  1. Mar 18, 2023 at 11:20 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Started my audio upgrade. Bought this when the truck was stuck in the shop for 9 months. Just reached out to James @james@tech12volts and he's sending me the dsr1 I need to make it work as well as some upgraded door speakers. Anything will sound better then the stock jl system.
  2. Mar 19, 2023 at 3:33 AM
    Beckusmc
    Beckusmc New Member
    Black Tundra Platinum
    Are the subs 10 or 12 inch? Let us know how it sounds after it is installed. Are you keeping the head unit? JBL or Non JBL?
  3. Mar 19, 2023 at 4:30 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    I see a theme here. Nice looking tire size for sure.
  4. Mar 19, 2023 at 9:09 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    It's 2 10" w3 shallows in jl's sealed stealthbox. I've heard great things about it so we will see. I'll be keeping the stock head unit for now. It's the jbl stock system.
  5. Mar 19, 2023 at 9:19 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Nothing new to report on the mod front yet. Just doing some post season/preseason touching up. Refinished the wheel wells and lower control arms with steelit.
  6. Mar 19, 2023 at 10:00 AM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    This is a snug fit for any single row light bar. There is not much room to adjust the light beam down or up. What I did was tilt the back of the light bar upwards as much as I can, then tighten down the bolts. I wanted to make sure the light beam doesn't shine up to incoming drivers. But again, the light bar sits about 2 feet off the ground, so it shouldn't blind other drivers on the opposite road. Standing 30 feet away in front of my truck, the light beam does not blind you. But if you squat down, yes, the light beam will shine directly at you. Mine is the Rigid SAE light bar, which is legal to use on the road, but I only turn it on during foggy and rainy conditions or when off roading. Only once, I had someone high beam me on a two way road. A technician told me I can trim down the opening using a dremel to give the light bar a little wiggle room, but I wasn't looking to mess up my bumper. In all, the install came out clean. Perfect spot on the bumper for any lights to be mounted. Post some pictures when you get it wired up.
    30" Rigid SAE Compliant Light Bar
  7. Mar 19, 2023 at 10:29 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    Made this super convenient. Speed and Navi side by side.
    GAknight, Part_time, GarTX526 and 6 others like this.
  8. Mar 19, 2023 at 10:44 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    Mine is a combo light, with outside floods and center "driving" lenses. It's aimed a little down based on the rake of the truck. When I level the truck it will be perfect. I turned it on last night on a straight stretch of road with no oncoming traffic, and its significantly brighter than my lows with driving lights, and throws way more light further down the road than my brights. I wouldn’t use it with oncoming traffic, it's way to bright for that.
    DeesCrewMax likes this.
  9. Mar 19, 2023 at 12:33 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    It’s been a while and many mods later.. Massive thanks to @RainMan_PNW for getting me set up with BSM, love it. Also @reywcms for blowing my mind and pushing me even closer to a SC (and for the leafs :thumbsup:). Finally got the tent mounted and ready to go as well as my truck not being brown anymore
    FF84A695-9938-411D-A68F-F2390207394C.jpg E999E06F-0C5B-40E4-A048-E0A1F7BF8BD6.jpg 63B8EE65-E7C4-48A5-9C62-A275D64E5F84.jpg
    Wallygator, GAknight, kbark and 19 others like this.
  10. Mar 19, 2023 at 12:44 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Looks great! Camping season is coming, boost helps you get there quicker to setup. It’s a fact
  11. Mar 19, 2023 at 12:45 PM
    TUNDRA180
    TUNDRA180 New Member
    MATT
    2017 BLACK TUNDRA PLATINUM
    Installed ‘19 TRD Pro LED headlights
  12. Mar 19, 2023 at 1:03 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    And we got that bad boy in. Seeing 14.8v on start up now, so the AGM battery will start charging.
  13. Mar 19, 2023 at 2:03 PM
    RegGex
    Oregon
    2021 TRD Pro CM
    Stop being reasonable.
  14. Mar 19, 2023 at 3:09 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    :fistbump:
    RegGex[QUOTED] likes this.
