra Lean
    Dustin
    Got it dialed in I think. The stock coils were definitely compensating for some lean right from the factory. I think my truck has more than average. I ended up having to set the passenger side at 1.3 and then set the driver's side to 1.9 plus 3/4" worth of coachbuilder shims to end up with no lean on a full tank of gas. Now with the CB +1 shackles in the rear, I have a 5/8" rake and no rub on my 295/70-18 Falken AT3Ws on Method NVs with +25 offset. I only got one crappy cell pic after finishing it up today.
  27. Apr 25, 2023 at 7:11 AM
    #2127
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
  28. Apr 25, 2023 at 11:45 AM
    #2128
    Whole EnchiTUNDRA
    Whole EnchiTUNDRA New Member
    2015 SR5 Crew Max
    Did the same except Toyo Open Country 2.
    Had to push the front liner on the stock bumper and still have a slight rub at full lock on the body mounts. New bumper took care of the front but will have to chop the mounts.
  29. Apr 25, 2023 at 4:19 PM
    #2129
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    @Whole EnchiTUNDRA did you try aftermarket upper control arms and increase your caster? That, in combination heat-gunning the rear fender liner, worked for me.
  30. Apr 25, 2023 at 6:23 PM
    #2130
    Whole EnchiTUNDRA
    2015 SR5 Crew Max
    No, I haven't looked at that. The rub is right on the corner of the body mount. Hoping an alignment might move it forward now that the bumper is out of the way. New UCA's aren't in the budget, but..... What UCA did you go with?
