Spit-ballin' a heated steering wheel in a Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by HulkSmurf14, Jan 27, 2021.
  1. Feb 26, 2023 at 6:37 AM
    #61
    vilord
    vilord New Member
    Jesse
    2019 TRD
    So the clock spring used in the 2019 tundra was also used on a bunch of other much older toyotas, like 2009 lexus gs... different steering angle sensor, but should hopefully be able to snap the newer steering angle sensor into the older clock spring and keep the tundra's turn signals...
    but did any of the older toyota/lexus models have heated steering?
    EDIT: answer is nope, none of the models with this style of clock spring had heated steering wheels.
    continuing to poke around on the internet and scanning ebay used photos but at this point i think i need to find a u-pick-it yard and just go poking around to piece things together, before i buy any more useless parts. it's *possible* that the 2018 highlander's complete clock spring + steering angle + turn signals + wheel will just plug in and work (after repinning the connectors as the number of pins are different) but i doubt the computer would accept the newer steering angle sensor's signals.
    EDIT 2: highlander clock spring/signals/etc don't fit. Ended up using a specific landcruiser/lexus clock spring, see further down the thread
    #61
  2. Feb 26, 2023 at 6:39 AM
    #62
    vilord
    vilord New Member
    Jesse
    2019 TRD
    yeah that's the case on 100% of the toyota/lexus heated wheels, heat is from 8-10 and 2-4 only.
  3. Feb 26, 2023 at 9:35 AM
    #63
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I get sketchy when messing with clock springs. You’re braver than I am.
    #63
  4. Feb 26, 2023 at 3:43 PM
    #64
    vilord
    vilord New Member
    Jesse
    2019 TRD
    Yeah I'm not planning to open one up and change the bits in it. The tundra clock spring is identical to the one on corolla, rav4, highlander, tacoma, venza, camry, avalon, and lexus rx, gx, etc, but unfortunately it is for previous generations of those, and none of them had heated steering wheels. the newer generation there was a heated steering wheel on a number of the models... unfortunately the rav4 clock spring i bought is *two* generations newer so there's just no way to use any part of it. the 1-generation-newer clock spring has mostly the same plugs as the tundra stuff, just uses a 12-pin instead of 10-pin plug for the main connection, and adds a 4-pin heat connector. the airbag connectors are identical across all of them.
    so yeah i'm willing to experiment, but not terribly excited about opening up different generation parts and swapping things between them
    EDIT: Okay, so I opened up the tundra clock spring and the highlander clock spring. ayup, they're different! Nothing can be transferred between them so i wiggled them back together, now my hands are covered with gooey grease. yuck.
  5. Feb 26, 2023 at 4:52 PM
    #65
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    I've got a heated SW on my 2020 Bullitt. Didn't think I'd use it but........
    panicman likes this.
  6. Feb 27, 2023 at 7:50 PM
    #66
    vilord
    vilord New Member
    Jesse
    2019 TRD
    The 2018 highlander heated steering wheel at least fits the steering column and has all the right buttons. This is also used in the sienna... the clock spring is useless again, too different from the tundra.
    Found toyota/lexus part 84306-50190 and 84306-50200 are both using the older style clock spring, but with the high amperage heated steering connector. The 50190 clock spring is available for very cheap, like 40 bucks. 50200 is not available for that cheap, so wth, ordered the 50190. Crossing my fingers that it snaps onto the tundra's turn signals!
    EDIT: Some additional digging reveals that 84306-50200 has the same 10pin/12pin harness connections as the tundra, so this would be a great choice if the chosen heated wheel has the same plugs as the tundra wheel, or if you want to add a wrap and heat tape to the factory wheel. 84306-50190 has 12pin and 14pin connectors instead of 10 and 12. The highlander wheel I'm planning to use has the 14pin connector so i'm going with that one. It also will leave two extra pins available if I want to later add paddles!
