Lift Advice - 2004 DC 2wd
Discussion in '1st Gen Tundras (2000-2006)' started by hack_tc, Jan 7, 2023.
  1. Mar 3, 2023 at 8:43 AM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Pic just for reference, 4.75" backspace with 1.25" spidertrax spacer. no frame rub but rubbed on the pinch weld. @alb1k found the the happy medium with the 3/4" spacer but he is also running a bigger tire.
    des2mtn and alb1k like this.
  2. Mar 3, 2023 at 9:28 AM
    Pronto13
    Pronto13 New Member
    ‘06 white DC SR5 V8/4wd
    What size tires and wheels?
  3. Mar 3, 2023 at 9:30 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Looks like they don't make them for my truck. Only diff might just be bolt spacing/size on those plates though. I might just have to order them and fab some secondary plates
  4. Mar 3, 2023 at 9:30 AM
    805Tundra
    Ben
    Central Coast
    Method 305s 17x8.5 4.75" backspace with 285/70/17
    Pronto13[QUOTED] likes this.
  5. Mar 3, 2023 at 10:12 AM
    Casper421
    In the woods
    06 DC
    Did you install longer studs? Have a link for the 3/4" steelies?
  6. Mar 3, 2023 at 12:03 PM
    alb1k
    Left Coast
    It's good
    Don’t need longer studs because they are studded. I’ll find a link.
    these guys, I believe they are tied to Bora.
    https://www.motorsport-tech.com/truck_ss.html
    Casper421[QUOTED] likes this.
  7. Mar 3, 2023 at 6:05 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Pics for more reference....
    285/75/17. 8.5 rim width -6mm offset 4.5" bs
    Pronto13 likes this.
  8. Mar 4, 2023 at 8:47 AM
    Pronto13
    Pronto13 New Member
    Spacers? How much rub?
  9. Mar 4, 2023 at 8:54 AM
    Pronto13
    Pronto13 New Member
    Watch this and tell me if you think this could solve my issue?
    https://youtu.be/MJK8c0pBKPs
    my passenger side tire is much farther back towards rear fender and my cam bolts/SPC uppers are in a way different position than his. I’m wondering if this alignment setup could fix my issue by pushing the tire forward.
  10. Mar 4, 2023 at 10:46 AM
    alb1k
    Left Coast
    It's good
    Moving the wheels forward helps on these trucks, especially if your front bumper is modded and or washer reservoir is relocated. I’m running solo LCAs which move the wheel forward about 1”. Here’s my driver side.
    you can see fender and flare are cut back 1 1/2”, but I still hit the cab in there.
    bumper needs a trim for aesthetics only.
    24B40D42-964E-44C1-BE35-C02337C89052.jpgE2C6224C-CF64-4FF1-934F-577F55C22CF4.jpg12B58FAC-60A4-4113-9677-58969BBE0475.jpg
  11. Mar 4, 2023 at 11:01 AM
    alb1k
    Left Coast
    It's good
    Here’s the front poke. 15mm + 13mm + 19.5mm =47.5mm = 1.86 inches past OEM.
    Thats for offset, wheel width and 3/4” spacers.
    des2mtn, shifty` and Pronto13 like this.
  12. Mar 4, 2023 at 7:31 PM
    daveeasa
    Erik doesn't have holes in his bumper like I do, waiting for lightzzzz. Looks so killer.
    des2mtn likes this.
  13. Mar 4, 2023 at 8:42 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    The real magic is the cheapo marker lights. On the highway you can easily tell it's him in the rear view mirror :)
    One of the nicest little flairs on his truck tbh.
    alb1k and daveeasa[QUOTED] like this.
  14. Mar 5, 2023 at 8:38 AM
    alb1k
    Left Coast
    It's good
    Best little shitty lights around, lol
  15. Mar 8, 2023 at 9:41 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    No spacers, no rub normal driving I don't wheel it so not sure if it would with suspension compressed.
