General Supercharger Thread
  1. Mar 4, 2023 at 7:50 AM
    #6241
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I have a question for the guys who tow - does the supercharger help engine braking performance? I've watched TFL's towing tests of the TRX and Raptor R and it seems like they do incredibly well not needing brake inputs on downhills.
  2. Mar 4, 2023 at 8:05 AM
    #6242
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    If in tow/Haul, it's the same as NA...you can modify some parameters of the transmission but it's a simple 6 speed compared to the 8 and 10 speeds that have more going on then the pumped up motors...towing us incredible with the SC...makes the truck an actual capable truck...braking is where the differences truly start...no true changes in transmission tho...my tcu optimization I feel has helped but more for moving forward while accelerating vs braking
  3. Mar 4, 2023 at 8:26 AM
    #6243
    snivilous
    SW UT
    300k+ Supercharged 2008
    No difference. When engine braking the supercharger is in bypass mode so it's not adding any boost to the engine for the pistons to compress. Maybe on a more sophisticated setup the boost could be allowed when braking and increase the cylinder pressure, but not on our setups.
  4. Mar 4, 2023 at 10:02 AM
    #6244
    Saltyhero13
    Saltyhero13 Throbbing Member
  5. Mar 4, 2023 at 10:38 AM
    #6245
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Soooo.... After doing some "things and stuff" (fattening up the WOT AFRs to safer and seeing I'm blowing through my Inj DC), it appears that it would be prudent to upsize my TRD injectors to the Prospeed 750s (go big or go home, right) and do the @snivilous patented "cut/solder/prune connector mod". As I live in an area where getting things shipped is mildly complicated (it blows), can anyone comment on the shipping method that Prospeed seems to be using (FedEx/UPS/USPS)?
  6. Mar 4, 2023 at 10:42 AM
    #6246
    HulkSmurf14
    2014 Tundra Limited
    This upgrading badass SCs all of a sudden for many of us is wild! Great minds think alike!
    Hopefully anyone not USPS helps you out!
    e30cabrio, AZTundra and Wynnded like this.
  7. Mar 4, 2023 at 10:57 AM
    #6247
    AZTundra
    Paul
    Phoenix, AZ
    Why not go with the FiveO injectors? They are drop in and no plug extensions are needed. The discount code I posted earlier will save you $40 making them only $60 more than the prospeed.
  8. Mar 4, 2023 at 10:59 AM
    #6248
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Oooooh, investigating....!
    HulkSmurf14 and snivilous[OP] like this.
  9. Mar 4, 2023 at 11:02 AM
    #6249
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    If you sign up for Five-o mailing list you get 10% off, if they still have it. I paid $710
  10. Mar 4, 2023 at 11:22 AM
    #6250
    snivilous
    SW UT
    Agreed with above, I'd go with the FiveOs. They're probably real 750s too, instead of "750" that's actually a 725 from the company they buy from, that actually test as a 715 in reality :rofl:
  11. Mar 4, 2023 at 11:44 AM
    #6251
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Went with the recommended FiveO Motorsports injectors.:thumbsup: Thanks gang!
  12. Mar 4, 2023 at 2:02 PM
    #6252
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    IC pump installed. Ran the harness, verified function, disconnected the harness so it's not running. Waiting for the O rings to do the injectors & running the gas out before I can do the pump.
  13. Mar 4, 2023 at 2:26 PM
    #6253
    HulkSmurf14
    2014 Tundra Limited
    It looks like the PS would be easier to weld a bung in...however, to do it "right," one would disconnect at the collector flange and weld accordingly...at that point, one may as well remove the front prop-shaft on DS and install on the DS...this is from underneath, obviously, so here are the pics... I'm thinking 180° from the OE O2 sensors?
    @Sniv, can you get under and snap a picture of yours by chance? Or whomever has access to a lift for a quick pic?
  14. Mar 4, 2023 at 2:33 PM
    #6254
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This is the pic of his that he sent me when I asked him that same question prior to installing mine.
  15. Mar 4, 2023 at 2:40 PM
    #6255
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    It should probably be removed either way like you said to drill the hole for the bung. Metal shavings in the converters can cause hot spots and premature failure I was told by my mechanic. This isn’t mine, but is exactly how mine is installed on the drivers side after the primary O2.
