Wind noise concern
Discussion in '3rd Gen Tundras (2022+)' started by Hogujak, Nov 26, 2021.
  1. Feb 20, 2023 at 1:34 PM
    #271
    Breathing Borla
    AZ
    great update
    my guess is they are having a hard time isolating this between the mirror and the door. either way, I agree, this has been going on for a long time now and its crickets from corporate.
    I am really really cringing if my new tundra, which isnt built yet, has this.
  2. Feb 20, 2023 at 1:36 PM
    #272
    Tundra23owner
    Tundra23owner New Member
    I just got my tundra 4 days ago and this issue is actually insane.. people had this problem a year ago and its not fixed?
    I feel like something bigger has to be done against Toyota for giving us shit quality for 70k spent on a vehicle.. smh.
  3. Feb 20, 2023 at 1:37 PM
    #273
    Breathing Borla
    AZ
    so yours has this as well?
  4. Feb 20, 2023 at 1:38 PM
    #274
    Tundra23owner
    Yeah two issues so far.
    Whistling/wind noise when its windy or a going above 30+
    Seatbelt censor in the rear going off but i temp fixed that by putting the seatbelt on.
  5. Feb 20, 2023 at 1:40 PM
    #275
    Breathing Borla
    AZ
    @wedemmoez
    without getting yourself in any kinda of trouble, can you offer any information?
    is this at least known and being taken seriously, its been going on for a long time now ?
  6. Feb 20, 2023 at 1:46 PM
    #276
    Tundra23owner
  7. Feb 20, 2023 at 1:57 PM
    #277
    Breathing Borla
    AZ
    how are you going to that and let the mirror fold?
    I would just test it with some painters tape that removes easily in case its not coming from the mirror
  8. Feb 20, 2023 at 2:22 PM
    #278
    wedemmoez
    wedemmoez New Member
    2022 Black Tundra TRD Pro
    I mentioned it in another thread. Its being tracked but its extremely hard to reproduce. We've tried to reproduce in our test vehicles but haven't been able to consistently get the "whistling" that some users report at highway speeds. I havent noticed it on my own Tundra, even with crosswinds at highway speeds.
    We rely on dealer reports for issues like this, but even the dealers reporting to us have been inconsistent in describing the noise. Based on the reports we're getting, it affects significantly less than 1% of vehicles. I'm not sure what the latest updates are, but I think the team responsible is handling on a case by case basis, so if you're experiencing unusual wind noise, report it to your dealer!
    Sorry i'm not more help on this specific issue, but its such a sporadic one. If you're able to reproduce this noise on your truck consistently, please send me a DM with a video and any steps you take. This can include driving conditions, wind speeds, try pressing on the windows/sunroof to see if it gets worse, etc.
  9. Feb 20, 2023 at 3:04 PM
    #279
    Tundra23owner
    Yeah I forgot about that part.. I’m going to see if I can fix the issue somehow. I’ll let y’all know
  10. Feb 20, 2023 at 5:45 PM
    #280
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    A couple things to note on my experience:
    My 22 1794 was incredibly quiet when I first bought it. Although there was a noticeable whistle on the drivers window only above 75mph. It wasn't enough to turn me off from buying the truck but it was present. Over the course of putting 9000-10K miles on the truck the wind noise got considerably worse. In addition my truck developed the upper door/window squeak/rattle where the upper door frame actually wiggles against the cab (this is a separate issue from the wind noise).
    I started complaining about the wind noise to my dealer around my 10K service and it took them a bit to get to a point where they agreed to replace all my window seals. The dealer did all the taping, etc that they're doing to try and determine where the wind noise is coming from but ultimately what i've realized is that each truck is different depending on where the seal isn't snug up against the upper door frame. Mine in particular from in the back of the window near the B pillar because the seals were flared out catching wind and causing noise. After the first round of new seals the drivers rear, passenger front/rear were both greatly improved (basically back to new truck level of quietness). However my drivers window seal was horrible and frankly I was disappointed that the tech even let the truck leave his bay looking like this (photo below). So here is where the issues began because the service advisors 'excuse' for the seal being in this condition was that it gets shipped in a small package and 'if i wait until summer when it's hot it will lay flat'. Well that explanation didn't quite resonate with me since the other windows were perfect. Another trip to the dealer and a second & third seal netted the same result. I told them I wouldn't accept the truck back like that so they got a regional tech out with another seal and now it looks like the other three and no longer has the dreadful wind noise at 70+.
