  1. Feb 13, 2023 at 6:27 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    I did the VLED tail light conversion kit. Very happy with my choice, great LEDs, changes the entire stock assembly look. I do recommend this kit below:
    https://www.vleds.com/featured-vehi...ndra-vt-v6-extreme-tail-light-conversion.html
    Also swapped out my front LED turn signals with these:
    https://www.vleds.com/shop-application/turn-signals-front/7440/7443-50-hv-amber-2.html
    Contemplating on doing the Fog lights (amber or white?) and haven't decided on my cargo/third brake light. I swapped out all my interior bulbs first week of ownership, surprised they weren't factory LED, ($25 kit on Amazon :thumbsup:).
    bulldog93, Trentimus and RainMan_PNW like this.
  2. Feb 13, 2023 at 7:10 PM
    Trentimus
    Trentimus New Member
    Trent
    2019 Tundra Off Road
    Nfab bars, undercover armor cover, hottails
    I have the taillight conversion as well, but recently noticed every once in a while the reverse lights (one or both) fail to come on.
    I used my security camera to check and it failed like 3 out of 25 reverse gear changes.
  3. Feb 13, 2023 at 7:16 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Contact VLED about it? 2-3 yr warranty.
  4. Feb 13, 2023 at 7:52 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    Thanks. I was just at the scrap yard today too. Would've tried to snag one.
  5. Feb 13, 2023 at 9:37 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    No. 4Hi flashed for quite a a while.
  6. Feb 13, 2023 at 9:41 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    There’s a 2WD light? I don’t think I’ve ever seen it.
    I’ve noticed this of I don’t straighten out the wheels and let off the gas for a second or two.
  7. Feb 13, 2023 at 10:53 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Just looked at it and enjoyed the sunset
  8. Feb 13, 2023 at 11:27 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The FRAC Harness is powered by the Head Unit’s ignition power circuit through the harness itself. So unless the ignition is on, the FRAC circuits can’t physically draw any power.
    If the front camera is installed as recommended, it is powered by the same ignition source via the FRAC cam power lead. So it will also draw zero amps when the ignition is off.
    Some guys have connected their front camera to a constant 12v source. I don’t recommend this approach. If this is done, then there will be a constant low current drain on the battery. This can cause issues over time.
    Not sure how yours was wired, but i would check that.
    I have helped a couple guys resolve some power issues where the power lead from various mods had been pinched to the chassis during re-installation. If a power wire insulation is not damaged enough to short out immediately, then over time with normal road vibration the insulation will still gradually wear down. Initially there may not be enough continuity to blow a fuse, but it can still cause excessive power drain until the time it fully shorts out. Those are the hardest problems to find. So I would inspect all modded wiring carefully.
  9. Feb 13, 2023 at 11:38 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I’d be interested in understanding any “weird” issues that may have been caused by the FRAC Harness. Quality is very important to me and I fully test every harness before it is shipped out. That said, problems can still arise so I also work hard with anyone having technical issues in order to resolve them.
  10. Feb 14, 2023 at 1:51 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    Couldn’t wait so last night I insralled the rear EKE seat covers. Great fit and look in my opinion. Hardest part was getting the head covers on. Ended up taking them inside to let them warm up a bit before pulling them on.
    Nbab23, welshmike, Henry1jg and 8 others like this.
  11. Feb 14, 2023 at 2:12 AM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    My first wheeler was a Timberwolf 250 and then I inherited my dad's '93 or '94 Warrior. I had a lot of fun on that thing for a few years.
    Here's my friend and I being retarded.
    Ace96, Bama, mgm16trdpro and 2 others like this.
  12. Feb 14, 2023 at 3:55 AM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    I do understand that. I have no complaints. You have great product and I like to support small business.
    For me, if something doesn’t work or I don’t like it, I just replaced it with the other product till I like it.
    That’s why I had 3 different kinds of suspension sets on my truck ;)
    Give me your address and I will send the harness back to you for your investigation purposes.
  13. Feb 14, 2023 at 4:55 AM
    Woodsong
    Woodsong New Member
    Do you have a link for these? I am looking for seat covers for my 2019 tundra. The ones I got off Amazon fit poorly!
  14. Feb 14, 2023 at 5:21 AM
    Eborseti22
    Evan
    Henry1jg and bulldog93 like this.