  16. Mar 4, 2023 at 2:42 PM
    #6256
    e30cabrio
    Is that area accessible?
  17. Mar 4, 2023 at 2:44 PM
    #6257
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Pops just picked the rig up. Hasn’t got on it all the way yet but he did say pulling away from the light with partial throttle did light up the 37s easier than the maggy. More info to come as he drives more. I said it’ll come alive when we pulley it up etc. Also added the carbon vented hood to keep that heat out.
  18. Mar 4, 2023 at 2:47 PM
    #6258
    Silver17
    Eastern PA
    Not without removing the midpipe, and on the drivers side the driveshaft unfortunately. I’d probably do the passenger since it’s easier lol.
  19. Mar 4, 2023 at 2:49 PM
    #6259
    e30cabrio
    That's what I was afraid of.
    Regardless I have to remove my TRD skid :(
    Lol
    HulkSmurf14 likes this.
  20. Mar 4, 2023 at 2:56 PM
    #6260
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    At some point would truly love to hear that Whipple!!:) before all this happened with my truck i had it narrowed down to a Whipple and ProCharger. I was going to do the Whipple,, just to be different and love the way they sound!!!!
    reywcms[QUOTED] likes this.
  21. Mar 4, 2023 at 2:56 PM
    #6261
    M3Tundra-JK
    Scott
    2005 GX470
    Awesome! Can you link the hood?
    Black@Blue19 likes this.
  22. Mar 4, 2023 at 2:57 PM
    #6262
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    The noise is definitely more than the maggy he said. All around noise more whistles and whines
    Black@Blue19[QUOTED] likes this.
  23. Mar 4, 2023 at 2:57 PM
    #6263
    Black@Blue19
    Ken
    SE Texas
    Yes please on the hood. That looks very nice!!!:)
    M3Tundra-JK[QUOTED] likes this.
  24. Mar 4, 2023 at 2:58 PM
    #6264
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  25. Mar 4, 2023 at 3:08 PM
    #6265
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Carbon looks good :thumbsup:
    Black@Blue19 and reywcms[QUOTED] like this.
  26. Mar 4, 2023 at 3:51 PM
    #6266
    HulkSmurf14
    2014 Tundra Limited
    Gauge vent install...this vent is easiest but not ideal...life's a journey:
    >Pop off trim by prying door-side edge of trim out...pull from there.
    >Pop off chrome vent ring at the x3 clasps.
    >Pull trim apart by unscrewing x3 small philipshead screws. Separate the parts and put the original vents away.
    >Cut out grill inside vented trim piece. I used a pair of dykes/wire trimmers and made it smooth with a chisel.
    >Slide GlowShift gauge cradle (https://www.amazon.com/gp/aw/d/B083YVT188?ref=ppx_pop_mob_b_asin_title )over your PSB-1 and prepare your hold downs to size...I removed approximately 3/16" from each end to fit...
    >Measure and cut 1" thick window seal (from any Hardware store) around to fit inbetween the aluminum hold down.
    I'm leaving the plastic on gauge face until I next get it all hooked up...next up is getting the bung welded in...after that, a continuation of this saga...
    **edit, no I'm not on plastic wrapped gauge face...this looks better! There is still airflow as I didn't completely wrap in the gauge's entirety...I'd say you get the air flowing through 25% of the opening now...which is adequate.
    This idea is courtesy of @ssmokedz!
  27. Mar 4, 2023 at 4:13 PM
    #6267
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Can't be having that!!! :nuclear:
  28. Mar 4, 2023 at 4:44 PM
    #6268
    Saltyhero13
    Packaging looks great. Does it have a bypass valve?
  29. Mar 4, 2023 at 4:48 PM
    #6269
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    yes
  30. Mar 4, 2023 at 5:00 PM
    #6270
    snivilous
    SW UT
    As I recall I pulled my exhaust to do the sensor, with some extensions and an impact it was pretty fast. And passenger side (picture Wynnded posted from me) was easiest to mark out and had the most room (and met the mounting requirements in the instructions). But it's been a long time since I installed it, so maybe my memory of my reasoning is bad :D