    Window seal after 3rd replacement.
    Following the window seal was the upper door squeak/rattle situation which really can't be solved unless Toyota redesigns their inner door to cab seals and makes them substantially larger so the door seals to the cab tighter. I solved it myself by adding additional stick on auto/marine gasket above the existing cab seal to put additional pressure on the top of the door. I did this for both drivers and passenger front doors. This solved the problem of the upper door moving around when hitting bumps, but I don't consider this to be a long term solution. My hope is that Toyota comes with a future TSB for this issue, but time will tell.
    Henry1jg, FLTundra22, mayan and 3 others like this.
  11. Feb 20, 2023 at 6:32 PM
    #281
    ArticTundra
    ArticTundra New Member
    Cold
    That first photo is SOOO BAD. It looks like my 2 year old installed a window seal sold by Harbor Freight. SHAME. SHAME. SHAME.
  12. Feb 20, 2023 at 6:43 PM
    #282
    kstateskier
    Bradley
    Kansas City, MO
    Yeah I was pissed.
    FLTundra22 likes this.
  13. Feb 20, 2023 at 6:51 PM
    #283
    Tundra23owner
    Taped my mirror up and noise is still there, taking it to dealer tomorrow. I think it’s a gasket problem. Going to tape airways to the window and see if that helps. I’ll keep y’all updated
    Breathing Borla likes this.
  14. Feb 20, 2023 at 7:09 PM
    #284
    Tundra23owner
    doing this solved the whistling isssue from the driver side, now I hear the passenger a bit more lol. I’ll take it to Toyota tomorrow and see what they say.
    kstateskier and Kap1 like this.
  15. Feb 20, 2023 at 7:58 PM
    #285
    Kap1
    Kap1 New Member
    San Francisco, CA
    As others said, it seems that these wind noise issues are unique to each truck - depending where the seal gap is that's causing wind to intrude and whistle.
    My driver side always gets whistling noise above 40 mph. Originally, of I fold down my power mirror, the noise was gone and only would re-appear at about 70mph.
    However, now that my truck for 2k miles on it, folding mirrors does not help to get rid of the whistling noise. It's weird how something changed that folding mirror no longer helps with the noise. Even though nothing changed on my truck... Maybe some dust over the past 2k miles? Idk
    I tried taking up the whole mirror without any results, so I believe that my particular issue is probably window seal at the driver door. Didn't had a chance to do more taping...
  16. Feb 20, 2023 at 8:07 PM
    #286
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    I have a wind noise that is more than the other doors emanating from the drivers window, not a whistle, just more wind noise. I have an SR and I’m going to try taping the mirror.
  17. Feb 20, 2023 at 8:35 PM
    #287
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    Dang I don’t have the wind noise. I did the DB test and it was on par for my other cars 60-62
  18. Feb 20, 2023 at 8:36 PM
    #288
    Tundra23owner
    Going to try to pinpoint the problem tomorrow during the day and see if i can spot it.. but everyones truck is different.. hope toyota fixes this asap.
  19. Feb 20, 2023 at 9:31 PM
    #289
    Kap1
    Kap1 New Member
    San Francisco, CA
    A riddle: expensive, whistling and is all taped up. What is it?
  20. Feb 21, 2023 at 8:08 AM
    #290
    hassaan.shezad
    hassaan.shezad New Member
    So this is my theory of course, but in my opinion, the entire weatherproofing/ sealing/ sound proofing or whatever you want to call it is complete garbage. I suspect this to be the case for a couple reasons.
    Firstly, the weatherproof seal on the inside front passenger seal started peeling off for me, this didn’t cause any wind noise as it towards the inside of the vehicle but I showed it to my dealer, and they said they will replace it once they receive the part, here is the notes they left:
    WINDOW RUN ON INNDER SIDE HAS A DISFORMATION ON IT-CHECK AND ADVISE PLS. RIGHT FRONT DOOR GLASS RUN ON ORDER, PART ETA 2/21/2023 (today)
    Another thing is that a lot of people here, had their weather strip replaced multiple times (including me) which sometimes led to it being fixed and sometimes didn’t. And we can also see that some people taped up their side mirrors which fixed it for some, while for some it didn’t.
