New Binize Box for ‘22 Tundra
Discussion in 'Audio & Video' started by TobyKai, Dec 7, 2022.
  1. Jan 1, 2023 at 3:37 PM
    topdec
    topdec New Member
    AWD Sprinter, 2023 4R ORP, 2 3rd gen Tundras - sold
    I have the 2022 CarlinKit AI Box with 4GB RAM + 64GB ROM. I think it's the same as the latest Binize box but cheaper.
    The 1 annoying issue that I have is that the carlinkit box doesn't automatically see/connect to my iphone's hotspot. Perhaps it's an iphone issue. I have to go to my phone's hotspot settings page for carlinkit to start seeing the hotspot name.
    RickyBobbysTundra likes this.
  2. Feb 6, 2023 at 7:07 PM
    MaiToyTunCap
    MaiToyTunCap New Member
    Hoa
    Minnesota
    2023 Tundra Capstone
    Bak X4S; Hardwired Dashcam; Carlinkit
    I been doing some research and Carlinkit CPC200 came pretty highly rated/recommended, so it’s reassuring that you’re happy with it.
    Regarding your hotspot issue, I doubt it’s the box’s fault. I work out of my vehicle and use my iPhone’s hotspot for my ipad on a daily basis. Often times, I have to go into my hotspot setting to turn it off then back on to refresh it in order for the ipad to re-connect.
    I’m going to put in the order tonight and report back with you to see if I have the same issue. If so, I will reach out to Apple support and see if there’s a fix.
  3. Feb 7, 2023 at 6:08 AM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    I have the CarlinKit 3GB RAM + 32GB ROM and have been very happy with it, not issues at all. I also have the iPhone hotspot issue, it’s not the CarlinKit box, it’s the phone. No matter what I am hotspotting to the phone, you often have to turn the hotspot function off and back on for the device to connect.
    MaiToyTunCap likes this.
  4. Feb 18, 2023 at 6:38 PM
    MaiToyTunCap
    Hoa
    Minnesota
    Finally got it in tonight... This will make those long days sitting at a construction site much more tolerable!
    P1NDLESK1N, TheSS712, sc taco and 7 others like this.
  5. Feb 18, 2023 at 9:37 PM
    4genRunner
    Southwestern MO
    Nice clean install. :thumbsup:
  6. Feb 19, 2023 at 1:22 PM
    Hella Krusty
    Hella Krusty New Member
    Question. I have read all about Binize but I cant find a firm answer. Can you play a downloaded video off your phone thru the Binize onto the OEM screen on the dash. Think of it as downloading a Netflix show to your tablet , then linking the tablet to the binize. Sometimes we don’t have cellular data so we can’t stream and have to play a download
  7. Feb 19, 2023 at 5:12 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Think you'd have to save media on an SD card or the box itself.
  8. Feb 19, 2023 at 5:14 PM
    eddiefromcali
    Eddie
    100% Stock
    Got a link to that cable?
  9. Feb 19, 2023 at 5:20 PM
    Hella Krusty
    Thanks. That was kinda what I thought. I never thought about the actual box
  10. Feb 19, 2023 at 5:22 PM
    MaiToyTunCap
    Hoa
    Minnesota
  11. Apr 12, 2023 at 4:23 AM
    CwickStylz
    CwickStylz New Member
    Andrew
    South Haven, MI
    2022 White Tundra Limited
    Just so I fully understand this Binizie Box's functionality...it plugs into the main CarPlay USB port & allows for a full Android 9, 10 or 11(based on box purchased) interface on '22+ Tundra's w/ the 14" Infotainment System?
    Reason I ask, is that I've been waiting months on a similar device, called Carluex that just came in, which was supposed to offer same/similar functionality & can't seem to get it past connecting for a split second & then immediately disconnecting.
    I've been trying all sorts of troubleshooting with the company, as they stated that it has support for Toyota's uptown 2023 models, but to no avail...works on my Jeep, with an aftermarket Alpine CarPlay head unit, but can't seem to get working on my Tundra & may end up going this Binizie Box route, if it's continued to work without issue for you guys? I'd really LOVE to take full advantage of that beautiful 14" screen with one of these devices, so just want to ensure I'm fully understanding how the Binizie works & that it continues to work without issue(s)?
  12. Apr 12, 2023 at 5:45 AM
    4genRunner
    Southwestern MO
    That is correct. Most here are using them for the ability to stream video to the screen via Plex, Netflix, Hulu, etc. I do not have the Binize box, I have the CarlinKit box. It works great, no issues at all.
  13. Apr 12, 2023 at 5:50 AM
    CwickStylz
    Andrew
    South Haven, MI
    Awesome! Thanks for the quick response! I'm essentially looking to use mine for very same stuff, so that's very helpful.
    I saw on their site, if I have the correct one below, they have options for Android 9, 11 & now a 12 device...which OS version do you have, as I don't necessarily need to be on the bleeding edge, but would prefer the version that I know is tried & tested working stably?
