LED LIGHTS from LASFIT 15% off CODE
Discussion in '1st Gen Tundras (2000-2006)' started by Mhagha, Feb 5, 2023.
  1. Feb 5, 2023 at 4:45 AM
    Mhagha
    Mhagha [OP] New Member
    Hey,
    I just purchased new LEDS for my truck from LASFIT. I was sent a 15% off code yesterday. It expires on 2/12/23 I don't know how many times it can be used but here is the code if anyone needs it .
    CODE is DSY6-SFNT-USK4
    Teutonics, shifty` and Mustanley like this.
  2. Feb 5, 2023 at 7:39 AM
    I was curiously looking at their LS Plus series bulbs a while back but opted to stay w/Halogens. If the coupon is expired, coupon FIRST10 will get you 10% off too.
    Mhagha[OP] likes this.
  3. Mar 1, 2023 at 4:38 PM
    Mhagha
    BTW in case anyone else has this problem.....
    After installing LEDS, My high beams would not come on. When I pressed the button for fog lights the fog lights didn't work and my high beams came on. I did some research and there is a Motorcycle headlight Load resistor ( part # H4-RL650-M) that you install and it resolves this issue.
    Purchased for $9 from superbrightleds
  4. Mar 1, 2023 at 5:03 PM
    Yup, the need for a resistor is covered in most of the LED threads, and the general info thread stuck to the top of the thread list.