    User oxlsu40 also mentioned how “One of the service guys told me he has worked for Toyota for over 25 years, and these gaskets/seals were the "jankiest" he's ever seen.”
    So, this is why Toyota still hasn’t come up with a solution so far (my theory), the issue is very complex and diverse between different Tundra’s. I doubt Toyota will come up with a solution for my Tundra by Monday like they said. Let’s keep spamming Toyota and putting pressure and hopefully a recall will come out soon.
    Kap1 likes this.
  21. Feb 21, 2023 at 8:21 AM
    #291
    Breathing Borla
    AZ
    from reading everything, my best guess is the supplier was cheaper and the seals are just shit.
    I bet if they were slightly higher quality and slightly larger to put more pressure on the seal it would solve it
    It seems odd that they are saying its less than 1% of trucks when its sustained here, odd
  22. Feb 21, 2023 at 10:52 AM
    #292
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    I believe the above posts are true. Anyone notice that the door glass, upon closing the door, rattles/shakes too much?
    could it be due to the seals being substandard and don’t press against the surface enough?
  23. Feb 21, 2023 at 11:00 AM
    #293
    wedemmoez
    I posted about this in another thread, but the very large majority of Tundra owners don't have accounts on this forum. It seems like its a common problem when you have a thread of people complaining about it, but in terms of number of trucks with a wind noise issue that have been reported to dealers, its a minuscule amount.
    Also, I do not speak for Toyota, I'm sure there is a representative somewhere that can give you the company line. I'm just an engineer with the company who has some insight into the issues we're tracking.
    I've gotten PMs telling me the truck is garbage and I did a terrible job, someone else told me that I shouldn't procreate. If thats the response I'm getting for trying to help the forum out with information, I should just stop posting altogether.
    mayan, Henry1jg, ryanwgregg and 4 others like this.
  24. Feb 21, 2023 at 11:03 AM
    #294
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    That’s a shame. Private messages should contain content that the sender would not be embarrassed to post publicly.
  25. Feb 21, 2023 at 11:29 AM
    #295
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Took my truck into the local dealer (bought it out of state) for the following issues, here are their responses lol
    -brake squeal in reverse- all the other 22 tundra's do it, within spec- LOL
    -bed rattles over bumps- all other 22 tundras do it- LOL
    -wind noise- tapped up every seam and did it all- then blamed it on my roof rack- did it before i installed it, its whislting from the front windows- LOL
    -black vinyl on front pillars not aligned and lifting in one spot- within spec- LOL
    -door rattles terribly with any bass- within spec of all other 22 tundras- LOL- this developed over time...
    supermike and Dmon187 like this.
  26. Feb 21, 2023 at 11:32 AM
    #296
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    Not all dealers are equal. Sadly, a lot of them don’t give a shit or make you got through a bunch of tests to do anything.
    kstateskier and wedemmoez like this.
  27. Feb 21, 2023 at 11:39 AM
    #297
    Breathing Borla
    AZ
    ya, thats bad man, Im sorry your getting stuff like that, its 100% uncalled for. The world today is full of idiots unfortunately
    I for one appreciate you trying to help and post insight without getting yourself in trouble.
    just delete all that BS
  28. Feb 21, 2023 at 11:42 AM
    #298
    Breathing Borla
    AZ
    ya, my dealer is way better than that. I can see how its frustrating when they say the other tundras are doing it so its in spec, ya right
    Dmon187[QUOTED] likes this.
  29. Feb 21, 2023 at 11:46 AM
    #299
    Ore43
    Ore43 New Member
    2023 Sequoia
    I really appreciate the information you post and I am sorry you are getting harassed like that, you don't deserve any of that
  30. Feb 21, 2023 at 12:15 PM
    #300
    Hella Krusty
    Hella Krusty New Member
    My 1794 has the tow mirrors and I have zero wind noise
