DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Mar 14, 2023 at 4:37 AM
    #2521
    COTundra23
    COTundra23 New Member
    Question for you all. This individual I’ve been talking to has Pro suspension and coachbuilder shims up front… he’s able to fit 37s with rock warrior wheels. No wheel spacers, no BMC…
    Doesn’t seem like that much work but what do I know
    What are y’all’s thoughts?
  2. Mar 14, 2023 at 6:14 AM
    #2522
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    to fit 37/12.5/20 tires on 20/10/-19 rims, needed to do the following:
    SDHQ BMC, pinch weld, Viper cut fender, Coach Builder bumper shim, RC6” lift, SPC UCA,
  3. Mar 14, 2023 at 8:21 AM
    #2523
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    If you've read through the thread, it is definitely extremely rare that you can do this - although, that doesn't mean you can't.
    Body mount relocation can play a factor into this gentleman not needing a BMC.
    PWM, I only know of one person that runs 37 without this mod and that's @Vizsla.
    Pro suspension yields roughly 2" stock, so he's probably sitting at about 2.5" with shims. Rear, you can fit 37s without any sort of modifications.
    The only thing is that, I'm pretty sure he's gotta be running wheel spacers because the RW wheels are +55 which is going to pull the tire extremely close to the UCA. Also, KM3 runs a tad smaller than other 37s. Aside from that, it's probably minimal modifications that he's made to fit the 37s. May have played with his caster, may have trimmed bumper caps, may have added front bumper shims too.
    I think there is a guy (not sure if he's on here, but @king.cong.1119 knows the guy) that runs no lift with 37s.
  4. Mar 16, 2023 at 8:31 AM
    #2524
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  5. Mar 16, 2023 at 8:58 AM
    #2525
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    eccracer104 likes this.
  6. Mar 17, 2023 at 4:05 PM
    #2526
    Mrf1987
    Mrf1987 New Member
    2020 Trd sport tundra
    If anyone is interested drt-fabrication just went live with their body mount relocation for the 2nd gen tundras. Price is $275 and it is by far the most robust kit on the market! I’m not affiliated with them just spreading the word.
  7. Mar 19, 2023 at 5:57 PM
    #2527
    PaulROahu
    Paul
    Kaneohe, Hawaii
    had Dura Coating on my last 35” tires. Exoforma tire coating on my new 37”
    EvoTundra, C.I., coTony and 3 others like this.
  8. Mar 23, 2023 at 6:57 AM
    #2528
    king.cong.1119
    king.cong.1119 New Member
    Yea, friend of mine ran 37s with stock suspension, +25mm wheels, for a while when his shocks are getting rebuilt. He did have BMC so, that helped a lot.
  9. Mar 23, 2023 at 7:24 AM
    #2529
    Mrf1987
    Mrf1987 New Member
    First 2 of the 5 37’s showed up today.
    Toyo open country R/T Trails in 37x12.50R17
  10. Mar 26, 2023 at 8:09 AM
    #2530
    DPhung
    DPhung Measly Mechanic
    North AL
    2016 MGM Tundra CM
    Excited to see how it goes for you. Running similar setup with the JBAs.
  11. Mar 26, 2023 at 8:15 AM
    #2531
    TimS458
    TimS458 New Member
    2012 Barcelona Red TRD Off-road
    I know this is a 2.5 gen thread, but I'd like to submit my application to the Dirty Seven club!
    Setup:
    Bilstein 6112/5160 top setting
    2 Driver side Coachbuilder shims and one passenger
    Freedom Off-road UCAs
    Toytec Diff drop and carrier bearing drop
    Pro Form Fab lift shackles (if they ever get dropped off to USPS)
  12. Mar 26, 2023 at 8:50 AM
    #2532
    Shanet421
    San Diego,CA
    Love the look on the 2nd gen! Can you you share photos of the inside wheel well? Also tire/rim details?
    TIA
  13. Mar 26, 2023 at 9:04 AM
    #2533
    TimS458
    TimS458 New Member
    Here ya go! I used the SDHQ plates and they clear great. I might have to trim and hammer the pinch weld and massage the liner a bit, but I have noticed much, if any rubbing
  14. Mar 28, 2023 at 6:21 PM
    #2534
    Jonnynewton909
    Jonnynewton909 Jonnys_Tundra
    Jonny
    East Texas
    2017 Tundra CrewMax
    Accutune Fox DSC 2.5 front w/ SPC UCAs, Alcan custom spring pack and Accutune Fox DSC 2.5 rear. 37 Toyo RT Trails on Method 312s. SOB Fab F&R high clearance bumpers. AT Overland Atlas.
