Truck lunches when putting in drive, even when at a complete stop from startup.
Discussion in '3rd Gen Tundras (2022+)' started by RickyBobbysTundra, Jan 29, 2023.
  1. Jan 29, 2023 at 10:52 AM
    RickyBobbysTundra
    RickyBobbysTundra [OP] New Member
    Phoenix
    2023 Solar Octane TRD Pro
    Even with the brake peddle pressed the truck sometimes lurches forward when shifting from park to drive. Anyone else have this issue?
    TRD pro, 1k miles
  2. Jan 29, 2023 at 10:54 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Might depend on how your parking it. Try putting in neutral then applying parking brake. Then take foot off brake so the parking brake takes the weight. Then put in park.
  3. Jan 29, 2023 at 10:55 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    My truck breakfasts when left alone in the garage. What should I do?
  4. Jan 29, 2023 at 10:58 AM
    Lunging truck=dealership.
  5. Jan 29, 2023 at 11:05 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Maybe is just has too much torque :notsure:
  6. Jan 29, 2023 at 11:22 AM
    devron11
    devron11 New Member
    Ron
    Denver
    There is a TSB on this. My SR 5 does this too. Search the forum for the list of bulletins and then take it to the dealer.
  7. Jan 29, 2023 at 12:53 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    Took my truck in for the sad problem, the TSB cured it
  8. Jan 29, 2023 at 3:19 PM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    Lou1947, you know which TSB it was? was it for the pop/clunk or the surging?
  9. Jan 29, 2023 at 3:30 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    These new tundras seem hangry
  10. Jan 29, 2023 at 4:09 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Mine will do it if I go straight to drive when start it up. But, I let rpms get down around 800 or so it will not do it on start up.
  11. Jan 29, 2023 at 5:31 PM
    Breathing Borla
    AZ
    Tsb is out for this
  12. Jan 29, 2023 at 6:56 PM
    Adam B
    Adam B New Member
    Which one?
  13. Jan 29, 2023 at 7:09 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    They did two TSB on my truck , one for the clunk and one for the surge when I would put the truck on drive
  14. Jan 29, 2023 at 7:27 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  15. Jan 29, 2023 at 9:40 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    I think its this one
    RickyBobbysTundra[OP] likes this.
  16. Feb 2, 2023 at 10:38 AM
    RickyBobbysTundra
    Phoenix
    Took it to the dealer and they said because that TSB only currently applies to gas engines, they're not able to apply it to my truck without charging me a fee. They said it's best to wait for a TSB specific to the hybrid.
    Anyone know if this is BS or is a standard operating procedure for Toyota?
  17. Feb 14, 2023 at 8:00 PM
    Screwy Louie
    Screwy Louie New Member
    2022 Tundra limited double cab with TRD pkg white
    I would call this BS since the hybrid has the same transmission and gas engine, it just has a battery to work in conjunction with it. Ask another dealer if they aren't going to do anything. IMO
  18. Feb 14, 2023 at 8:28 PM
    RickyBobbysTundra
    Phoenix
    I asked two different dealers. Called Toyota corporate and they opened a case for. Will follow up by tomorrow EOD
