  1. Mar 25, 2023 at 7:41 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    This is awesome. I love the new grilles (compared to mine), but that OEM cover looks like hell. Your design makes it seamless. Nice job. :thumbsup:
    RobertD likes this.
  2. Mar 25, 2023 at 7:56 AM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Thank you!
    This is my 6th iteration, I've been playing with design size and materials. I wanted it to overhang the bottom by a few mm to match the style of the bottom row. That was a little problematic with printing and the ABS warping, so in the end I just printed without the gap and used a hack saw to trim, which worked really well.
    It is far from perfect, there is about a 2-3mm gap at the top. If I do a 7th iteration I might address that.
    My biggest challenge will be trying to match the paint. I hastely painted one before and the temps were not great amd I rush laying the paint on too thick. I'm trying to decide between a matte finish or satin however we just got a 11" of snow this morning so that will need to wait
  3. Mar 25, 2023 at 8:03 AM
    BlueRibbon4x4
    Geno
    I see what you’re saying about the gap, and appreciate your attention to detail. Even close up it looks really good. Matte clear may have a little different sheen to matte black paint. If you can’t get it perfect, lower sheen matches better than higher. I’d suggest flat black with matte clear, based on the pic.
    RobertD and Voda48[QUOTED] like this.
  4. Mar 25, 2023 at 8:07 AM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    That is what I was planning to paint with next. I'm also going to fill in the small groves on the top to smooth out the look.
    BlueRibbon4x4[QUOTED] likes this.
  5. Mar 25, 2023 at 8:11 AM
    BlueRibbon4x4
    Geno
    Nice! Looking forward to the results.
    Voda48[QUOTED] likes this.
  6. Mar 25, 2023 at 8:11 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    If it was printed in ABS, why didn't you try the acetone vapor trick for smoothing?
    Disclaimer: I'm only 3d printer curious, but I've read a ton on the subject.
  7. Mar 25, 2023 at 8:21 AM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    1) I'm newer to 3d printing (just bought it end of January) and this is my first print in ABS
    2) I've had a bad experience with acetone in the past, but that was really from me being an idiot
    3) I know I can easily fill sand and paint and get good results.
    I might consider giving it a go however. The biggest challenge will be time and temps. Kids activities and all
    BlueRibbon4x4 and RobertD like this.
  8. Mar 25, 2023 at 8:24 AM
    Trentimus
    Trentimus New Member
    Trent
    2019 Tundra Off Road
    Nfab bars, undercover armor cover, hottails
    It’s not technically padded, but it’s so thick and fluffy compared to the factory one. Well worth paying the premium over a cheap Amazon or EBay cover.
    As soon as my Katzkin went on, I knew. :spending:
  9. Mar 25, 2023 at 8:52 AM
    SwitchThrottle
    Maybe try it on one of the previous attempts just to see what happens? That way you don't screw up the last one.
  10. Mar 25, 2023 at 8:59 AM
    SwitchThrottle
    How many miles on it? Belt and heads done?
  11. Mar 25, 2023 at 11:05 AM
    S13ka24de
    S13ka24de New Member
    4 resonator to see if i can get drone out...lol
  12. Mar 25, 2023 at 11:09 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    :eek: :)
  13. Mar 25, 2023 at 11:25 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    That thing wouldn’t last one outing on my truck lol. Hopefully it works!
  14. Mar 25, 2023 at 11:33 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Not a Toyota, but a good (some are still made in Japan) Japanese car.... Good choice :thumbsup:
  15. Mar 25, 2023 at 12:00 PM
    S13ka24de
    No it doesnt sounded like it has more drone than before i did t÷ 2 back resonator........with the 2 in front it was ok. But now i added 2 to the back it seems like it more drone. Nothing else i can do now...switch back n lost a ton of $ or leave it...lol
    reywcms[QUOTED] likes this.
  16. Mar 25, 2023 at 1:03 PM
    1794TX
    Steven
    N.TX
    '20 1794
    You might benefit from a quick word or two from Keith @dirtydeeds
    Dirty Deeds Industries | Toyota Tundra Forum (tundras.com)
  17. Mar 25, 2023 at 2:49 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  18. Mar 25, 2023 at 3:37 PM
    DTund18
    DTund18 New Member
    2018 Tundra Limited
    Installed Prinsu camper shell rack, next up cab rack. 82E47B93-C0CB-4E4B-8662-821839A4C6D1.jpg
  19. Mar 25, 2023 at 4:31 PM
    V3N0M
    V3N0M New Member
    Orange County, CA
    2020 Tundra SR5 Crewmax
    - Carven Type R Exhaust - TRD LED Headlights - (2) LED Ditch Lights Mounted on Hood - Cali Raised Ditch Light Brackets - (2) 42” LED Light Bars Behind Grill - Cali Raised Hidden Grille Mounting Brackets - AJT Interior Chrome Delete - AJT V3 Shift Knob - 8" ReadyLift w/ Bilstein 5100's (all around) - 18" Raceline 948B Split Wheels - Toyo Open Country MT 37 x 13.50 R18 - Amp Research Power Steps
    Installed the Carven type R exhaust
  20. Mar 25, 2023 at 4:32 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    vacuumed out a cup and a half of sand from the beach. empyed most of of the gear from the truck bed. hope to wash it tomorrow!
    bulldog93 and AGTundra like this.
  21. Mar 25, 2023 at 5:45 PM
    Tiger85
    Tiger85 New Member
    2025 Mag Gray Platinum i-Force MAX
    Did the GM diode mod for charging my AGM battery. Still only showing 13.7 volts after the swap though....
    bulldog93 likes this.
  22. Mar 25, 2023 at 5:52 PM
    Florida AF
    Logan
    North Florida
    Tested the Edge Insight3 for another user on here, took my neice to a tournament... enjoyed ALL the windows being opened... Day 2 was a success.
  23. Mar 25, 2023 at 6:09 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Installed this Body Armor Highline bumper on this 2019 SR5. Winch to come.
    Pretty stout! Looks good imo.
  24. Mar 25, 2023 at 6:32 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    Did you drive it around? Have a photo of the fuse box?
  25. Mar 25, 2023 at 7:22 PM
    Taco-Spike
    Two Trucks
    Clazzio Front seats done. Cut in switch panel and relocated rear window. Still need to wire the heated seats and Install rear seats.
    5CDC35F2-BF64-4BB8-889F-BA9D9BE062DE.jpg 9C8C1836-3B9F-43D2-943F-9711DD787DE2.jpg 9C2C8D74-FF8A-4DFE-B103-B71552905E1C.jpg 0B658155-CAA3-43FB-ACCF-259081612D47.jpg
  26. Mar 25, 2023 at 7:23 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well done. Love that switch placement!
  27. Mar 25, 2023 at 8:10 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Reverse its direction. See if that works. I put mine in backwards but I can’t remember what the voltage was when I realized it was backwards.
  28. Mar 25, 2023 at 8:37 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If you put it in backwards you’ll have a bunch of dash lights and know it’s in wrong (twss?)… ask me how I know
    WVI, bulldog93 and NewImprovedRon like this.
  29. Mar 26, 2023 at 12:04 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    We’ve had good luck with them. Have three (foresters) in the driveway right now.
  30. Mar 26, 2023 at 5:32 AM
    Tiger85
    Tiger85 New Member
    I just started it in the driveway so I didn't get the RPMs up. I'll drive around today and monitor it.
    I put it in wrong initially because I got the battery light on the dash so then reversed it and no more battery light.
