  1. Mar 20, 2023 at 9:13 AM
    So it's a big stick on sheet? that pretty cool. Or do you spray the stuff on and then cover it with the sheet?
    TaquitoBandito and Rgross2112 like this.
  2. Mar 20, 2023 at 9:16 AM
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    It’s made by Dumond, it’s like a white paste you put about a 16th to 1/8 of an inch thick with a roller then you put that sheet over it to slow the drying process, then around 24 hours later you pull it off, a lot of times it comes off with the sheet or with a putty knife,
    More than likely there’s lead in this paint and I was figuring a way out to remove it without getting it airborne and this was the recommended way
  3. Mar 20, 2023 at 10:54 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That is really cool. And the natural wood looks amazing. One hell of a project.
    TaquitoBandito likes this.
  4. Mar 20, 2023 at 12:31 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Re-coating my teak tops..
  5. Mar 20, 2023 at 6:35 PM
    snomoman
    snomoman New Member
    North Aurora, IL
    288F24BB-449E-4D80-8416-0F0A8F153BAE.jpg 629DF974-9FCE-4BA7-81D5-D3C4EF028EC7.jpg F837CE2A-48FB-4DFF-BA15-70AED9A11AA4.jpg
    The ceiling was a whole other project in itself, we took down some cherry trees in the backyard, had them cut, milled and kiln dried and this is what we came up with for the ceiling, it’s a tongue and groove system with beveled edges, I had a master carpenter help me with this
  6. Mar 20, 2023 at 7:21 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    You might want to paint the A/C vent can with some flat back before you put the grill on. You wont regret it.
  7. Mar 22, 2023 at 5:01 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Really dig those farmer sinks. :thumbsup:
  8. Mar 22, 2023 at 5:04 PM
    BlueRibbon4x4
    Geno
    Built and installed range hood for the first time yesterday. Had to be built to spec for their current hood. Skinned with 1/4” drywall.
    45360A23-2637-491B-8282-99C4DBC5C21F.jpg 225A4455-30D4-407E-BB04-0C69CC7AD563.jpg
  9. Mar 22, 2023 at 6:21 PM
    bfunke
    bfunke Tundra Curmudgeon
    How do you put the sheet rock over the curves?
    BlueRibbon4x4 likes this.
  10. Mar 22, 2023 at 6:27 PM
    TaquitoBandito
    Joel (AKA Bif)
    FrenchToasty and Fotnot[QUOTED] like this.
  11. Mar 22, 2023 at 6:31 PM
    TaquitoBandito
    Joel (AKA Bif)
    I switched out a few old fans with some Panasonic "remodel" fans recently and had really good luck with them.
  12. Mar 22, 2023 at 7:05 PM
    BlueRibbon4x4
    Geno
    I used 1/4” drywall, and let it soak for about an hour. It eventually sags enough to be pressed into it’s shape.
  13. Mar 22, 2023 at 7:49 PM
    BlueRibbon4x4
    Geno
    Dang!! I had a buddy who had a telescope half that size and we saw everything. I can’t imagine what that thing can do. :thumbsup:
  14. Mar 22, 2023 at 8:11 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Oh I haven’t heard that method before. I know you can score the back paper at like 1” increments and then float some mud to smooth out the front once it’s laid.
    looks great though. Nice job
  15. Mar 22, 2023 at 8:59 PM
    BlueRibbon4x4
    Geno
    Thanks!
  16. Mar 25, 2023 at 4:01 PM
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    FBEB3084-F17D-4CF4-A1E8-5CE2DD4BF241.jpg C1FFA49B-4D85-46EE-9584-4BE813161A8E.jpg My desert trailer got kicked out of the garage to make room for my wife’s new car. I had our contractor come over and move our fence 8 feet forward. It’s a tight fit, but it works!
  17. Mar 25, 2023 at 4:14 PM
    snoope
    snoope The Old Man
    Beautiful RX :cool:
    And that gas meter and line will be gone soon so that "Snug fit" will be a 'Lil roomier :boink::boink::boink:
  18. Mar 25, 2023 at 4:24 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I guess it might qualify as a home improvement so here goes. I cleaned ALL my tile grout today using Clorox Gel Toilet Bowl cleaner and my new McCullough steamer. The job was actually manageable for the first time ever. Don't get me wrong it's still a PITA but not as bad as before.
    TaquitoBandito and Fotnot like this.
  19. Mar 25, 2023 at 4:49 PM
    drobb
    Thanks…. The RX is nice!!!! The gas meter actually isn’t in the way. I back the trailer up to the fence and then wheel the trailer in by hand from there.
  20. Mar 26, 2023 at 2:33 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Sounds like a lawnmower. You can have a conversation standing next to it.
  21. Mar 26, 2023 at 6:56 PM
    snoope
    snoope The Old Man
    Finally took pix of these two " at work ":cool:
    These are gifts from Con's parents and survived "Ian" :thumbsup:
    After a "Litle bit " of work and a wire brush... life has come back to them..
  22. Mar 26, 2023 at 7:19 PM
    TaquitoBandito
    Joel (AKA Bif)
    Nice job @snoope - those are awesome
    FrenchToasty and snoope[QUOTED] like this.
  23. Mar 26, 2023 at 7:24 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    KIMG2034.jpgCleaning up a downed live oak
  24. Mar 26, 2023 at 7:58 PM
    Tom
    Tom New Member
    I moved the pile of stuff from one side of my garage to the other side.
  25. Mar 27, 2023 at 4:40 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Mowed the back lawn. Enjoying a cool one as I test the deck fire.
    Prostar 190, Fotnot, drobb and 4 others like this.
  26. Mar 27, 2023 at 4:55 PM
    NWPirate
    Zach
    WA
    Great beer. :thumbsup:
    You guys are mowing on the Wet side already!?
    I still have a little snow left, lol
  27. Mar 27, 2023 at 4:59 PM
    Ya, no shit lol
  28. Mar 27, 2023 at 6:11 PM
    TaquitoBandito
    Joel (AKA Bif)
    Costco has toilet seats on sale so I replaced all four.
    Sidenote: I really need to work on my aim when I get up to pee in the middle of the night. :anonymous:
    snoope, Azblue, NWPirate and 3 others like this.
  29. Mar 27, 2023 at 6:32 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    If you don't lift the seat, she'll clean it up out of respect.
    #powermove
    Follow me for more relationship advice
    JMB, snoope, Prostar 190 and 5 others like this.
  30. Mar 27, 2023 at 6:34 PM
    Just leave the seat up. I can’t quite grasp why leaving the seat up isn’t acceptable. Just put the seat in the position you need it. Why do I have to pre-position the seat for the next potential user? A mystery. Of course I don’t leave the seat up in my house, lest the hounds gain additional watering sources.
