General Supercharger Thread
  1. Mar 1, 2023 at 7:24 AM
    #6181
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I've seen people say this, and also that after a big tune the MPG readout on dash isn't correct. That you need to do the math on fillup to verify
  2. Mar 1, 2023 at 7:38 AM
    #6182
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I'm going by my Scanguage 3. it WAS within a 1/10 of a gallon on fillups.
    but to your point...the new tune may have did a 3 card monty on me. he did make the mix richer.
    the SG3 has a nice way of modifying the full usage when you fill up...it "learns". we'll see.
  3. Mar 1, 2023 at 7:42 AM
    #6183
    nobodyintexas
    nobodyintexas What?
    South of Houston
    are these still avail? I tried a cursory search and came up with zilch.
    Saltyhero13 likes this.
  4. Mar 1, 2023 at 7:46 AM
    #6184
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Since those with long travel have no liners my plan is to route the 5” opening into the cowl area for cool fresh air. Also have it sit a bit higher since the wheel well area will be getting fully cut out for clearance
  5. Mar 1, 2023 at 7:47 AM
    #6185
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Cowl area for fresh air
    HulkSmurf14[QUOTED] likes this.
  6. Mar 1, 2023 at 7:47 AM
    #6186
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    You can piece an SABM together for very cheap. That’s what I did via the Amazon
    HulkSmurf14 likes this.
  7. Mar 1, 2023 at 7:48 AM
    #6187
    M3Tundra-JK
    Scott
    2005 GX470
    I just ordered:
    TRD 98mm airbox top for $172 - PTR03-34083
    TRD Airflow inlet for $18 - PTR03-34079
    TRD intake tube is $31 - PTR03-34082
    I need to call SCOL to order the lower air filter housing
    e30cabrio likes this.
  8. Mar 1, 2023 at 7:49 AM
    #6188
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I would imagine so. In January 2022 I was in contact with Nergal at SCOL about ordering one new. The prices at that time were as follows:
    The Airbox Base is $45.00
    The Lid is $155.00
    Shipping $22.00 - $25.00
    You can email him and find out price and availability at:
    Nergal@superchargersonline.com
    I too pieced together the SABM parts with cheap stuff from Amazon.
  9. Mar 1, 2023 at 7:50 AM
    #6189
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Buttoned up my basket & tested, the pump runs! Waiting for FIVE O 650s, IC harness and IC coolant reservoir. Getting close, need a pulley!! (the puller is out for delivery)
  10. Mar 1, 2023 at 11:33 AM
    #6190
    M3Tundra-JK
    Scott
    2005 GX470
    @snivilous can you add this to front page?
    or wait, that's not the maggy replacement filter I'm looking for. Anyone know that part number? I'm digging through search feature atm
    Edit: found it
    snivilous[OP] likes this.
  11. Mar 1, 2023 at 11:46 AM
    #6191
    M3Tundra-JK
    Scott
    2005 GX470
    Also, I emailed SCOL about the lower air box. He said he'd never heard of the 2007-2013 lower box being larger than the top part. When I look through both Toyota 2014- and Magnusun instructions, it only has you changing out the lid. He's gonna go grab the dimensions off the lower box so I can compare against my 2021
  12. Mar 1, 2023 at 11:57 AM
    #6192
    Saltyhero13
    Saltyhero13 Throbbing Member
    That filter is the largest AFE filter I could find that would fit in the Stillen airbox. Folks would need to run a 4.5" to 6" adapter to use it. Sorry for any confusion.
    M3Tundra-JK[QUOTED] likes this.
  13. Mar 1, 2023 at 11:58 AM
    #6193
    Silver17
    Eastern PA
    He gonn’learn t’day
  14. Mar 1, 2023 at 12:25 PM
    #6194
    Saltyhero13
    This is the dilemma I faced and part of why I went with the AFE filter. They offer several levels of filtration; a high flow oiled akin to the K&N, a reusable non-oiled one with better filtration just a notch below the high flow, and an oiled for offroad for heavy dust environments (best filtration but lower flow). Currently running the middle flow but plan on testing the other two out after my gauges and retune. I won't have dyno data of the three but may be able to gleam something from the PSI.
    Here is AFE's info:
    https://afepower.com/stock-replacement-and-universal-performance-air-filters
  15. Mar 1, 2023 at 12:32 PM
    #6195
    Saltyhero13
    It's been working better since they pushed the updates.
    nobodyintexas[QUOTED] likes this.
  16. Mar 1, 2023 at 12:34 PM
    #6196
    Silver17
    Eastern PA
    Here is the difference between an 07-13/magnuson filter and the smaller 2014+ filter.
