  1. Mar 25, 2023 at 8:57 AM
    Nice! Question for you: How'd you get your holes so clean in the gussets you center-punched for drill out? They look perfect, deburred, clean-beveled, and no sign of how it was done.
    RUSTYNUTS and FrenchToasty like this.
  2. Mar 25, 2023 at 9:18 AM
    Never had Chevy in my Garage before. Helping my friend replace both CV axles, front brakes, and all diff/TCase fluids. His 05 Silverado is nearly mint with 80k miles.
    His axles are a different design so they are extremely easy to swap.
  3. Mar 25, 2023 at 9:44 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    mini-mill and a step bit. I had to flip them because the steps were a little short…F726A9DD-4394-4660-ADFD-CBC0F2B021B6.jpg
  4. Mar 25, 2023 at 9:46 AM
    Are you actually measuring and moving your mill per measurement or just centering the bit on your scribe marks?
  5. Mar 25, 2023 at 9:54 AM
    alb1k
    Left Coast
    It's good
    I’m centering on the little punch marks. With the power off I drop the chuck and turn the chuck backwards by hand holding some down pressure. Makes a new mark/pocket onsite or at the punch mark. When I raise it I look carefully to see if the bit moves in any direction. I’ll clock the bit and check from the front and side as I pull down with gentle pressure and raise again. Let me know if that doesn’t make sense, I can better illustrate it.
    Sunnier and FrenchToasty[QUOTED] like this.
  6. Mar 25, 2023 at 9:55 AM
    Makes sense to me! Wish I had some more precision tools like that!
    at work usually I’ll set it with a punch, then hand drill a 1/8” pilot, go to the drill press, get it close in a similar fashion as you, and then just send it and let it self center hahaha
    Sunnier likes this.
  7. Mar 25, 2023 at 10:08 AM
    alb1k
    Left Coast
    It's good
    I do the freehand punch, 1/8” pilot, drill usually with oil all the time if it’s getting a bolt or grommet or something. The power tools I use all the time for making stuff are that 2x72 belt sander you saw, the mini mill, 9” disc grinder, porta band in a vice.
  8. Mar 25, 2023 at 10:10 AM
    Hopefully you have some mediocre drill bits;)
    9” disc grinder? Like bench mounted or a actual hand grinder? That’s a big boy!
    Sunnier likes this.
  9. Mar 25, 2023 at 10:30 AM
    alb1k
    Left Coast
    It's good
    When I was making knives, I got the ultimate mounted disc grinder.. and I was lucky enough to know a crazy good machinist who made me two steel discs that are perfectly true and balanced. You can’t find those off the shelf
  10. Mar 25, 2023 at 10:34 AM
    alb1k
    Left Coast
    It's good
    I have china bits from Costco or Amazon that I treat as disposable…..the bigger ones I might resharpen, but ya, lol
  11. Mar 25, 2023 at 10:36 AM
    I’ll try and round up some sheeters before Sedona for you
    alb1k[QUOTED] likes this.
  12. Mar 25, 2023 at 10:53 AM
    alb1k
    Left Coast
    It's good
    Yew!
  13. Mar 25, 2023 at 11:50 AM
    Apparently GM doesn't put a drain plug on the rear differential. You have to remove the entire cover. :rolleyes:
    KNABORES and Mr.bee like this.
  14. Mar 25, 2023 at 11:51 AM
    You could suck it out? Where’s the fill plug?
    Jack McCarthy likes this.
  15. Mar 25, 2023 at 12:01 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    yeah that's standard practice for the big 3. Fords are the same way, so are Dodge. Most of the axles are made by Dana anyways.
  16. Mar 25, 2023 at 12:01 PM
    You need to upgrade to an aftermarket cover to “add” the drain plug.
    Or maybe drill your own? :notsure:
    DJenerated and FrenchToasty like this.
  17. Mar 25, 2023 at 12:21 PM
    In an odd place on the front side of the diff.
  18. Mar 25, 2023 at 12:45 PM
  19. Mar 25, 2023 at 12:55 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    You didnt get a pic of a clutch pack. Get a locker pleeb.
    txagg likes this.
  20. Mar 25, 2023 at 1:34 PM
    Hey! I have those same Wilton vise clamp pads.
    Meanwhile though, I sorted through the next batch of stuff to re-org in the basement and came across these fun finds. These all have to be at least 20 years old, probably more like 30. EDIT: OK, so Future Primitive is clearly more like 40. FUCK I'm getting old.
    And this one made me chuckle - someone gave this to me the 1st time I came to ATL.
  21. Mar 25, 2023 at 6:01 PM
    alb1k
    Left Coast
    It's good
    Wanna have a great time? Use your welder to heat bend your taking forever steel project., lol
  22. Mar 26, 2023 at 9:36 AM
    Rock Auto sent my coils quickly along with this sweet magnet.
    Walter White vibes.
  23. Mar 26, 2023 at 9:44 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Junkyard visit for a hood, fenders, if you feel like welding the core support isn’t terrible to replace. Pull the aprons back… or just pull it all and toss new panels on. Damage is all high so the frame rails should be straight still my 06 rails were straight as an arrow after it’s nasty wreck.
    shifty` likes this.
  24. Mar 26, 2023 at 9:45 AM
    empty_lord
    05 rollover special
    I’d do a return just to send that bitch back
    tacoguybill, txagg, shifty` and 2 others like this.
  25. Mar 26, 2023 at 10:03 AM
    You'll never be a meth kingpin with that attitude!
    txagg, shifty`, DJenerated and 2 others like this.
  26. Mar 26, 2023 at 10:42 AM
    alb1k
    Left Coast
    It's good
    Looks like practice helps. :anonymous:
    daveeasa, RUSTYNUTS, bmf4069 and 3 others like this.
  27. Mar 26, 2023 at 12:10 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Well damn brotha, color me impressed. You ever hook a bottle up to your machine? I mean, not sayin anything is wrong with what you're doin, but if you're doin that well with flux-core, you'd really make some pretty stuff with a gas shield.
  28. Mar 26, 2023 at 12:12 PM
    I’ve never welded with flux core, I wanna try it, had to do some stuff outside last week at work, and it looked like pigeon poop
    RUSTYNUTS[QUOTED] likes this.
  29. Mar 26, 2023 at 12:14 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Using wirefeed with gas outside?
  30. Mar 26, 2023 at 12:18 PM
    Hahahahhah yesssssss, I was repairing something facilities did last summer, not sure why they didn’t have to fix it. Ran her hot and hoped for the best!
