  1. Mar 15, 2023 at 11:07 AM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    It was $250 (Cdn). They custom fab’d the Y pipe and then added in stainless pipe where needed.
    bulldog93 likes this.
  2. Mar 15, 2023 at 11:19 AM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    These are adjustable headrest you can find on Amazon. They are great for the kids and adults on long trips when they sleeping. Keeps them from leaning sideway over the seat belt. Safety and convenient. Hope this helps.
  3. Mar 15, 2023 at 11:30 AM
    Quicksand_Tundra
    Jon
    Yes. These are still power fold mirrors and will work with your control knob from inside the truck. The small mirror is manual only.
  4. Mar 15, 2023 at 11:43 AM
    Quicksand_Tundra
    Jon
    Seriously? When I bought the truck back in 2019, I asked the dealership parts guy, if I can swap out the mirror for a turn signal mirror like the ones on the Platinum, he said it's not compatible if the truck didn't come equipped with it. :notsure: I would think the parts department would know. Can anyone on the forum, tell me otherwise. Would appreciate. Thanks.
  5. Mar 15, 2023 at 11:49 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Confirmed. My SR5 mirrors had no turn signals but both the Trail Ridge and Boost Auto power mirrors have built in signals and were operational when I installed the mirrors.
    Henry1jg and bulldog93 like this.
  6. Mar 15, 2023 at 11:51 AM
    Quicksand_Tundra
    Jon
    From the looks of it, the only wires behind the mirror is the BSM plug, and two plugs for the defroster. I don't see any other wires that would indicate as a source for the turn signal. Unless it's build in the BSM plug to be setup that way. Anyone swap out for the turn signal mirror? And let me know how it works. Would appreciate it. Thanks.
  7. Mar 15, 2023 at 11:57 AM
    Quicksand_Tundra
    Jon
    Good to know, but did you have to wire and tap into the signal lights? I saw a video on youtube, it had to be tapped in, for the Boost Auto power mirrors to work. The mirrors are built that way, but for turn signal to function, it had to be tapped in. Let me know if this is false. Thanks.
  8. Mar 15, 2023 at 12:05 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The wire you're talking about is most likely the long white wire that powers the reverse lights on those mirrors. No I didn't have to do anything special to "activate" my turn signals. The harness on the truck already has the power running to the mirrors but the mirrors from the factory, on lower trim levels, do not have a corresponding wired terminal since the mirrors are sans signals.
    bulldog93 and RobertD like this.
  9. Mar 15, 2023 at 12:12 PM
    Quicksand_Tundra
    Jon
    You're right. That is the feature for the reverse light function. I will look into the OEM mirror, since it's plug and play. Appreciate the knowledge and help. Thanks.
    Henry1jg and texasrho83 like this.
  10. Mar 15, 2023 at 12:16 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    OEM tow mirror? The Boost Auto option is also PnP as long as you stay away from the power fold conversion (unless your truck came with it).
  11. Mar 15, 2023 at 1:11 PM
    Quicksand_Tundra
    Jon
    No power fold mirror on my truck. I was actually looking at the OEM mirror only, but no luck. I believe I would have to replace the whole assembly, so only option will be aftermarket. Auto Boost tow mirrors will be on my checklist, but will have to wait for now. Thanks for all the info.
    texasrho83 likes this.
  12. Mar 15, 2023 at 1:23 PM
    RobertD
    Robert
    DFW, Texas
    Tons of posts on this forum with guys buying mirrors with turn signals and they instantly worked.
    There are some issues with cheap 3rd party mirrors because sometimes their harness connector isn't pinned correctly so they have to switch some pins and then it works. Multiple threads on this too.
    texasrho83 and Rocko9999 like this.
  13. Mar 15, 2023 at 2:16 PM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    have a link to those? Like the red stitching you have - they’d match my covers nicely!
  14. Mar 15, 2023 at 3:10 PM
    Kitt
    Kitt New Member
    2017 Tundra SR5 TRD 4x4
    Completely stock
  15. Mar 15, 2023 at 4:10 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    Is this a spot the difference challenge?
  16. Mar 15, 2023 at 4:16 PM
    Lol...looks like he just uploaded it twice.
  17. Mar 15, 2023 at 4:52 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Picked up my CO2 tank from getting recharged and installed the new battery. It’s been about 3 years, but figured time to swap it out. Went with X2power group 34 and the Rago Fab group 34 box.
