General Supercharger Thread
  1. Mar 2, 2023 at 11:44 AM
    #6211
    AZTundra
    Paul
    Phoenix, AZ
  2. Mar 2, 2023 at 1:21 PM
    #6212
    snivilous
    SW UT
    300k+ Supercharged 2008
    So you received the green ones and then bought the Five-O ones? Or one of those are the ones that came off your truck?
    I tried looking for a picture I thought I had taken, on my truck at least the OEM injector is tan and long and the Magnuson supplied are short and green. The Five-O ones Ive seen appear to have a stock (tan) looking body but obviously flow more.
  3. Mar 2, 2023 at 1:44 PM
    #6213
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    The green came with the SC, I bought the Gold 5-0s
    They came with these sheets:
    snivilous[OP] and M3Tundra-JK like this.
  4. Mar 2, 2023 at 1:50 PM
    #6214
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Got the base ordered. Was $57 after shipping
    Silver17[QUOTED] and e30cabrio like this.
  5. Mar 3, 2023 at 4:01 AM
    #6215
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What are you using for airbox upper?
  6. Mar 3, 2023 at 4:58 AM
    #6216
    M3Tundra-JK
    Scott
    2005 GX470
    reywcms and e30cabrio like this.
  7. Mar 3, 2023 at 5:01 AM
    #6217
    e30cabrio
    Does the TRD upper use the 07-13 lower or a different one?
    Asking in case I have issues.
  8. Mar 3, 2023 at 5:20 AM
    #6218
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Should be 07-13 lower for any airbox lid made for the supercharger kit.
  9. Mar 3, 2023 at 5:38 AM
    #6219
    e30cabrio
    HulkSmurf14 likes this.
  10. Mar 3, 2023 at 7:33 AM
    #6220
    e30cabrio
    Sorry I did not respond to the AFR gauge placement. I'm thinking here if it has room behind to fit.
    AZTundra and HulkSmurf14 like this.
  11. Mar 3, 2023 at 7:42 AM
    #6221
    snivilous
    SW UT
    Here's where mine is for the 07-13 guys who don't use the stock brake controller:
  12. Mar 3, 2023 at 7:52 AM
    #6222
    AZTundra
    Paul
    Phoenix, AZ
    @nobodyintexas You got a gauge added recently too right? Where did you mount it?
  13. Mar 3, 2023 at 7:52 AM
    #6223
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I received it yesterday...I didn't notice there was an Upgrade link next to my MPVI2 in Devices, I could have done it that way and had the credits transferred...I put in a support ticket to get them transferred over to the MPVI3.
    e30cabrio likes this.
  14. Mar 3, 2023 at 8:03 AM
    #6224
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    e30cabrio and AZTundra[QUOTED] like this.
  15. Mar 3, 2023 at 8:05 AM
    #6225
    nobodyintexas
    nobodyintexas What?
    South of Houston
    AZTundra likes this.
  16. Mar 3, 2023 at 8:10 AM
    #6226
    nobodyintexas
    nobodyintexas What?
    South of Houston
  17. Mar 3, 2023 at 8:11 AM
    #6227
    AZTundra
    Paul
    Phoenix, AZ
    Sweet. I believe that's the mount I'm going with as well, but will likely do the Innovate PSB-1 gauge. I did see another mount on a Youtube video of a supercharged Tundra where the gauge was mounted inside the ac vent on the left side of the dash. Been trying to find that video again to see what mount was used, but no luck finding it so far. I'll post up a picture if I can find it and maybe someone will know what mount that is.
  18. Mar 3, 2023 at 8:24 AM
    #6228
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This is what I did as well. With the combination gauge I only used the one pod, mounting it on the left hand side. The only indicators that it obscures are the left turn signal, and the Check Engine Light. A slight tip of the head brings them back into sight though.
  19. Mar 3, 2023 at 8:27 AM
    #6229
    AZTundra
    Paul
    Phoenix, AZ
    M3Tundra-JK likes this.
  20. Mar 3, 2023 at 8:32 AM
    #6230
    Silver17
    Eastern PA
    I like the cravenspeed mount. Looking at those gauges in my face makes me feel like I’m about to stop into Harry's and order 3 t66 turbo's with NOS and a Motec System exhaust as I drive along.