    Current parts i am hoping will work:
    • 2017-2019 highlander/2018-2020 sienna heated steering wheel and airbag (has lane departure and radar distance buttons for 2018+ tundras with TSS. Use a 2015-2016 highlander / 2015-2017 sienna heated wheel for pre-TSS tundras)
    • 2013-2014 land cruiser heated clock spring 84306-50190
    • tundra steering angle sensor
    • tundra turn signals
    will need to replace the 12pin clock spring to column connector with a 14-pin connector (appears to be used on both the land cruiser and the highlander, i have the complete highlander column with cutoff harness so i'll use that one if it plugs in)
    and now more waiting for parts. i'm going to have a lot to dump on ebay when i finish this :)
    #66
  7. Mar 9, 2023 at 5:51 PM
    #67
    TundraAWS
    TundraAWS New Member
    This site shows a 14 pin for the platinum
    https://clockspringexperts.com/prod...-0l-4-6l-4-7l-5-7l-new?variant=42290542215326
    Could you use a button like the radio source.... To run it instead, re route after the clock spring. You'd have to look at the gage of wire and electrical requirements of the heated steering wheel, like that aftermarket one. I was thinking on this after reading your stuff the other night. Haven't dug much past these thought but if you have wire diagrams of a Toyota with a heated steering wheel and this one, let me know I'd like to look.
    #67
  8. Mar 10, 2023 at 4:56 AM
    #68
    vilord
    vilord New Member
    Jesse
    2019 TRD
    Oh that just adds a whole extra level of fun to this mod lol.
    I'll poke around in TIS once I get the aftermarket heated clock spring i ordered and see if the platinum shows a different clock spring test procedure/pinout, and if so if it matches the clock spring i get.
    I personally would not feel comfortable running the heated steering wheel power through the normal clock spring pins in a clock spring that wasn't made for heat. it's a coil of thin plastic with some copper drawn onto it like a circuit board... pulling too many amps through it could cause it to heat up and melt... and right next to it is another thin plastic coil with copper drawn on that runs to the airbag.
  9. Mar 13, 2023 at 12:18 PM
    #69
    vilord
    vilord New Member
    Jesse
    2019 TRD
    Got the wheel mounted and the airbag/clock spring/controls are all working fine.
    Haven't hooked power to the clock spring's steering heat connector yet because it started raining, but nearly done!
    Note the AliExpress steering heat button on the left next to the auto full beam headlight button
  10. Mar 13, 2023 at 12:30 PM
    #70
    HulkSmurf14
    HulkSmurf14 [OP] ...Weighted Average...
    2014 Tundra Limited
    Tastefully enhanced...
  11. Mar 13, 2023 at 1:07 PM
    #71
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Shit yes this is awesome. I’ve always complained about the wheel especially in the platinum trim. I may need to do this lol
  12. Mar 13, 2023 at 1:16 PM
    #72
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    You wanna know the biggest improvement, besides heat obviously, is that the Volume Up and Next/Previous buttons are in the right place!! FOR THE LIFE OF ME, I cannot figure out WHY THE HELL Toyota decided to change that button placement for those. On the Second Gen Tacoma, it's the same Triangle, but Volume UP/Down is actually in the UP/Down spots. The NEXT/Previous is in the Lef/Right spots.
    But NOOOO, on the 3rd Gen Tacoma's and these Tundras, they're swapped! Volume UP/DOwn is in the LEFt/RIGHT position and Next/Previous is in the UP/Down.
    I HATE THIS SO MUCH! lol end rant
  13. Mar 13, 2023 at 1:18 PM
    #73
    Kung
    KG, VA
    LMAO
    I thought it was dumb too, but I live with it. My wife on the other hand *HATES* the placement. lol
    M3Tundra-JK[QUOTED] likes this.
  14. Mar 13, 2023 at 1:19 PM
    #74
    vilord
    vilord New Member
    Jesse
    2019 TRD
    Oh believe me, right there with you! I spent a lot of time looking at interior images of various Toyota and Lexus models from the last 10 years trying to figure out which steering wheels to try, and location of the damned volume buttons was very high on the list of things.
  15. Mar 13, 2023 at 2:56 PM
    #75
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    My hero.
    HulkSmurf14[OP] likes this.
  16. Mar 13, 2023 at 4:48 PM
    #76
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    @ColoradoTJ
    This man cracked the code. Maybe a sticky? Either way this thread should be saved IMO or combined into something else.
    Well done :hattip:
  17. Mar 13, 2023 at 5:02 PM
    #77
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Absolutely well done, @vilord!
    I bet a lot of members would love to see a cleaned up step by step tutorial with parts numbers if you have the time. Just to make it all easier to follow since most of us use the forum on our phones.
  18. Mar 13, 2023 at 5:06 PM
    #78
    vilord
    vilord New Member
    Jesse
    2019 TRD
    The difficult thing is that nearly all toyota wheels post 2012 (with the exception of 4runner, tacoma, tundra, sequoia) use a 14pin socket at the column and a black 12pin socket for the controls in the wheel. tundra is a 12pin socket at the column and white 10pin in the wheel.