    Battery had opposite terminals, so had to get new battery terminals, then the wires were too short, so had to get new wires, then the j hooks were also too long from the group 27f battery so had to get new j hooks too. :annoyed:
    All in all, works perfectly. Also have the NOCO genius 10 to do a monthly full recharge on the battery.
    Also, organized my recovery gear into a packout.
  18. Mar 15, 2023 at 5:13 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Reached a milestone. I picked it up from the dealer 2 years, 10 months ago.
    I reached the milestone on my way to work, as I passed by the USS Alabama.
    Neo258, GAknight, Tony_h and 23 others like this.
  19. Mar 15, 2023 at 6:05 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    Definitely does! Thank you!
  20. Mar 15, 2023 at 6:18 PM
    centex
    centex New Member
    Use them in mine and it’s great for my kid in a booster. Wouldn’t know how comfortable they are as mrs. daisy doesn’t drive so I don’t get to sleep haha.
  21. Mar 15, 2023 at 6:19 PM
    Kitt
    Kitt New Member
    Completely stock
    This a gen x'er doing his best boomer impression
    Henry1jg and PomDad like this.
  22. Mar 15, 2023 at 8:21 PM
    Quicksand_Tundra
    Jon
    Hello, I went back to my Amazon history purchase, and this color style is no longer available. Bought these two years ago. Apologize. Trying searching eBay, too.
  23. Mar 16, 2023 at 4:35 AM
    Eborseti22
    Evan
    No problem - appreciate the effort! Saw them on ebay but at $70/each! Will keep an eye out for them!
  24. Mar 16, 2023 at 5:15 AM
    Kung
    KG, VA
    You know you own a Tundra when you are curious whether the milestone is the miles or the *MILEAGE* :rofl:
  25. Mar 16, 2023 at 5:22 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    On the Spotter mirrors, what tabs broke? I've been looking at these too.
  26. Mar 16, 2023 at 7:19 AM
    Nickutta
    Nickutta New Member
    Boise, ID
    2017 TRD Pro Cemented
    Spotter mirrors are great, love mine! I have the turn signals version. Wasn't too bad, no need to pull door panels, just the sail and mirror itself to route/extend the wiring easier. I didn't break any tabs but can see how it could happen if not too careful, to pop out the existing mirror. I just used a wide/flat prior tool to pop it.
  27. Mar 16, 2023 at 7:34 AM
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    Question on the Spotter mirrors: should I be able to swap out my mirrors, which don't have turn signals currently, on my 2021 Limited for these (2007-2021 Toyota Tundra Adjustable Spotter Mirror) and end with turn signal mirrors? Not sure what my wiring is but from the sounds of it all the parts and pieces should be there.
  28. Mar 16, 2023 at 7:44 AM
    Quicksand_Tundra
    Jon
    You can check the pictures on the website spottermirror.com
    When you get to the Tundra page, scroll down to installation. When the glass is taken off, you can see the black plastic circle mount. When I took mine off, the whole piece came out along with the mirror. The tabs look like a L shape upside down. Maybe I did it wrong, but the mirror did not pry out so I had to use a screw driver to separate the mirror from the plastic mount. That’s how I broke the tabs. I had to use a screwdriver to separate it, but be careful you might break the mirror. I added some double sided adhesive tape to keep it from vibrating and loose. After that, I was able to mount it back onto the truck. Hope this helps. You’ll like this upgrade. Good luck on the build.
  29. Mar 16, 2023 at 8:05 AM
    Quicksand_Tundra
    Jon
    Good question. From their website, you can get the mirror with the turn signal and defroster. But your wire plug must have enough slot to fit the pins. Might have to configure it to make it fit. If you look at the website photo, you’ll see it’s all wired up for turn signal and defroster. (Green plug). But if your truck has BSM, the computer might detect it and raise a flag. Don’t quote me on that, but just thinking the BSM sensor might not work. Somehow, you can’t have all three, defroster, BSM, and turn signal due to the design of having the blind spot mirror. Only can you have all three features if going OEM. Good luck on your build.
  30. Mar 16, 2023 at 8:09 AM
    DFW
    2021 Limited 4x4
    I gotcha, I don't have BSM, I just have plain old reflective mirrors (with power adjust) on a Limited trim truck.
