General Supercharger Thread
  1. Mar 20, 2023 at 1:35 PM
    #6781
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I just screwed mine to the firewall on the driver side inboard of the brake booster. I didn't want a long vacuum/boost run, then the wiring under the booster and through the firewall along with all the other detritus that needs to go from the engine to the interior. I think that as long as you don't fix it to the exhaust manifold or coil pack, it'll be okay.¯\_(ツ)_/¯
  2. Mar 20, 2023 at 1:49 PM
    #6782
    snivilous
    SW UT
    300k+ Supercharged 2008
    Mine is bolted to the fender area right behind the hood strut.
    HulkSmurf14 likes this.
  3. Mar 20, 2023 at 2:00 PM
    #6783
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Thanks, where do I get the vacuum?
  4. Mar 20, 2023 at 2:03 PM
    #6784
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My blower has a port pretty much right there at the driver-rear corner.
  5. Mar 20, 2023 at 2:04 PM
    #6785
    e30cabrio
    I thought that was for the boost gauge. Cool!
    Saltyhero13 likes this.
  6. Mar 20, 2023 at 2:07 PM
    #6786
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Both occur there for your boost/vacuum gauge. Are you looking for for a vacuum source for something other than your gauge?
    Saltyhero13 and M3Tundra-JK like this.
  7. Mar 20, 2023 at 2:11 PM
    #6787
    e30cabrio
    Right now I'm trying to finish the Innovate PSB-1 install. I'll use that port, thanks!
    I mean trying to be ready to install it when I get my truck back tonight :p
    HulkSmurf14 and Wynnded like this.
  8. Mar 20, 2023 at 6:31 PM
    #6788
    e30cabrio
    It's done, just drove around the block, didn't really get to wot but saw 5.8.
  9. Mar 20, 2023 at 7:58 PM
    #6789
    snivilous
    SW UT
    Now tell me what the AFR number is when you're cruising :D
  10. Mar 20, 2023 at 8:16 PM
    #6790
    e30cabrio
    Criusing has been 13.5-14.5. The lowest I have seen is 9.8 for an instant at wot. If I get the pro deal can I get the Innovate info into the HP Tune reading?
    snivilous[QUOTED][OP] likes this.
  11. Mar 21, 2023 at 7:33 AM
    #6791
    snivilous
    SW UT
    You don't even need anything else, @ZPhilip figured out how to get HPT to read from the Innovate directly. Though you'd have to talk to him about how to do it.
  12. Mar 21, 2023 at 7:52 AM
    #6792
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Looks like you'll need to connect the Yellow wire to the blue or red wire on the prolink, then add the external input in the software. Also, make sure the ProLink is grounded as well.
    From Innovate Manual:
    Optionally, the YELLOW analog output can be connected to the analog input of other devices such as data loggers or standalone ECUs. If this wire is not being used isolate and tape it out of the way. The default analog output configuration is 0V = 7.35 AFR and 5V = 22.39 AFR.
    From HP Tuners forums:
    Under Channel Selector > External Inputs
    you'll see MVPI Pro, MVPI2
    MVPI2 Pro only has two analog inputs with the pro link. MVPI pro has four listed.
    Select MVPI2 > Pro Link
    if MVPI2 Pro link isn't visible try resynching your interface under Help section in vcm scanner. Afterwards make sure you are licensed with the Pro Feature Set in hptuners.com > My Account > My Devices
  13. Mar 21, 2023 at 7:59 AM
    #6793
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Wynnded, e30cabrio and Saltyhero13 like this.
  14. Mar 21, 2023 at 8:07 AM
    #6794
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That's pretty cool, so he added the gauge output as a serial input to his computer via usb adapter, and was able to see it in the software from there. Cheaper than the prolink for sure, and good to know.
    Silver17[QUOTED] and e30cabrio like this.
  15. Mar 21, 2023 at 8:08 AM
    #6795
    e30cabrio
    Thank you, gentlemen!