    Is this where you purchased from?
    https://www.carlinkit.store/collections/android-system-ai-box
  14. Apr 12, 2023 at 7:07 AM
    4genRunner
    Southwestern MO
    I purchased from Amazon. It is Android 11.
    https://www.amazon.com/dp/B0B9BRJ6JN
    Mine is the 3GB RAM/32GB ROM model. Listed on the CarlinKit site as the TBox Mini. The only thing I use it for is streaming video on long trips, so it’s fast enough for me. You can always spend more for one with more RAM/ROM and faster processor/more cores if you think you will need/want that.
  15. Apr 20, 2023 at 1:30 PM
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    Ok forgive me as I'm trying to understand these things and the system itself.
    1. I know I can use my android auto for some stuff. Can I tether (not hotspot) the Toyota system to my phone to use my cellular data? I know this may be a strange question, but it stems from using the Toyota system music options versus using them from my phone through android auto. I had the free wifi for a month and I like the interface over android auto.
    2. On these various boxes, can I tether the box to my phone (again, not hotspot) so that I can stream Netflix etc.?
  16. Apr 20, 2023 at 1:45 PM
    4genRunner
    Southwestern MO
    To the best of my knowledge, no you can not tether either the truck itself or one of these boxes to your phone. You can hotspot the truck and any of the boxes to your phone.
  17. Apr 20, 2023 at 1:47 PM
    ziznack
    ziznack New Member
    Texas Y'all
    Thanks. I want to tether cause it's usually faster and because I have unlimited tether but limited hot spot lol.
  18. May 3, 2023 at 6:45 AM
    MaiToyTunCap
    Hoa
    Minnesota
    In my experience, don't waste your money as they are all running a customer ROM and they're slow and undependable. I had issues with the unit I originally purchased with 4gb RAM and 64gb memory, so I returned that and purchased the 8gb RAM and 128gb of memory... Same issues.
    Apps constantly times out and would have to be forced close. I did noticed an improvement after I recently updated it to a new build released last month. All in all, still a custom ROM so it's not perfect.
  19. May 9, 2023 at 12:22 PM
    Tibetan Nomad
    Tibetan Nomad New Member
    The "older Binize" I ordered in April 2023 came with Android 12.
  20. May 9, 2023 at 11:00 PM
    #50
    1794Tundra1202
    1794Tundra1202 New Member
    Thanks for the info. Can you send some info on the process to install that cord please?
  21. May 10, 2023 at 10:38 AM
    #51
    TheSS712
    TheSS712 New Member
    Shayne
    2022 Army Green Tundra Limited
    @1794Tundra1202 I fished my cable(same one as MaiToyTunCap) through the front and fished it through. I removed the inside filter cover in the glove compartment to grab it. I did notch the cover for the cable too. I wasn't about to tear the dash apart.
  22. May 12, 2023 at 3:57 PM
    #52
    1794Tundra1202
    @TheSS712 Thank you - going to give it a shot this weekend. I agree with you there, not trying to take the dash apart. Nice to know that I don't have to!
    TheSS712 likes this.
  23. May 12, 2023 at 8:14 PM
    #53
    TheSS712
    TheSS712 New Member
    Shayne
    Someone with small hands can definitely grab the cable after feeding it through the dash. I fed it through pretty much right above the usb outlet.
  24. May 12, 2023 at 8:18 PM
    #54
    ziznack
    ziznack New Member
    Texas Y'all
    Can someone post the link to the binze they got? I got a little confused looking at them and couldn't figure out which is which.
  25. May 12, 2023 at 8:22 PM
    #55
    TheSS712
    TheSS712 New Member
    Shayne
  26. Jun 13, 2023 at 5:31 PM
    #56
    eyoung71
    eyoung71 New Member
    Is the only way to switch out of the Binize box or similar to unplug it? I was hoping to leave it plugged in and go back to Toyota screen or Carplay.
  27. Jun 13, 2023 at 5:34 PM
    #57
    ziznack
    ziznack New Member
    Texas Y'all
    Seems like someone would have come up with an app on Android to basically just bypass having a box and just use the phone. That's basically what the box is no?
  28. Jun 13, 2023 at 7:20 PM
    #58
    T315
    T315 New Member
    2022 Tundra Crewmax TRD Offroad
    I was looking into doing this then realized my SR5 has a shelf to store my Carlinkit. lol
  29. Jun 13, 2023 at 7:25 PM
    #59
    topdec
    topdec New Member
    That's 1 of the things I really like about the SR5. Plus the black window trim.
    T315[QUOTED] likes this.
  30. Jun 14, 2023 at 7:10 AM
    #60
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    Yes. To go back to the Toyota screen, one of the icons in Binize will take you back, I don't recall which one, I hardly use my Binize. Once back there, you can then switch in setting to you iPhone and get to CarPlay.