  15. Mar 19, 2023 at 3:13 PM
    PlaysARobin
    PlaysARobin New Member
    Thomas
    East Houston - Texas
    2021 TRD Pro Super White
    (2021 TRD Pro) AMP Steps, Ceramic Tint 5/20/70 windshield, Kilmat floor, doors and rear with Audiofrog/Arc audio/JL speaker upgrades and factory HU. AJT blackout. Ironmax4x4 Raid bumper with 10w amber work lights and 32" light bar. Rago dash setup with Bulletproof phone mounts. VLEDs interior kit with front and rear footwell lighting. X2Power AMG 27F.
    You won't regret it. James is phenomenal to work with, and knows his way around our trucks. I ripped all the garbage JBL branded stuff out after about 2 months of owning it. I've got a build thread in the audio subforum I think. It was about 2 years ago. Arc audio subs, audio frog doors, JL amp, DSR1 to keep the factory head unit. Still have it, and won't likely replace until it is necessary.
    If I may make a small suggestion... Killmat (Amazon) that truck while you have it apart. You don't have to go overboard and do every inch, but a couple full sheets inside your door on the inside of the outer door skin (it sounds as weird as it reads, but trust me) and on the inside of the door between the panel and the sheet metal make a HUGE difference in road noise reduction. I also did the entire floorpan while I had the truck torn apart. My brother has my old Tundra and we did just the doors, and it make a huge difference on his. Maybe 80% of the benefit of doing the overkill approach I did.
  16. Mar 19, 2023 at 3:18 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Got the rest of my holes drilled and shot with cold galv. Had the damn drill bind up on me and swing around and smack me hard in the cheek/lip - split lip, saw stars for a few seconds. After that, I went digging though my bits and came up with a spiral fluted reamer I forgot I had. That made the last 6 holes much easier.
    I’m short a few lock washers and need some longer bolts to accommodate the cat plate mount, so hardware store tomorrow to finish things up.
    2582929B-DFA1-4163-901E-6868C05C2755.jpg DD6F04F6-9C43-4D3D-9D3E-251754E2C5D5.jpg
    modified the mounting brackets for the rear cat shield to work with the White Knuckle sliders
    Then I swapped out the winch hook for the Agency6 one I got after the TucsonTundra1794 raffle
    Then I put on the heritage TRD badge from Tacos4Cheap
  17. Mar 19, 2023 at 3:56 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    heh, did the same when I was drilling the holes for my WKOR sliders too. Missed my eye by a mm.
  18. Mar 19, 2023 at 4:10 PM
    S13ka24de
    S13ka24de New Member
    More stupid youtube stuff let see if this helps with drone...lol
    bulldog93 likes this.
  19. Mar 19, 2023 at 4:11 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    So, what was the ChuckIt used for within that process :boink:
  20. Mar 19, 2023 at 4:15 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Heimholtz resonator will fix it.
    Edit: I now see you have them.
  21. Mar 19, 2023 at 4:26 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I hope that’s some high-temp web strapping.
  22. Mar 19, 2023 at 4:27 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Nothing like having to crawl out from under the truck (in the gravel) every 3 minutes to send a ball hurling through the air.
    #lablife
  23. Mar 19, 2023 at 4:51 PM
    He’s got ‘em
  24. Mar 19, 2023 at 4:52 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    So he does lol
  25. Mar 19, 2023 at 5:31 PM
    S13ka24de
    I have them still drone. I have a borla muffler and flowmaster side exhaust...lol even after the wrap the drone still there but now to a point i can tolerate. I suspect need longer j pipes. On one side is 36" another side is like 24"......i may waste more $ next week and add more j pipes...lol
  26. Mar 19, 2023 at 5:34 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    this is next on my list of things I want to do. thanks for the inspiration!
  27. Mar 19, 2023 at 5:54 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    had Dura Coating tires on my last 35”. this time using Exoforma on my new 37” as i really liked there other products. similar results; Clean tires really good. put on coating (3) results is dry to touch, NO sling and doesn’t attract dust/dirt. just rinse and use car wash soap, light scrub, rinse and blow dry
  28. Mar 19, 2023 at 5:54 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've heard that Flowmasters drone a LOT.
    WVI and S13ka24de[QUOTED] like this.
  29. Mar 19, 2023 at 6:05 PM
    the red
    I feel that. I've done that. I use my side handle a lot now. Eventually I'll upgrade to a drill that auto-stops.
  30. Mar 19, 2023 at 6:05 PM
    Sleeper16plat
    Near Vancouver
    i am jealous. my wife and kids cars and SUV all have heated steering wheels. why was that not part of the options with the "Platinum"?
