Engine Failure
Discussion in '3rd Gen Tundras (2022+)' started by HBV2017, Feb 16, 2023.
  1. Mar 6, 2023 at 4:29 PM
    #451
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    All I know is I'm taking care of the old 4.7's and the 5.7's. Have two of each. Combined mileage ls 600k.
  2. Mar 6, 2023 at 4:40 PM
    #452
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Bad fuel??!!?? Holy crap....
  3. Mar 6, 2023 at 5:13 PM
    #453
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Hopefully that will not be the case.
    No manufacturer wants another engine with a reputation like the Ford 6.0L diesel.
  4. Mar 9, 2023 at 8:31 AM
    #454
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    To reinforce your point, it's closer to 117K produced and sold.
  5. Mar 9, 2023 at 5:36 PM
    #455
    HBV2017
    HBV2017 [OP] New Member
    Just got word that the truck is done. My dealership is arranging transportation back up and I’ll update you guys as soon as I get it back!
  6. Mar 9, 2023 at 5:37 PM
    #456
    Coal Dragger
    Kung Fu Dick
    That sure as hell didn’t take 6 weeks.
    Good to hear, good luck OP!
  7. Mar 9, 2023 at 5:37 PM
    #457
    Great to hear! Less than a month, not bad. Hope it’s a solid repair!
  8. Mar 10, 2023 at 12:10 AM
    #458
    RookieEP
    RookieEP New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    Paws crossed you’re all good now. What’s the break in procedure for the new engine?
  9. Mar 10, 2023 at 3:37 AM
    #459
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    ToyCorp's procedure is to avoid using the starter until the short block warranty has expired.
    Then use starter as per the usual method.
    Rich2001, mayan, Leo's first and 7 others like this.
  10. Mar 10, 2023 at 6:56 AM
    #460
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Hopefully he got some bigger snails.
  11. Mar 10, 2023 at 12:55 PM
    #461
    justme!
    justme! New Member
    NY
    This is the second post I've seen about breaking in the engine. Why? Isn't first oil change after a few thousand miles enough? When did our trucks get so fragile? Maintaining them to last a long time is a different story than this break in period.
    OnThaLake likes this.
  12. Mar 10, 2023 at 1:02 PM
    #462
    Why? Because a ton of engineers who built and designed these motors came to enough of a consensus and agreed following those instructions would help extend the life of the engine and components. I can get into more technical reasons, but that alone is reason enough for me. I am not an engineer and I certainly don't design and build motors. As far as your second question..every vehicle I have owned since 2003 which includes a Ford, Chevy, Dodge, Honda, Hyundai and four Tundras has had break in procedures listed in the manual.
    ArmygreenTRD, KNABORES and 4genRunner like this.
  13. Mar 10, 2023 at 1:03 PM
    #463
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Maybe because Toyota recommends it? It's right there in the owners manual....
  14. Mar 10, 2023 at 3:01 PM
    #464
    Kap1
    Kap1 New Member
    San Francisco, CA
    Ta da dum!
    https://youtube.com/watch?v=nBBUQJKTaiM&si=EnSIkaIECMiOmarE
    Mattedfred likes this.
  15. Mar 10, 2023 at 3:13 PM
    #465
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
  16. Mar 10, 2023 at 3:29 PM
    #466
    Black widow TRD
    Manuel
    Git er done!!
    Eurodriver likes this.
  17. Mar 10, 2023 at 3:42 PM
    #467
    Careful with that water. Might get some in the intake and cause Toyota to get blamed for a crappy motor ;)
  18. Mar 10, 2023 at 4:41 PM
    #468
    Melikeymy beer
    Muscogee Nation
  19. Mar 10, 2023 at 7:52 PM
    #469
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I wonder how many people really let their turbo charged engine in the Tundra idle for a minute. For example, going down a highway and pulling into a rest stop to take a leak. I bet the number of folks that do that is small.
    mayan and fuzzamungus like this.
  20. Mar 10, 2023 at 7:56 PM
    #470
    Count me as one that does.
  21. Mar 10, 2023 at 8:10 PM
    #471
    Black widow TRD
    Manuel
    Same, I’ll even turn the remote start to allow it to cool.
    Henry1jg, Mattedfred and WAtundra4x4 like this.
  22. Mar 10, 2023 at 8:27 PM
    #472
    4genRunner
    Southwestern MO
    The coolant loop for the turbos is separate and has an electric water pump. If you turn it off when very hot it will keep the turbo coolant loop running. Of course it’s always better if you keep the oil circulating as well.
    WAtundra4x4[QUOTED] and TILLY like this.
  23. Mar 11, 2023 at 5:22 AM
    #473
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    I thought the auto stop could not be disabled on the hybrid engine.
    bc
  24. Mar 11, 2023 at 6:27 AM
    #474
    John_in_NC
    John_in_NC New Member
    North Carolina
    2022 Black Toyota Platinum
    Side Steps
    A bit disheartening, I am about to have an early 10K service on my 2022 Platinum prior to a 4K+ mile road trip. I guess I better check everything myself afterward!
    Sounds like it is going to get heated between the two dealerships, hopefully Toyota has a corporate investigator to really handle the situation. Good luck!
    RookieEP likes this.
  25. Mar 11, 2023 at 8:04 AM
    #475
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    I've compared the 2023 Toyota Tundra Owner's Manual (page 176) and the 2023 Toyota Tundra Hybrid Owner's Manual (page 172) and only the gas version owner's manual makes reference to idling after high-speed driving or hill climbing to prevent damage to the turbochargers. If the gas version and the hybrid have both been used for high-speed driving or hill climbing, I don't know why idling times are identified for the gas version only. Any ideas?
    WAtundra4x4[QUOTED] likes this.
  26. Mar 11, 2023 at 8:07 AM
    #476
    fastarget
    fastarget New Member
    2023 Max Platinum
    Unless they have recirculating pumps(some sports cars do, but dont think Tundras do) to cool the turbos down. Our hybrid I cant control the idling since I would let it run 20-30 sec before shutting it off, but it shuts off on its own. Good Synthetic oil is your friend as far as turbos go.
    raylo likes this.
  27. Mar 11, 2023 at 10:23 AM
    #477
    Kap1
    Kap1 New Member
    San Francisco, CA
    Maybe it's just that hybrid can't really be controlled to let it "idle" so Toyota kind of just gave up on this point?
    Ps I'm a big idler, warm up my truck for 5+ min and cool down for a couple min
    rst likes this.
  28. Mar 11, 2023 at 3:10 PM
    #478
    frozen_tundra
    frozen_tundra New Member
    2022 Tundra SR Crewmax Black
    I’m curious on this as well. Is there a separate electric water pump or something on only the hybrid model? It should have the same idle time requirements as the non-hybrid if it doesn’t have some kind of additional oil or water cooling capability….??
  29. Mar 11, 2023 at 7:35 PM
    #479
    Sr5yota
    Sr5yota New Member
    It could be that with the HV system, less power is directly needed from the engine and turbos. The reduced stress on the turbos can have them run cooler and with the additional output from the HV system, it would be easier to have ecu programmed logic for cool down strategy.
    frozen_tundra likes this.
  30. Mar 11, 2023 at 7:46 PM
    #480
    Black widow TRD
    Manuel
    Perhaps as the hybrid engine runs it also turn the oil pump on the engine. Both motors are joined at the transmission.
