Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Feb 17, 2023 at 7:08 PM
    #1021
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    That would be mind blowing except for the fact that she drives my truck 5 days a week now. She’s noticing things :rofl: How come your vents don’t work? Your truck is squirrelly on the freeway, I don’t like it. Did you know your windshield is cracked? Did you know your speedometer is not accurate? o_O:rolleyes::anonymous:
  2. Feb 17, 2023 at 7:14 PM
    #1022
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I’m glad my old lady doesn’t want to drive mine
    Lol
  3. Feb 17, 2023 at 7:16 PM
    #1023
    Cruzer
    Cruz
    Sunnyvale, CA
    Oh she hates driving the truck but her commute to work is 12 miles round trip while mine is 70,
  4. Feb 17, 2023 at 7:26 PM
    #1024
    Ew!
  5. Feb 17, 2023 at 7:28 PM
    #1025
    Cruzer
    Cruz
    Sunnyvale, CA
    Riiiiight? :rofl:
    eccracer104 likes this.
  6. Feb 17, 2023 at 7:32 PM
    #1026
    I used to drive 3-4k a month(in a company truck) it suuuuuuucked!!!! And In some of the same traffic you do! I started to take side streets to free my mind
  7. Feb 18, 2023 at 9:03 AM
    #1027
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It's time for another vehicle. Or, best case would be to get her on a bike. :rofl: Maybe an E-bike
  8. Mar 1, 2023 at 7:29 PM
    #1028
    Cruzer
    Cruz
    Sunnyvale, CA
    So I bought a 16 relay board
    This weekend I will attempt to hack the 4WD ECU and the Transfer Case actuator. The goal is to trick the truck into thinking it's in 2WD while I manually shift it into 4WD.
    Why? My truck has not been shifting when in 4LO, it's stuck in first gear, but shifts fine when in 2WD or 4HI. Also, when in 2WD everybody here knows that the Tow Haul Mode button gives the truck some extra oomph when the ECM shifts the throttle angle more open by a few degrees. However, the Tow Haul Mode is disabled when you go into 4WD.
    I will hopefully be solving two problems at once 1) shifting issue in 4LO and 2) torque issues when crawling big obstacles.
    Through an Arduino the relay board will be used to disconnect certain pins on the wire harness between the 4WD ECU and the Actuator so that the actuator is unable to notify the ECU, via internal trigger switch position changes, that voltages have changed. I will also configure it so that the relays apply power to rotate the actuator motor that shifts in/out of 4HI/4LO. There are still a couple of unknowns that I need to figure out but won't know until I start chopping shit.
    :fingerscrossed:
  9. Mar 1, 2023 at 7:30 PM
    #1029
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    You sound like a mad scientist :bananadance:
  10. Mar 1, 2023 at 7:57 PM
    #1030
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    :popcorn: :popcorn: :popcorn:
  11. Mar 1, 2023 at 8:24 PM
    #1031
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Sorcery!
  12. Mar 1, 2023 at 8:46 PM
    #1032
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  13. Mar 2, 2023 at 3:46 AM
    #1033
    daveeasa
    Super cool! I love the initiative.
    Cruzer[OP] likes this.
  14. Mar 2, 2023 at 7:11 AM
    #1034
    Cruzer
    Cruz
    Sunnyvale, CA
    Here's my initial wiring plan. I just need to figure out how TL1-TL4 works with the actuator motor (TM1/TM2) and the Solenoid Coil (SCC). I want to automate as much as possible so I'm hoping that I can use TL1-TL4 as a trigger to stop applying voltage to the motor and coil. Won't know until I get in there.
  15. Mar 2, 2023 at 7:44 AM
    #1035
    SAGE63
    San Diego County
    looks like you have been and still have some signal chasing to do.
    Cruzer[QUOTED][OP] likes this.
  16. Mar 2, 2023 at 7:57 AM
    #1036
    SAGE63
    San Diego County
    Cruz just ignorant curiosity, are you just transferring signals or actual power? if power I understand the relays but if digital signals why not a smaller pcb utilizing and gate ICs and remove the potential for sticking relays
  17. Mar 2, 2023 at 8:13 AM
    #1037
    Cruzer
    Cruz
    Sunnyvale, CA
    The relays are definitely needed to operate the motors and coil. I could probably use ICs for the other pins but this board is the quick and dirty version for me. If this works, then I may have to pick your brain at T2S to figure out how to shrink this :D
  18. Mar 2, 2023 at 8:35 AM
    #1038
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Sunnier, Mater, eccracer104 and 2 others like this.
  19. Mar 2, 2023 at 11:09 AM
    #1039
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    From "how do I keep my beer cans from rattling in the fridge" to "i'm designing a computer to control my transfer case". This thread has EVERYTHING!
    BOSSARU, biebs96, bulldog93 and 9 others like this.
  20. Mar 6, 2023 at 7:32 AM
    #1040
    Cruzer
    Cruz
    Sunnyvale, CA
    Messing with the 4WD ECU turned out to be a lot harder than I expected BUT I am making progress.
    Turns out that whenever you disconnect a single pin, basically when the 4WD ECU can no longer detect what's on the other end, it will flash you 4HI/4LO all day long and won't let you change TC modes. I spent a lot of time gathering data, collecting voltage, current and resistance, at different stages of the transfer case (2WD, 2WD>4HI, 4HI, 4HI>4LO, 4LO, 4LO>4HI, 4HI, 4HI>2WD, 2WD; pin connected, pin disconnected, etc.) Found out that the TC Actuator uses diodes to regulate voltages. Anyways, long story short, I've figured out how to trick the 4WD ECU into thinking it's still in 2WD mode on 7 out of the 10 pins. The remaining 3 pins required me to order more parts so I'll be at it again next weekend.
  21. Mar 16, 2023 at 8:22 PM
    #1041
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
  22. Mar 18, 2023 at 9:01 PM
    #1042
    Cruzer
    Cruz
    Sunnyvale, CA
    9 out of 10 pins tricked! I'm thinking I can ignore this last pin to SCC. So I'm moving forward. I'm writing up the code to create an app that will change the modes. Pretty basic, looks like this. Hoping I can do a test drive tomorrow.
  23. Mar 18, 2023 at 9:04 PM
    #1043
    helidave
    flagstaff
    2015 DC 4x4
    What does manual mode do?
  24. Mar 18, 2023 at 9:14 PM
    #1044
    Cruzer
    Cruz
    Sunnyvale, CA
    That's when relays are triggered prior to ignition start to trick the ECU that it's in 2wd. When I manually change to 4hi or 4lo, the ECU will still think it's in 2wd.
    Sunnier and helidave[QUOTED] like this.
  25. Mar 22, 2023 at 12:27 PM
    #1045
    Cruzer
    Cruz
    Sunnyvale, CA
    On the road somewhere
  26. Mar 22, 2023 at 5:00 PM
    #1046
    Cruzer
    Cruz
    Sunnyvale, CA
  27. Mar 22, 2023 at 5:02 PM
    #1047
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hahaa the student driver sticker. Well done
    bulldog93, Sunnier, Mater and 2 others like this.
  28. Mar 22, 2023 at 5:05 PM
    #1048
  29. Mar 22, 2023 at 5:19 PM
    #1049
    Careful who is behind you at pit stops in Sedona………
    reywcms likes this.
  30. Mar 22, 2023 at 5:22 PM
    #1050
    Cruzer
    Cruz
    Sunnyvale, CA
