Dasaita vivid11 in 2017 Tundra SR5
Discussion in '2.5 Gen Tundras (2014-2021)' started by PhuckEwe, Mar 8, 2023.
  1. Mar 14, 2023 at 6:27 AM
    PhuckEwe
    PhuckEwe [OP] New Member
    2017 Black DC Tundra SR5
    Working on it
    It’s set to the setting everyone in there was saying worked
  2. Mar 14, 2023 at 6:29 AM
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    id scroll thru and pick thru them. mine was totally different from they said. took me a few days to get everything working, was a pain
  3. Mar 14, 2023 at 6:35 AM
    PhuckEwe
    Working on it
    Sure I’ll try that…however whatever the problem was that began with the new head unit is now doing the same exact things with the old head unit despite swapping it back and the canbus with that one that worked fine prior to.
  4. Mar 14, 2023 at 8:34 AM
    Rocko9999
    Rocko9999 New Member
    How does the HU deal with the lower impedance speakers? It doesn't overheat?
  5. Mar 14, 2023 at 9:29 AM
    PhuckEwe
    Working on it
    So messing around thinking either back speakers are blown or it’s something else. Checked every fuse I could think off short of pulling every fuse under the dash and physically looking at them. Front doors have some to them it may be time to replace. However can ANYONE at all tell me what would cause the door beep to suddenly go away and then not return when headunit is changed back to previous one? Tonight I very well may put the Dasaita back in
  6. Mar 14, 2023 at 10:13 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I did get the headunit to overheat, once, after playing my stereo at near-loudest volume on a road trip for 3+ hours. The factory "amp" might as well be made of dirt and water, for all the muddy audio it outputs. I'll trade not being able to blare at max volume for long periods of time, for overall much better quality.
    Funny story, doing that also popped my passenger-side front door speaker, and it now buzzes a little, I'll have to replace it, darn. =) If it can blow the OEM speakers, it's probably doing its job just fine.
  7. Mar 14, 2023 at 10:26 AM
    Rocko9999
    So your HU is utilizing the OEM amplifier?
  8. Mar 14, 2023 at 10:29 AM
    MedCityMoto
    See the weird thing here about this to me is, both the front and back door speakers stopped working simultaneously. The Dasaita headunits default to starting at low-nearly-silence audio levels, so it wouldn't have completely blown out your speakers just starting up the first time. Something's up.
    I recommend replacing (don't check - replace - fuses are $0.15) replacing the 15A Radio fuse and maybe the Panel one.
    https://www.tundras.com/threads/fuse-block-location-for-2018-tundra.27830/#post-1459509
  9. Mar 14, 2023 at 10:29 AM
    MedCityMoto
    Nope. Eliminated it and removed it from the truck. Sitting on a shelf.
    Rocko9999[QUOTED] likes this.
  10. Mar 14, 2023 at 10:43 AM
    PhuckEwe
    Working on it
    I’ll give that a go. Bypassed not sure if it did anything or not but I’ll figure it out
  11. Mar 14, 2023 at 11:06 AM
    PhuckEwe
    Working on it
    That may be it as well. Super low didn’t catch it but rears may have been blown for years and I didn’t notice
  12. Mar 21, 2023 at 6:43 AM
    stirul
    stirul New Member
    Gas
    I am interested to see some pictures of this new model of head unit installed. This is by far the best looking option if the photos on the Dasaita site are accurate.
  13. Mar 21, 2023 at 9:13 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    DId you get this working?
    I'm a little confused about what you have and haven't done.
    There is indeed a fuse for your OEM amp under the hood and it sounds like it's blown.
    My 2014;
    The reason you hear the dash speakers are that they are directly powered by the HU.
    The door speakers go thru the under seat amp.
    It sure sounds like that amp isn't getting power.
    Keep in mind you don't have a rear speaker #2 because you have a double cab
    If you had a crewmax you'd be hearing the tweeters in the rear doors, as they are also powered by the HU...
    upload_2023-3-21_11-10-3.jpgupload_2023-3-21_11-10-23.jpgScreenshot_2023-03-21_111644_7d3cb8dde1bdb0254d33f0a5ca100266dd2f4094.jpg
    As @MedCityMoto suggested, you could certainly bypass your OEM amp using the adapter posted earlier.
    Just connect the speaker wiring output from the HU to the input of the door speaker wiring under the front seat.
    This might help you with that bypass.
