  1. Mar 5, 2023 at 4:07 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    once you get a couple tanks of gas through, let us know how the injectors are working please and thank you!
    07 Tundie[QUOTED] likes this.
  2. Mar 5, 2023 at 4:12 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    This is the newer version of it: https://phoenixautomotiveinc.com/pr...-tundra-2007-2013?_pos=2&_sid=056cda12a&_ss=r
    I'm really happy with it though I only use it for Carplay and the backup camera. There's a million little tricks and hacks to get it setup with physical buttons and such. Message me if you end up getting it and I'll get you started.
  3. Mar 5, 2023 at 4:53 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    Will do, brother! Seems to be consuming more fuel than usual but I'd imagine it's due to the engine break-in period.
    joseph_womack[QUOTED] likes this.
  4. Mar 7, 2023 at 4:46 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    What happened? Pinion seal leaking or did the nut come loose?
    These have a crush sleeve that must get replaced if that nut ever moves. That said, the nut is one time use too and gets replaced if ever moved.
    In short you need a beam style torque wrench rated in inch/pounds to measure the rotational torque of the bearings and seal as the nut is tightened. You'll need the spec from the manual and to your point, the diff needs to come out and obviously have the carrier pulled to install new pinion bearings and set pinion bearing preload
    It may not be a day job...
    The 2010 4.6 also has a 9.5 ring w 3.909 ratio.
    Ping me if you need help. I just installed this OS-Giken LSD in my IS-350.
    Peeeheeuuu, MTRock, Ricos and 5 others like this.
  5. Mar 7, 2023 at 9:13 PM
    Wrath
    Wrath New Member
    2nd Gen Tundra
    Mods that make me happy.
    Played in the dirt today.
  6. Mar 7, 2023 at 10:15 PM
    joseph_womack
    Joe
    Louisiana
    Pinion yoke had a groove worn into it because of dirt, had to replace the yoke and nut, I overtightened the nut on accident (325 ft lbs is what the manual says) and ruined the bearing. I work at a shop but we never do gears; I’m probably gonna drop it off at the local gear guru Thursday. I was gonna attempt myself, but a little nervous about screwing up the backlash and preload and grenading the diff
  7. Mar 9, 2023 at 2:39 PM
    4x4WarriorOfRocks
    4x4WarriorOfRocks New Member
    2010 Tundra 4x4 Rock Warrior
    Finally got around to installing this bumper with new lights and a winch! Pretty happy with how it turned out!
    :spending:
  8. Mar 11, 2023 at 11:59 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Did the rear diff breather mod behind the tail light today. It’s these little inexpensive mods that I can’t stop doing. 27DB3666-3C50-400A-972C-6D842AE5E09B.jpg 76AD676A-A190-4046-A064-F8AB61E42826.jpg 1166E16E-F27E-4075-BEA0-00C848533C20.jpg
  9. Mar 11, 2023 at 12:51 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Getting a new windshield put in. I really hate other people working on and touching my truck…
  10. Mar 11, 2023 at 3:22 PM
    PhotoNerd
    Tony
    Waterford, CT
    Replaced a blue button with an orange button. This should have taken about 3 minutes but it took an hour because I did an awful job with the wiring the first time and I had to redo it.
    3B13C9BF-ED1C-4CFD-854C-FA35E3E493CD.jpg 49A66FA6-4220-4799-A2B3-0B4567EB4E4A.jpg
    Anyway orange buttons match better.
  11. Mar 11, 2023 at 3:25 PM
    chrisf111
    chrisf111 New Member
    Did you buy a whole switch or just swap the LED. The LEDs can be swapped with basic soldering know-how, but I've yet to find an exact color match for the orange in our trucks.
  12. Mar 11, 2023 at 5:35 PM
    PhotoNerd
    Tony
    Waterford, CT
    I replaced the switch because it didn't occur to me to just disassemble it!
  13. Mar 11, 2023 at 10:24 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Read my owners manual and discovered I can program my seat setting with my key fob :bananadance:
    Kung, Ohannon7, joseph_womack and 3 others like this.
  14. Mar 12, 2023 at 6:06 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    "upgraded, or downgraded my battery tie down.. It kept slidding off to the sides, because the OEM bracket was too high, so, I took my Celica's spare tie down bracket, and ordered a short J hook from tue back side. Aint going anywhere no more.
    installed Crew Max running boards, boards will need some modding, as in drilling out new holes, its about a 10 inch gap on the last bracket.
  15. Mar 14, 2023 at 9:09 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    1. I installed the Alpharex pro lights “halogen” last night and snapped a couple pics this morning.
    2. I hooked up the DRL module so it functions properly: Orange while running, regardless of headlights being on or off, they turn white when I turn the truck off, after 60 seconds they go black, perfect.
    3. I swapped halogen to led bc it has a cutoff line so it doesn’t blind oncoming traffic at all. Plus I dont want the housing to get hot and start to haze early, etc. The only issue is that they do NOT seem bright to me. I need to try tonight but last night they seemed not too bright, IDK what to do about that yet. I have fog lights but they do shine on opposing traffic at this time, still gotta figure that out so I try to not use them.