  17. Mar 1, 2023 at 1:05 PM
    #6197
    e30cabrio
    It's a sticker!
    M3Tundra-JK likes this.
  18. Mar 1, 2023 at 1:19 PM
    #6198
    M3Tundra-JK
    Scott
    2005 GX470
    Yuppers!
      File size:
      255.1 KB
      89
    Silver17[QUOTED] likes this.
  19. Mar 1, 2023 at 2:05 PM
    #6199
    e30cabrio
    Pulley removal tool came, pretty solid!
    M3Tundra-JK and AZTundra like this.
  20. Mar 1, 2023 at 2:55 PM
    #6200
    AZTundra
    Paul
    Phoenix, AZ
    Well, I stopped by Dyno Comp today to inquire about doing my Magnuson coupler replacement along with installing the @snivilous pulley, new fuel pump, injectors, and smaller belt. I didn't get a good vibe from that place, but maybe it was just the guy behind the counter. He was telling me that for the coupler they would pull the supercharger and send it out to Magnuson for a rebuild. That rebuild would cost between $2,500 - $3,500 and take 3 weeks. I just sort of internally laughed to myself and still asked about the other items for the heck of it. He said they could install the fuel pump and injectors, but was trying to convince me they were not needed with the smaller pulley. He seemed to think sending the Mag off for a rebuild and then slapping the pulley on and doing a dyno tune for an additional $1,295 would be all I needed. Needless to say I was not impressed. I almost got the feeling I was interrupting his break. No one else was inside and he didn't seem busy at all.
    After that, cruised over to Westcott Designs who did my Magnuson install. Told them about the coupler rattle and that I'd like to install a smaller pulley, fuel pump, and injectors while the snout is pulled off. Talked about the parts I'd like to use and that I could order and bring everything in if that were easiest for them. They said they didn't see a problem with tackling that for me, but would need to talk with their lead installer and get back to me with an estimate for everything. Hoping that they will be able to do it and then I'll start ordering the parts and get an install date set up. I'll just need to get something lined up for the tuning piece.
    @e30cabrio - Are you still providing the pulley removal tool loan program (for a fee of course)? ;) Not sure if Westcott Designs would need it, but that puller looks a heck of a lot easier to use.
  21. Mar 1, 2023 at 4:02 PM
    #6201
    Saltyhero13
  22. Mar 1, 2023 at 4:08 PM
    #6202
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Well knowing that will most likely pull air from the fender well it won’t work in my application. Plus who knows when that’ll be ready and released
  23. Mar 2, 2023 at 6:08 AM
    #6203
    e30cabrio
    I don't understand how a company that provides expensive 100% discretionary spending services can be so unfriendly.
    Happy to share!
    AZTundra[QUOTED] likes this.
  24. Mar 2, 2023 at 6:41 AM
    #6204
    Saltyhero13
    When you get it all set up I would be curious to hear your experience with their Guard filter for offroad use.
    reywcms[QUOTED] likes this.
  25. Mar 2, 2023 at 9:30 AM
    #6205
    AZTundra
    Paul
    Phoenix, AZ
    Just got an email from Westcott Designs after stopping by yesterday to inquire about the coupler replacement, pulley install along with the Walbro 450 and 750cc injectors. They will take on the job for me! Guess I can start to order the parts and get the ball rolling.
    :yes:
    e30cabrio, M3Tundra-JK, BigAl and 6 others like this.
  26. Mar 2, 2023 at 11:04 AM
    #6206
    e30cabrio
    Injectors!!!
    Why are they totally different from the Magnusons?
    reywcms and snivilous[OP] like this.
  27. Mar 2, 2023 at 11:10 AM
    #6207
    snivilous
    SW UT
    300k+ Supercharged 2008
    They look identical to the stock ones. Question is why are the Magnusons different from stock.
    reywcms, M3Tundra-JK and HulkSmurf14 like this.
  28. Mar 2, 2023 at 11:12 AM
    #6208
    e30cabrio
    I am missing 6 of the doughnut O rings so interacted with FIVE 0 to get all the O rings, he said the green one was OEM. :dunno:
    This is my first interaction with Tundra injectors. :D
  29. Mar 2, 2023 at 11:38 AM
    #6209
    AZTundra
    Paul
    Phoenix, AZ
    Do you have a link? I'm not familar with RCA unless I'm just drawing a blank at the moment. Possibly looking to add the PSB-1 to the list as well. What are you doing for a mount? I was looking at the cravenspeed flexpod option, not sure if there is anything better out there.
  30. Mar 2, 2023 at 11:44 AM
    #6210
    e30cabrio