    Danimal86, reywcms, ZPhilip and 2 others like this.
  21. Mar 3, 2023 at 9:59 AM
    #6231
    ZPhilip
    Philip
    West Chester, PA
    Did the shop install the AFR gauge crooked or do you want it that way?
  22. Mar 3, 2023 at 10:34 AM
    #6232
    nobodyintexas
    nobodyintexas What?
    South of Houston
    It moved a tad
    I need to nudge it
    reywcms likes this.
  23. Mar 3, 2023 at 11:42 AM
    #6233
    AZTundra
    Paul
    Phoenix, AZ
    Just ordered a couple pieces to the puzzle this morning.
    • FiveO Motorsports 750cc Injectors ($760.00 after 5% off)
    • Gates K081124HD belt from Grainger ($51.02)
    • Walbro 450 fuel pump with installation kit direct from Walbro ($194.99) with free standard shipping
    • TRD/Magnuson Coupler Replacement Kit with o-rings from Superchargers Online (SCOL) ($149.99)
    • TRD/Magnuson 76MM Idler from SCOL ($168.99)
    I have a slight squeal most noticeable around 800-1200 rpm's, but not consistently. Toyota replaced the belt tensioner and fan bracket about two weeks ago as a fix. The squeal is still there, but not nearly as bad. I'm thinking it may be the supercharger idler pulley or the engine idler pulley emitting the tiny bit of squeal that is left. I figured since everything is off might as well swap both those pulley's to see if that clears it up.
    Things I still need to order:
    • @snivilous 2.2/2.1 pulley with hub (once available)
    • Cravenspeed FlexPod
    • Innovate PSB-1
  24. Mar 3, 2023 at 12:14 PM
    #6234
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  25. Mar 3, 2023 at 12:28 PM
    #6235
    AZTundra
    Paul
    Phoenix, AZ
    When I went to the checkout it had a box for discount codes. I did a quick google search and found nothing recent, but it looks like they do 15% off sales around the holidays with codes. I sent a quick email to them and got a response within a couple minutes. I just asked if they had any current discount codes or any upcoming sales. They replied asking what I was looking to order and they would check to see if there are any current discounts on those parts. I shot back an email with the injectors I needed and about 30 minutes later he emailed me to use this code: "FIVEOFFCART5" (number 5, not letter S). That gave me 5% off saving me $40. Not a huge savings, but I'll take it since all of this adds up pretty quick.
  26. Mar 3, 2023 at 12:30 PM
    #6236
    HulkSmurf14
    2014 Tundra Limited
    I like your tenacity! Thank you for the heads up! I got my PSB-1 and Glowshift in today so I plan on fitting things up soon...
  27. Mar 3, 2023 at 12:35 PM
    #6237
    AZTundra
    Paul
    Phoenix, AZ
    Let me know how it goes with the gauge install. I really like the clean look of it being in the vent, but wasn't a fan of the P3 gauge. Will the vent cradle drop into place or need modification to fit the Tundra? Any idea where you plan to weld the bung on the exhaust? Trying to find the right location based off feedback from others.
    HulkSmurf14[QUOTED] likes this.
  28. Mar 3, 2023 at 12:42 PM
    #6238
    HulkSmurf14
    2014 Tundra Limited
    I will for sure and post photos of the finding/results...The cradle just drops in and isn't secured by anything other than weight and compression of the gauge...The cradle should just drop in without modification. I'm going to check and see what side and where the bung will be added...Sniv and others have used the passenger side as it's much easier to get to and weld in...the driver's side would be best only due to Cylinder 5 being an often culprit of when these motors go and start getting stretched tired....but we'll see...I likely will do the PS due to ease but I'll know more this weekend...
  29. Mar 3, 2023 at 2:58 PM
    #6239
    e30cabrio
    IC coolant pump harness, reservoir & spark plugs came, all that is outstanding are the gaskets for the TB & coolant crossover & SC hose kit, all from Toyota supposed to come next week.
    I wired up the harness & tested the pump, it runs!
    Also, I have 2 S&B dry filters I forgot about so have a temporary solution if I can't get the AFE to work.
    Also, a new AFE wet, don't know if it's big enough to attach. We'll see.
  30. Mar 3, 2023 at 5:52 PM
    #6240
    e30cabrio