    The crappy side shot no one wants to give lol
  16. Mar 15, 2023 at 1:31 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Installed the taco vinyl pro insert in super white and the black out glove box lock mod complete or bogblm for short lol
    A98B26C4-7343-418E-AADD-6E4FD58E0FC6.jpg A47E641C-C4D2-487D-BA91-40C394D06010.jpg 3DDE3545-24BB-4D08-A6AA-22095E90FA50.jpg
    It’s the little things sometimes!
  17. Mar 16, 2023 at 1:24 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    today I got my new headlights to shine properly all thanks to @Shanet421 for sending me a fairly basic how-to bc ultimately I had them facing the completely wrong direction.
    So that feels nice to get right.
    I also went and looked at buying a 2000 Tundra at a local car lot but unfortunately the frame was super rusted.
    I’m no rust expert but this looks bad to me.
    Looking for an extra midsize pickup for kids.
    D4x4TRD likes this.
  18. Mar 16, 2023 at 2:26 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Hard to tell from the pictures but that looks like the coating from the frame is flaking off and there is a little bit of surface rust?
    07 Tundie likes this.
  19. Mar 16, 2023 at 6:43 PM
    PhotoNerd
    Tony
    Waterford, CT
    That is almost brand new. If it's a 2000 model, it'll still be here in 2050.
    ACDC2ZZTop likes this.
  20. Mar 16, 2023 at 7:18 PM
    Nemesis
    Nemesis New Member
    Today, for the first time in my life, I saw blinker fluids. I heard they existed but never saw one in person, and on a 2.5 Gen Tundra, too! The right tail light was half full of blinker fluid. Kid you not. HALF FULL!!! Amazing!!!
    I tried to have my wife take a pic but we lost the grey 2.5 Gen Tundra in traffic driving southbound on the 5 highway in Cali @ around 3:40pm past Anaheim (Disneyland).
    So, if that was you today check your right tail light, take a pic, and share a pic of the mystical BLINKER FLUID!!!
  21. Mar 16, 2023 at 7:20 PM
    20GR8 Super
    Corey
    PNW Outskirts
  22. Mar 17, 2023 at 7:22 AM
    LASurf
    LASurf New Member
    Los Angeles
    300k+mi 06 AC4x4
  23. Mar 17, 2023 at 8:59 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I would have passed on that one too.
    Looks to me like somewhat substantial rust has been spray-painted, and that paint is now flaking off with the rusted material beneath. Where the bed mounts, appears quite rotten in the pictures as well.
    Just the fact that someone attempted the "quick fix" would give me pause regarding any other maintenance
  24. Mar 17, 2023 at 10:20 AM
    LASurf
    LASurf New Member
    Los Angeles
    300k+mi 06 AC4x4
    Victory 4x4 rack, Smittybilt gen2 tent, rotopax 2 gallon, ALL FOR SALE. Located in Los Angeles
  25. Mar 17, 2023 at 1:58 PM
    PhotoNerd
    Tony
    Waterford, CT
    I installed the VF Tune for 91 octane, so I can spend even more on gas. It changes the computer's software to adjust the throttle mapping and changes some aspects of the ignition timing to get better performance, particularly with higher-octane gas.
    Questions:
    • What's the difference between the regular and "Torque Modifier" tunes?
    • What does the Tow/Haul button do different now (it's not clear from the docs)? It definitely makes it way more aggressive and stays in lower gears longer (which it always did to an extent). It seems like gear locking does work when I have it in manual shifting; it definitely didn't automatically down-shift.
  26. Mar 17, 2023 at 2:25 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    dondino, WVI, Prostar 190 and 4 others like this.
  27. Mar 17, 2023 at 3:37 PM
    20GR8 Super
    Corey
    PNW Outskirts
    Installed ICS dash plate, 2 ram mounts and an ICS USB/USB-C charger. Relocated the tow haul button to make room for fog light, driving light, and ditch light switches in the center console area. Also completed the garage door switch mod.
    B512D234-DF60-4B03-B2B0-3097E958256E.jpg F52F89BB-20F4-4B9B-9203-D7DE2784ADCA.jpg 26339BD0-4285-42E8-8403-E00BCD2F394D.jpg
  28. Mar 17, 2023 at 4:39 PM
    Nemesis
    Nemesis New Member
    Garage switch looks nice, doesn't it? Got a lot of hate for it when I posted it on FB Tundra group. Never again will I share anything on that media platform.
  29. Mar 17, 2023 at 4:47 PM
    20GR8 Super
    Corey
    PNW Outskirts
    They do look good and seem like a an okay quality switch even if they are from overseas. I bought the same ones for the fog lights and driving lights so looking forward to getting those in at some point too.
    Yeah this site is my form of social media. Lol!
  30. Mar 17, 2023 at 6:19 PM
    07 Tundie
    07 Tundie Shadowfax
    SC
    Bro, it’s so toxic and uninformed.
    Ohannon7 likes this.
