Tires sizes for 2020 ?
Discussion in 'Wheels & Tires' started by vsantoro, Mar 20, 2023.
  1. Mar 20, 2023 at 10:38 AM
    vsantoro
    vsantoro [OP] New Member
    vic
    2020 Gray Tundra TRD PRO
    ahh ok I see. So if I want a P rated tire I cannot get 285/70R18. That definitely limits what i can get.
    PermaFrostTRD likes this.
  2. Mar 20, 2023 at 11:48 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    correct. But put them next to each other, the 70 series looks bigger
  3. Mar 20, 2023 at 12:20 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    x2 vote for the MT Baja Boss ATs... I don't believe they are making a 285/70/18 in them yet, so that leaves you w/the 295/70s or the 275/70/18s....
    If you don't want rubbing issues or having to deal w/your speedo being off by 5-6mph, I'd go with 275/70s :thumbsup:
  4. Mar 20, 2023 at 12:51 PM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    That Grabber in 275/70r18 is a unicorn; only one I see in that size that is standard load. Cheap too, only ~$250/ea. Check what reviews say on different sites. Falken AT3W 285/65r18 comes in standard load too, but costs a fortune for some reason. Also in lieu of better info, speed rating for a particular tire size isn't a bad proxy for rolling resistance. If you do decide to go for an LT, get one with an "S" speed rating or higher.
    vtl likes this.
  5. Mar 20, 2023 at 1:54 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    About half of trucks I see in Maine forests are Tundras on Grabber AT/X. This is actually how I learnt these tires exist ;)
    They are good at highways speeds, too. Getting from Boston area to NW Maine wilderness in my older Volvo on KO2s was a nightmare - very loud. Not sure it's KO2 or frame-less Volvo... Tundra+Grabbers combo is quiet.
    I wanted to convert to narrow Falkens, to an "almost 35" size (to keep stock UCAs) to get a better ground clearance in snow, but then I bought a winch and don't feel I want bigger tires anymore.
    rruff[QUOTED] likes this.
  6. Mar 20, 2023 at 2:07 PM
    rruff
    rruff New Member
    You don't even need a lift for 35s... really. Guessing you are talking about 285/75r18 and you mean UCAs? Those are actually larger diameter than the tires called "35x" which are typically only 34.6". 35 to the nearest inch I guess... :rolleyes:
  7. Mar 20, 2023 at 2:12 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Right, UCA. I forgot which 35 tire I was looking at, in tirerack specs sheet, but I subtracted 35's width from my 33's, divided by 2 and that was how much space I needed between the rubber and UCA. This space requirement was more than I measured on my truck. Looking at Falken's spec sheet, they would fit.
  8. Mar 20, 2023 at 2:18 PM
    rruff
    rruff New Member
    People mount 285/75r18 on stock rims and they work fine. The UCA wouldn't help you anyway, you'd need a rim or spacer to move them outboard a little if you had UCA clearance issues. 295/70r18 works on stock rims too.
  9. Mar 20, 2023 at 2:29 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Spacers are illegal in Massachusetts. Don't want to change the wheels just to fit a fatter tires. Falkens were a good candidates for all stock, but really the winch killed the whole 35" idea. Maybe I still get them, for better traction spot when aired down, but Grabbers are only 20k miles.
  10. Mar 20, 2023 at 4:13 PM
    LVM8
    LVM8 New Member
    NY
    2024 Tundra Limited 4X4 - TRD OF - MGM
    295/70/18 - Wlidpeaks - 2020 TRD Pro - stock suspension. Went with the Wildpeaks because I’m in CNY, good in snow and have a mileage warranty.
  11. Mar 20, 2023 at 4:27 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Looks good. How bad is your MPG?
    LVM8[QUOTED] likes this.
  12. Mar 20, 2023 at 5:32 PM
    LVM8
    LVM8 New Member
    NY
    I’ve only had them on for a couple of days now and noticed that each trip I take is down round 1 MPG. I normally get 14.5 and I’m at 13.7 after 2 days. I’ll update after the full tank and see overall how MPG changes.
  13. Mar 20, 2023 at 9:15 PM
    Tripleconpanna
    Looks good; we don't see that size come up in discussions that often. You should post of few more photos showing a head-on view (poke) and a side-on view (wheel well and height)...
  14. Mar 20, 2023 at 9:49 PM
    rruff
    rruff New Member
    Probably an error. I don't see 295/60r18 in any searches, and it would be slightly shorter than stock.
    Tripleconpanna likes this.
  15. Mar 21, 2023 at 1:27 AM
    LVM8
    LVM8 New Member
    NY
    Yes, my mistake - 295/70/18
  16. Mar 22, 2023 at 6:17 AM
    cpa357
    cpa357 New Member
    Hey Everyone. I just bought a gray TRD Pro 2020 on Monday. How much modification is required to run 295/70/18s without rubbing? Can it be done with the current suspension. If not will 295/70/18s work without changes?
    Would consider changing UCAs to accommodate 295s?
    Thanks in advance.
  17. Mar 22, 2023 at 8:22 AM
    rruff
    rruff New Member
    Very little, and your current lift is more than enough.
  18. Mar 24, 2023 at 2:41 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Sorry Vic, I some how missed this. Usually I don’t. Lol. Yes 21 is the same 2020. Nitto ridge grapplers. Not my first set had them on my 4runner Pro. No rubbing at all with 285/70/18 tires on the stock wheels. I’m going to try and get my tires mounted this week on my SCS wheels. That will change the look. I may also be removing my westcott lift because I don’t plan on jumping up to 35’s. Happy with the tire size I have.
