I Have a Fuel Leak Coming From Some Gizmo
Discussion in '2.5 Gen Tundras (2014-2021)' started by jtw, Mar 11, 2023.
  1. Mar 11, 2023 at 12:09 PM
    jtw
    jtw [OP] New Member
    Hi. I have a 2015 5.7FFV. There is a fuel leak coming from a device mounted on the driver's side frame rail, next to the fuel tank. The gizmo is 7 inches long and roughly cylindrical. There is a black braided hose going in to the back of the device. The rear 4 or 5 inches of the device is black plastic. There are 2 braided hoses (1 green, 1 red) fitted to the inside side of the device, pointed toward the fuel tank. There is an electrical connection near the front of the device. The leak is coming from the cylindrical metallic area at the front of the device. The electrical connector has >PA66< stamped on it. 10900 is stamped on the other end. The only other marking I can find on the device is >PC/ABS<, which is stamped near the green and red hose connections.
    What is it? What does it do? How much does it cost to fix? Any chance it was part of a recall? Thanks
  2. Mar 11, 2023 at 12:34 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  3. Mar 11, 2023 at 12:52 PM
    jtw
    jtw [OP] New Member
  4. Mar 11, 2023 at 12:54 PM
    jtw
    jtw [OP] New Member
  5. Mar 11, 2023 at 1:02 PM
    Retired...finally
  6. Mar 11, 2023 at 1:18 PM
    1UP
    1UP Truck Gang
  7. Mar 11, 2023 at 1:20 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looked under my 16 and didn't see anything that fits your description.
  8. Mar 11, 2023 at 1:27 PM
    NWPirate
    Zach
    WA
    Sounds like the evap cannister. Do you overfill your gas a lot after it clicks off?
  9. Mar 11, 2023 at 2:03 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Leo's first, 1UP and FrenchToasty like this.
  10. Mar 11, 2023 at 2:33 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    In the future, a pic is worth a thousand words..
    Post one up if you can.
    It might just be a bad hose connection...:confused:
  11. Mar 11, 2023 at 5:00 PM
    jtw
    jtw [OP] New Member
    It's buried, so I can't get a good pic. But the part referenced in post #3 of this thread is very close.
    It is not leaking at any of the 3 connections.
    So it looks like it is a fuel tank solenoid valve. What does that do? What are those 3 hoses connected to it?
  12. Mar 12, 2023 at 9:19 AM
    jtw
    jtw [OP] New Member
    I'm pretty sure that I only have one fuel tank.
    HulkSmurf14 likes this.
  13. Mar 12, 2023 at 10:20 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    In my estimation, anything to do with fuel and a leak is reason enough to take it to the dealer for repair. Good luck with the fix!
    831Tun, Sierradevil and texasrho83 like this.
  14. Mar 12, 2023 at 1:47 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I’d be impressed if you had two tanks
  15. Mar 14, 2023 at 3:17 AM
    jtw
    jtw [OP] New Member
  16. Mar 14, 2023 at 7:07 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Post some pics of it.
  17. Mar 14, 2023 at 7:35 AM
    jtw
    jtw [OP] New Member
  18. Mar 14, 2023 at 10:43 AM
    jtw
    jtw [OP] New Member
    This seems to be the replacement part. The leak seems to be at the circular place at the bottom right of the picture.
  19. Mar 14, 2023 at 10:46 AM
    jtw
    jtw [OP] New Member
    This shows the 2 hose connections on the right, and the circular area where I see wetness. Remember, this is mounted on the driver side frame rail, right next to the tank. The red and green lines are at the same elevation as the top of the fuel tank, and pointed toward it.
    HifiKenny likes this.
  20. Mar 14, 2023 at 10:49 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Try here.
  21. Mar 14, 2023 at 10:49 AM
    jtw
    jtw [OP] New Member
    This is the only electrical connection, located near the circular area where I see wetness.
  22. Mar 14, 2023 at 10:51 AM
    jtw
    jtw [OP] New Member
    Wider angle view. The single line comes into the part off screen right.
  23. Mar 14, 2023 at 11:05 AM
    jtw
    jtw [OP] New Member
    I appreciate the link, but that's not it. It's a different solenoid and not located in the canister area, which is off by itself much farther back under the bed on my truck.
  24. Dec 13, 2024 at 11:16 AM
    Tundra_Newb
    Tundra_Newb New Member
    2014 SR5
    None
    @jtw
    did you resolve this issue with the fuel leak? I’m having a similar problem. Location is left side of the vehicle towards the engine compartment. Haven’t crawled up in that area yet, due to the Wx being 14 deg F and snow covered ground. But that’s on my list of things that need to be addressed.
    TIA
