Hello - 2021 Tundra issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bugman20, Mar 5, 2023.
  1. Mar 5, 2023 at 1:20 PM
    Bugman20
    Bugman20 [OP] New Member
    2021 Tundra 1794
    Twice it has happened, stop vehicle, turn it off, someone waiting inside truck locks doors manually. They unlock when I come to get back in vehicle (5-10 mins later). Truck will not start. Thought the first time was a flook but it happened again recently.
    This last time the dash said to hold key fob to red ignition button - it started, but the GPS was down, clock was off time.
    Has this happened to anyone else? What's up with this vehicle?
    Thanks
  2. Mar 5, 2023 at 1:23 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  3. Mar 5, 2023 at 1:26 PM
    Bugman20
    2021 Tundra 1794
    Yes it is - just trying to figure out if it's something I'm not doing right first.
    1UP likes this.
  4. Mar 5, 2023 at 1:29 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    That message regarding the key fob makes me think its battery is extremely low. Your truck can still start with a dead fob if you hold it to the start button on the dash as you press it. I think you have to hold the side with the chrome Toyota emblem to the start button. Or that might just be the key fob on my older Lexus.
    Try replacing the fob battery, and see if you can recreate the problem.
    Giskk likes this.
  5. Mar 5, 2023 at 1:34 PM
    Bugman20
    2021 Tundra 1794
    Didn't think about the battery in key fob - will for sure replace that. Thanks
    Terndrerrr likes this.
  6. Mar 12, 2023 at 11:22 AM
    Bergy24
    Bergy24 New Member
    Keep us posted on what you find out.