    Well, I finally took the time to install my LCS Fab Cab Mount Relocate bracket, pushed the UCAs forward and set caster to 6.4 which was maxed out on setting A, and threw some 2nd hand 37x12.50R17 Cooper STT Pros on. Came out pretty nice but man that's a lot of tire and gas mileage really went to crap! LOL The 0 offset isn't helping either but it seems to be clearing everything for now. Gonna put it through its paces and see what needs attention or if I may make the swap to a + offset wheel.
    This is just mock up. I threw a longer bolt in there once everything was finalized!
    Pinch weld sliced and hammered in then coated in 3M body seam sealer.
  15. Mar 29, 2023 at 12:08 PM
    #2535
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Christ! Your rig is CLEAN
  16. Mar 29, 2023 at 12:38 PM
    #2536
    NaturalState4x4
    NaturalState4x4 New Member
    Josh
    2021 Black Crewmax
    3" lift, TRD PRO wheels, 35x11.50 Falken RTs
  17. Mar 29, 2023 at 12:55 PM
    #2537
    PaulROahu
    Paul
    Kaneohe, Hawaii
    ever since the 6” lift, my OCD took over so i can clean the under carriage easier. Now part of my wash/detail is interior, exterior, engine bay and undercarriage
  18. Mar 29, 2023 at 12:58 PM
    #2538
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Ok I need an exhaust sound clip lol
    B.Ross and CaptRussia253 like this.
  19. Mar 29, 2023 at 1:25 PM
    #2539
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Same. Thinking about chopping mine off.
    PaulROahu likes this.
  20. Mar 29, 2023 at 1:25 PM
    #2540
    CaptRussia253
    Ruslan
    Same. I just bought my damn 35s :annoyed:
  21. Mar 30, 2023 at 10:17 AM
    #2541
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Do you need 37's though?
    CaptRussia253[QUOTED] likes this.
  22. Mar 30, 2023 at 11:33 AM
    #2542
    CaptRussia253
    Ruslan
    It’s more of a want for sure. No body really “needs” 37s haha
  23. Mar 30, 2023 at 11:36 AM
    #2543
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Lies lol
  24. Mar 30, 2023 at 12:25 PM
    #2544
    shmabs
    shmabs New Member
    I run 37x12.5 ko2s on RW wheels, no spacers.
    BMC is done, no rubbing on the MCM upper arms. I will probably look into the body mount relocation, and probably have to trim the firewall a bunch to clear either chains on the 37s, or a bigger tire, as the 37s are really close to both.
    They do however rub my heavily massaged mud flaps, and my sway bar.
  25. Mar 30, 2023 at 12:26 PM
    #2545
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Wheeling/Crawling? Long travel? Then you do ;)
    Though 37's now is good future proofing if you plan on serious suspension mods.
  26. Mar 30, 2023 at 1:06 PM
    #2546
    CaptRussia253
    Ruslan
    What offset are your wheels?
  27. Mar 30, 2023 at 1:07 PM
    #2547
    CaptRussia253
    Ruslan
    If I wanted a rock crawler I’d get a wrangler on 40s. I just want 37s on the tundra to clear the parking lot curbs. :D
  28. Mar 30, 2023 at 1:12 PM
    #2548
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    RW wheels are +50
    BlackSheep and shmabs like this.
  29. Mar 30, 2023 at 1:48 PM
    #2549
    C.I.
    Cesar Pedrin
    Cabo, Mx
    the hell? how friggin tall are those where you live?! :rofl:
    excelw and CaptRussia253[QUOTED] like this.
  30. Mar 30, 2023 at 2:40 PM
    #2550
    BabyBlackYota
    BabyBlackYota New Member
    Alex
    Longview TX
    2015 Black Tundra SR5 offroad
    AFE cold air intake, Outlaw Catback Dual Exhaust, ProRunner Fender Flares, DAPTISED 37x12.5x20’s, (soon to be 38x13.5x17) Zone 5 bracket lift kit /with pro comp spindles and outer tie rods grip pro lsd rear, Revolution 5.29 gears Deaver U748 springs Camburg shackles Fox 2.5 Coilovers 7” BDS Icon Billet adj/UCA’s
    Got my Icons put on today
