fuel leak above tank
Discussion in '2nd Gen Tundras (2007-2013)' started by creektrails, Feb 14, 2023.
  1. Feb 14, 2023 at 11:26 AM
    creektrails
    creektrails [OP] New Member
    2013 Tundra w/ 175000 miles. noticed fuel smell and now can see fuel leaking from a cylindrical part above the tank with wires going into it and kind of over the frame. This is near the front of the tank near the front tank strap. Kind of between the frame and the tank. What is this? I'm sure I need to drop the tank to replace it but did a search and can't find what it is.
    Thanks Also right against the emergency brake line.
    Edit: I am posting a picture and you can see it is above the frame. The fuel is coming out of the little hole. You can see it is wet below the hole. It only leaks when there is fuel pressure, also the truck is starting a little bit harder since the leak
    mdfcleveland likes this.
  2. Feb 14, 2023 at 12:26 PM
    creektrails
  3. Feb 18, 2023 at 8:25 AM
    creektrails
    gosolo likes this.
  4. Feb 18, 2023 at 8:35 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Glad you got it figured out and fixed. Sounds like a real pain in the ass to get to.
    welcome to the forum! Post some more pictures of your truck!
  5. Feb 18, 2023 at 8:41 AM
    These FFV E85 trucks sound like a pain in the ass.