    So the options are to add your own heat tape to the tundra wheel with a new leather wrap, and use the 84306-50200 clock spring, or to rewire the column with a 14 pin plug, use the 84306-50190 clock spring that's like 40 bucks aftermarket, and use another wheel like highlander/sienna, rav4/corolla, camry, etc that all use the 12 pin plug at the wheel controls.
    you can see my notes here for the 12pin to 14pin conversion at the column:
    https://docs.google.com/spreadsheets/d/1Leie8b_zFCFKP0EM5M3Atvcips5oT4uP_m2W872qJb8/edit?usp=sharing
    don't rely on the colors in my sheet, toyota seems to have changed wire colors a number of times over the years
    helpfully, toyota didn't even use the same pins... the 14pin socket uses a newer type of pin than the 12 so it can't just be repinned... i ended up cutting off the tundra plug and wiring on the highlander/rav4 plug instead, you can see the solderseal heatshrink connections i used here:
    (highlander's cruise control stalk has backlighting, the dangling white wire i haven't hooked up yet just needs to go to ground / illumination -. in highlander if there's an error with cruise it will flash the backlighting on the stalk, but i don't need that)
    wKgpWC9ihN34pQMq4hGJW0el1S1CO1JS0zJ5OeOx_b41b002e79457a1346268c6f87c267c923e8f1cb.jpg
  19. Mar 13, 2023 at 5:08 PM
    #79
    vilord
    vilord New Member
    Jesse
    2019 TRD
    Yup, that's my plan, to put together a step by step once this storm passes and i can hook up the last few wires under the dash without getting rained on at 35 degrees :)
  20. Mar 13, 2023 at 5:18 PM
    #80
    vilord
    vilord New Member
    Jesse
    2019 TRD
    Oh also, if you do attempt this, don't be like me and use an impact to take off and put on the steering wheel nut! And be very careful moving the steering angle sensor from the old clock spring to the new one. The steering angle sensor is very sensitive to shock, and is about a $400+ replacement on the 2018+ TSS trucks. I ended up using my extended warranty to have it replaced a couple weeks ago when I was still experimenting, the dealer said it had developed an internal short.
  21. Mar 13, 2023 at 7:10 PM
    #81
    AggiePhil
    College Station, TX
    That wheel just doesn’t look right on a truck.
    cavalry bear and HulkSmurf14[OP] like this.
  22. Mar 13, 2023 at 7:12 PM
    #82
    vilord
    vilord New Member
    Jesse
    2019 TRD
    Everyone's got an opinion
    texasrho83 and ZappBrannigan like this.
  23. Mar 13, 2023 at 7:36 PM
    #83
    HulkSmurf14
    2014 Tundra Limited
    This opens up a lot of awesome!
  24. Mar 13, 2023 at 7:44 PM
    #84
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I cooked a clock spring once working on a Pontiac. That one came out of my pocket though. :(
  25. Mar 13, 2023 at 8:37 PM
    #85
    Dukhnt
    Dukhnt New Member
    Oh! Can you mount it upside down, so the heated part is at the bottom, where I think most of us hold the wheel anyway? Lol
  26. Mar 14, 2023 at 4:07 AM
    #86
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Most of us? I'd love to see the distribution on that, I personally never hold the bottom of the wheel.
    Warm outside = one hand at 1-2 on the wheel, the other out the open window
    Cold outside = one hand at 10-11 on the wheel, the other resting on the shifter.
  27. Mar 14, 2023 at 4:21 AM
    #87
    vilord
    vilord New Member
    Jesse
    2019 TRD
    You could try to do that, the clock spring and angle sensor have a number of rotations limit, if you exceed that number they will break.
    And the turn signals won't disable properly.
    Just add steering wheel heat tape where you want the heat, or buy a 22 which has a fully heated wheel.
  28. Mar 14, 2023 at 2:50 PM
    #88
    Dukhnt
    Dukhnt New Member
    Maybe it's an Eastern / western thing? Do you have the seat reclined all the way back like a balla? :)
  29. Mar 14, 2023 at 2:54 PM
    #89
    vilord
    vilord New Member
    Jesse
    2019 TRD
    I think it's more of a balla vs not thing. I could not by any stretch pull off being a balla :)
    Dukhnt likes this.
  30. Mar 14, 2023 at 8:44 PM
    #90
    Dukhnt
    Dukhnt New Member
    I'm right there with ya!