  16. Mar 21, 2023 at 1:03 PM
    #6796
    e30cabrio
    I am having a slow start issue after replacing the flex basket that had a small fpr in it with a non flex, can I use this FPR I have from a BMW (made by Ireland Engineering) If I can where does it go?
  17. Mar 21, 2023 at 7:01 PM
    #6797
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Correct, I did successfully get the PSB-1 to show up in the channel list and record the AFR in data logs. Without using the ProLink or any other hardware.
    Once I got a new serial to USB adapter (had an old adapter that was being problematic), I added the external serial input and got it to connect with some trial and error. The next issue was getting it to display in AFR units with 14.7 stoich. I dug deep on HPT’s tuning forum and came up with the formula below to get the units correct. Hope this helps.
    Wynnded, V10Ace, HulkSmurf14 and 3 others like this.
  18. Mar 22, 2023 at 5:45 AM
    #6798
    e30cabrio
    So I need to connect the rs232's wites to the PSB-1 out?
  19. Mar 22, 2023 at 6:46 AM
    #6799
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    This is what I've been scanning for with OTT
    snivilous[OP] and e30cabrio like this.
  20. Mar 22, 2023 at 6:51 AM
    #6800
    e30cabrio
    Guess a positive of being in IT since 1980 (went to Wang school, which was a waste of $ & time) is having pretty much every possible cable & connector.
    Is this all I need to connect?
    HulkSmurf14 and M3Tundra-JK like this.
  21. Mar 22, 2023 at 6:54 AM
    #6801
    M3Tundra-JK
    Scott
    2005 GX470
    Oi, high-five for the IT guy! I'm a data center engineer.
  22. Mar 22, 2023 at 6:56 AM
    #6802
    ZPhilip
    Philip
    West Chester, PA
    That is what I connected. The supplied serial Innovate cable and bought a USB adapter. I don’t know what rs232 wires are. I’m just a half assed driveway tinkerer.
  23. Mar 22, 2023 at 6:58 AM
    #6803
    e30cabrio
    The connector the USB cable is going to is called rs232, it's ancient tech.
  24. Mar 22, 2023 at 7:00 AM
    #6804
    M3Tundra-JK
    Scott
    2005 GX470
    Mostly for connecting to hardware console interfaces. Think of command line DOS stuff
  25. Mar 22, 2023 at 7:34 AM
    #6805
    e30cabrio
    I have these for PuTTY mostly. :p
  26. Mar 22, 2023 at 7:37 AM
    #6806
    e30cabrio
    I searched & don't see how to add the new scan parameter.
    Found this digging into it, what do I select?
    Hopefully I'm in the right place, how do I get the transform right?
  27. Mar 22, 2023 at 7:59 AM
    #6807
    e30cabrio
  28. Mar 22, 2023 at 10:43 AM
    #6808
    M3Tundra-JK
    Scott
    2005 GX470
    Need some help troubleshooting.
    OTT is seeing tiny fuel corrections all over the place, over and under. They aren't sure what's causing that. When I get back home, I'll swap back from the AEM FPR to the Evil Energy FPR and see if that does anything. What else should I be checking? He said at 5k RPM on my last run, I was only at 38% duty cycle on the 750cc injectors. Asked me to turn down the FPR from 60 to 45psi to see if that helps. But he thinks airflow or fueling related.
    I'm also going to order the SABM parts today for the maggy intake
  29. Mar 22, 2023 at 11:21 AM
    #6809
    Silver17
    Eastern PA
    I’m just here to speculate with no experience, but that could make sense that it’s just too much fuel. When using large injectors you’re utilizing a much smaller range of the injectors capabilities I could see it being more difficult to fine tune (worse resolution) and cause erratic fueling. If those injectors are rated at 750cc at 43.5psi, they will flow 880cc at 60psi.
  30. Mar 22, 2023 at 11:23 AM
    #6810
    M3Tundra-JK
    Scott
    2005 GX470
    I never thought about that part! PS injectors are rated at 715cc (purportedly 750cc) and their instructions say to set FPR at 60psi
    Saltyhero13 and Silver17[QUOTED] like this.