    J144 (Smaller factory amp harness) 7 wires
    Pin 1 - Front Right Output to Speaker (+) - Light Green
    Pin 2 - Front Left Output to Speaker (+) - Violet
    Pin 3 - Accessory/Switched 12v [Remote In] - Sky Blue
    Pin 4 - 12v Constant [Power] - Red
    Pin 5 - Front Right Output to Speaker (-) - Blue
    Pin 6 - Front Left Output to Speaker (-) - Pink
    Pin 7 - Ground - White and Black (NOTE: The factory wiring diagram says that ground is Pin 9, but I confirmed that Pin 7 is actually the ground. It is a white and black wire. )
    J145 12 wires
    Pin 1 - Front Left Signal (+) - Brown
    Pin 2 - Front Right Signal (+) - Pink
    Pin 3 - Rear Left Signal (+) - Light Green
    Pin 4 - Rear Right Output to Speaker (+) - Red
    Pin 5 - Rear Left Output to Speaker (+) - White
    Pin 6 - Front Left Signal (-) - Beige
    Pin 7 - Front Right Signal (-) - Gray
    Pin 8 - Rear Left Signal (-) - Black
    Pin 9 - Rear Right Signal (+) - Blue
    Pin 10 - Rear Right Signal (-) - White
    Pin 11 - Rear Right Output to Speaker (-) - Violet
    Pin 12 - Rear Left Output to Speaker (-) - Green
    Rocko9999 likes this.
  14. Mar 21, 2023 at 4:07 PM
    PhuckEwe
    Working on it
    BoysandHisToys likes this.
  15. Mar 21, 2023 at 4:08 PM
    PhuckEwe
    Working on it
    I got it sorted. The stereo connector came loose. However nothing out the rear speakers it sounds somewhat like it did with the pioneer. Needs better tuning and will be doing the upgrade from ********* shortly after work chaos slows. Pretty sure I blew the rear speakers years ago and never noticed
  16. Mar 21, 2023 at 4:37 PM
    PhuckEwe
    Working on it
    None of your colors match to the harness ordered to bypass. Small from factory hookup into amp for harness to bypass white, white/black, grey, grey/black, black, black, red, yellow
    bigger harness
    White, white/black, grey, grey/black, 2 sets purple, purple/black, 2 sets green, green/black
  17. Mar 21, 2023 at 4:46 PM
    Rocko9999
    Are most people happy with this head unit?
  18. Mar 21, 2023 at 4:50 PM
    PhuckEwe
    Working on it
    I am content currently. It’ll be better once I upgrade the stock speakers and amp. I did have to get the car play inline usb thing and download autokit for car play to work properly but small price. Once I tune it post upgrade I’m sure I’ll be completely happy. It does have some weird things autoprogrammed such as “you have been driving for 2 hours maybe take a break?” Pop up which I just hit dismiss to. But 2.5 hr drive where the double din pioneer which filled the whole dash would overheat and reset a few times it didn’t do that once.
  19. Mar 21, 2023 at 4:55 PM
    Rocko9999
    Does it not come stock with wireless Carplay?
  20. Mar 21, 2023 at 4:57 PM
    #50
    PhuckEwe
    Working on it
    I couldn’t get it to do it properly. And I keep mine hardwired. I’m driving don’t need my phone in my hand. Plus it uses my gps from phone ‍♂️
  21. Mar 23, 2023 at 6:00 AM
    #51
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
  22. Mar 23, 2023 at 6:01 AM
    #52
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    once u start with tuning, holy shit, my lowest volume was loud lol. i still have to mess with it more
  23. Mar 23, 2023 at 8:22 AM
    #53
    Rocko9999
  24. Mar 23, 2023 at 9:44 AM
    #54
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    steering controls worked, no issues there. i didnt want a wired android so i had gotten the ma1 for a good deal used that from the beginning,
  25. Mar 25, 2023 at 2:27 PM
    #55
    Jesus
    Jesus New Member
    Jesus
    2014 TRD TUNDRA
    Stock just got it
    @PhuckEwe
    how do you like the stereo so far? Any complains or issues with it?
  26. Mar 25, 2023 at 3:35 PM
    #56
    PoppaGrizzly
    PoppaGrizzly New Member
    21 Tundra TRD OFF ROAD
    Mine did the same thing initially. I didn’t purchase a bypass harness, instead I purchased a harness for around $30 that was wired for the amplifier and tied it in. No issues almost 6 months later.
  27. Mar 25, 2023 at 3:39 PM
    #57
    PoppaGrizzly
    Yes. Every now and then it may cut out or act up. Every now and then I’ll have to do a quick restart and it will act fine.
  28. Apr 15, 2023 at 10:33 AM
    #58
    PhuckEwe
    Working on it
    It randomly gets stuck black screen on boot have to unhook battery and rehook up. And it works. Apparently it’s a vivid issue
  29. Apr 15, 2023 at 10:35 AM
    #59
    PhuckEwe
    Working on it
    Can you post a screenshot of your audio settings and I’ll give it a run I was going to get the ********* setup but that’s a down the road thing. Don’t want to mess with tearing doors off and wiring and putting back together currently with my work schedule. Nor do I want to pay someone to do it and tune everything being without my vehicle for however long.
  30. Jun 18, 2024 at 1:33 PM
    #60
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    im looking at the Dasaita unit as we type this.
    I also have bypassed my factory amp for this setup. Hoping the Dasaita works well when all done.