  15. Feb 14, 2023 at 9:09 AM
    Blueox08
    Blueox08 Building it better stronger but slower
    Sam
    Southern Oregon coast
    2019 Tundra sr5 double cab 8ft
    Ironman 4x4 3.5” full suspension lift Ironman 4x4 8ft awning with attached tent room Elk leg bone shifter Arb canopy with kargo master rack 10ft rooftop cedar deck with lighting Rough country grated step boards Tuffy Center console safe Keyline smart batter isolater with dual batteries to power inverter. 8ft wooden drawer slides with bed plat form for camping set up Ironman 4x4 13 gallon water tank. Bucket shower Side step lights and back up lights. More to come
    Someone 3d printed these little window tabs for me years ago. Finally got around to installing. Not sure how long they Will last on logging roads but they work for now.
  16. Feb 14, 2023 at 9:56 AM
    awr1211
    awr1211 New Member
    Wendell
    2019 Black Tundra SR5
    Installed EKR seat covers and 13 inch Tesla style radio from Phoenix Automotive.
  17. Feb 14, 2023 at 10:26 AM
    Eborseti22
    Evan
    Only had mine in a day, but I love them so far! Couple people I showed thought I had leather installed haha! You happy with yours too?
  18. Feb 14, 2023 at 10:30 AM
    awr1211
    awr1211 New Member
    Wendell
    I love mine. The only thing I dont like or have to get used to is how cold they are when I try to leave in the morning with out warming up the truck.
    Eborseti22[QUOTED] likes this.
  19. Feb 14, 2023 at 10:30 AM
    skifreak
    skifreak New Member
    North Carolina
    2015 Tundra SR5
    Tekonsha brake controller
    can you send the link for the seat covers? i cant find the red like what you have
  20. Feb 14, 2023 at 10:31 AM
    Eborseti22
    Evan
    Funny, I thought the same thing this morning, but I can get over that for the look they add!!
    awr1211[QUOTED] likes this.
  21. Feb 14, 2023 at 10:31 AM
    Eborseti22
    Evan
    Look up in the window a few posts - I sent it earlier today
    bulldog93 likes this.
  22. Feb 14, 2023 at 10:37 AM
    awr1211
    awr1211 New Member
    Wendell
  23. Feb 14, 2023 at 10:52 AM
    pyrite12
    pyrite12 New Member
    NY state
    2021 Silver Sky TRD DC
    These really fit that well...? I've had them in my cart for a couple of months and haven't pulled the trigger because of some pictures I've seen of them fitting loosely (on the back seat mostly). I'm sure a lot of it has to do with the installation...?
    I was thinking this would be a cost effective way to add seat heaters, as I don't trust myself to take off and re-secure my factory cloth seat covers.
    d_kinneyjr likes this.
  24. Feb 14, 2023 at 11:01 AM
    awr1211
    awr1211 New Member
    Wendell
    I say do it. I was the same way they were on my wishlist for a few months before I did it. My backseats fit snug and are not losse at all. I installed mine while it was cold and didnt have to do any extra pulling or stretching to get them to fit right.
  25. Feb 14, 2023 at 11:17 AM
    Sergicalmaneuver
    Sergicalmaneuver New Member
    So Cal
    2019 Platinum Crewmax
    How do you like the radio??
  26. Feb 14, 2023 at 11:21 AM
    Eborseti22
    Evan
    They fit great. I did mine cold as well and thought the fit was pretty impressive considering cost. I am not sure I would put heaters between them and the original seat though, but I don;t know much about it.
    My backseat was a little loose, but once it heats up here in MA I will adjust accordingly. One day soon it will be hot again...
  27. Feb 14, 2023 at 11:48 AM
    pyrite12
    pyrite12 New Member
    NY state
    Thanks for the feedback guys...that was the push I needed!
  28. Feb 14, 2023 at 11:52 AM
    Eborseti22
    Evan
    Hah no problem! I figured worst case even if it wasn't a great fit, its still WAY cheaper than Katskins or some other custom covers out there...Plus it's always fun to be pleasantly surprised by something you don't have high hopes for!
    pyrite12[QUOTED] likes this.
  29. Feb 14, 2023 at 12:16 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    where is the write up for this?
    Blueox08[QUOTED] likes this.
  30. Feb 14, 2023 at 12:18 PM
    Taco-Spike
    Two Trucks
    cartage1, bulldog93 and Blueox08 like this.
